Question about Malber WD1000 Front Load Washer/Dryer
New Malber wd1000...how do you unlock the dryer..picked up at store
HI..i just bought a floor model and after the wash cycle it doesn't kick into dry...i think you have to unbolt some screws from the dryer or set it up properly..they forgot to give me the manual and it's in the mail but i need to use it...wash works but doesnt' go into dry cycle when finished...tried everything with settings so i think there is something to do to the machine for set up?? Some type of bolts have to be removed..called them but they will only send the manual or make an apt for a month away for someone to come..HELP...thanks
  • Dianne Quinn Jun 24, 2007
    Thank you so much...yes the shipping brackets were still in place...thank you soooo much!
  • 247 Answers
TURN THE MACHINE OFF NOW. If the machine still has the transit brackets fitted (which is what I think your post implies), operating it in a wash cycle is likely to lead to severe damage to the machine and could be quite dangerous too. You can find a copy of the manual here: http://www.absak.com/pdf/manuals/Malber/WDman.pdf Before you use the machine again, suggest you look at page 2, and check that everything that should have been removed actually has been. Turning to the question you actually asked, failure to go into a tumble cycle isn't really the sort of thing that would normally associate with packaging having been left in place. Skimming through the manual, there are hints (see page 14) that you're meant to do some counterintuitive things to make the dryer work on this model - like keeping the "half load" button pressed in. Making sure "Spin Cancel" is out is a bit more obvious, but just as important. A.
Posted on Jun 22, 2007
How do I dry clothes
Either hang them up wet or put in clothes dryer
Nov 26, 2014 | Malber WD1000 Front Load Washer/Dryer
How do you get the water to drain in the Malber WD100 washer/dryer combo?
Hi. I''m assuming you are referring to a WD1000.
To initiate the drain cycle: Rotate far right knob CLOCKWISE to Position 4. It may take 30-45 seconds to recognize the knob's new position, but then it will begin an 11 minute Slow Tumble/Pump Out cycle. During this cycle you'll see the internal drum slowly rotate CW for 60 seconds, pause, then rotate CCW for 5 secs - then repeat. All this time the pump will run and you'll hear water running down the drain. When you hear no more water you can rotate same knob to "straight up", and stop the machine. To turn power off, press the rightmost button.
Sep 21, 2014 | Malber WD1000 Front Load Washer/Dryer
Spin cycle not working on Malber washing machine, it is on a used boat we just bought and it is in Fort Lauderdale but coming to NY soon, boat broker says he cant locate a person to fix the Malber- an
In New York, call Malber Distribution Corp at 516-323-5299.
They can schedule a technician to fix your machine. They've been fixing Malbers for about 25 years.
Tell them Mike, in Wash DC, says hi.
Mar 06, 2014 | Malber WD1000 Front Load Washer/Dryer
Hi, How do I open the door on a Malber wd1000 when is it stuck after the cycle is over?
Some machines require it to be empty of water to allow the door to open.Try dropping the drain hose low into a bucket to allow it to open, then clean the filter as it may be blocked causing this problem... Good luck
Feb 10, 2011 | Malber WD1000 Front Load Washer/Dryer
Water leaking out on the floor after first rinse cycle
if it's a single machine- the dryer cycle could be damaging the seals on the door or the drum.
check your warranty!
good luck!
Apr 17, 2010 | Malber WD1000 Front Load Washer/Dryer
Flooding
I never had this problem with my unit, but I've been using detergent that is specifically designated for front-load washers. You can find it at Target or any other store. It's supposed to reduce the amount of suds/foam build-up within the unit, so it might prevent thte flooding.
Hope this helps.
Aug 11, 2008 | Malber WD1000 Front Load Washer/Dryer
Malber wd1000
Two of the dials are dryer settings. There is only one washer dial, which basically controls the length of the wash and rinses, etc.
Apr 22, 2008 | Malber WD1000 Front Load Washer/Dryer
Discharge hose
I thought I needed a specific hose from Malber, but I was able to use a generic hose from the hardware store.
Apr 05, 2008 | Malber WD1000 Front Load Washer/Dryer
Gasket for Cleanout at bottom of Malber WD1000
WD1000 gaskets are in stock and available for immediate delivery from Malber USA. (info@malberusa.com)
Dec 09, 2007 | Malber WD1000 Front Load Washer/Dryer
Open Questions:
See all Malber WD1000 Front Load Washer/Dryer Questions
Malber WD1000 Front Load Washer/Dryer Logo
157 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
ashburton
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
