Question about RC Micro X Copter Mini RC Helicopter
Can't charge micro x mini i/r control helicopter
There aren't green light in charger
Search Results
    How To Fix Your RC Helicopter - YouTube
    ? 4:22
    https://www.youtube.com/watch?v=R65JJYwSH50
    Jun 28, 2010 - Uploaded by R/C 101
    Does your RC helicopter spin out of control in the air or ... thing that the video says but there nothing wrong about it the remote is fine but the propeller .... i have a brookstone RC stunt copter that i have not used in a few months. i .... however when I come to fly it, it makes a sound but the wings aren't working.
    All comments on How To Fix Your RC Helicopter - YouTube
    https://www.youtube.com/all_comments?v=R65JJYwSH50
    where can I buy new gears and pinions for my mini rc helicopter?. Read more Show.... The two pins on the charger port aren't working they won't charge ..... The charging light is off meaning the battery is charged. Any ideas? ..... So, the motor spins the correct way but there is no gear to transfer the power to the rotors 'A'.Missing: silver ‎bullet
    rc helicopter light flashing Remote Controls Questions
Jan 19, 2016 | Brookstone Rc Mini Helicopter Silver...
Helicopter charger and batteries in remote ok, chopper won't fly
Is the "flight light" blinking on the copter? If you connect the USB cable to the copter will it power up? Have you tried different batteries in the remote? Check the pins in the charging port on the copter, Otherwise there's not a lot that can be done with these little RCs.
Feb 24, 2015 | Syma S102 IR Control Micro Blackhawk RC...
Why is that not working?
The antenna in the helicopter might be broken
May 08, 2014 | Electric 3CH Mini Sport RTF RC Helicopter...
My jxd 341 vr mini helicopter just bought it new batteries fully charged it wont take off just spins on the ground
Remove the body shell and make sure both gears are meshed to the drive system. It sounds as though only one rotor is being powered and the contra-rotating rotor is rotating freely and not being driven. If I was you, I'd take it back. These models are mass produced so you may have a faulty one. If you don't, then it could fail when the guarantee runs out.
Oct 04, 2013 | JXD 331 Cobra 3CH Micro RC Helicopter RTF...
Syma S109g Apache Ah-64 3.5-channels Mini Indoor Helicopter will not charge; the light will keep being red on the USB
Try bringing it to your local electronics store. It might be the connection, or in could be another electrical problem.
Jan 29, 2013 | Syma S109g Apache Ah-64 3.5-channels Mini...
Air hogs pocket copter, brand new. Inserted brand new batteries into charger and controller per instructions. Plug the helicopter into charger and led blinks red as stated. About two or three minutes into...
You bought a defective mini copter, the internal micro relay is malfunctioning and I hope you could bring it back where you bought it. Replace it with a new one and let them try to test flight it before you go home.
Hope that helps you out.
Thanks for asking FixYa!
Aug 09, 2011 | Toys
I have 3 s107 and I it says 3 channel on the box and the transmitter says A B C but will only let me select 2 of them. What's the trick on flying 3 at the same time?
Mine's exactly the same as yours. Although the transmitter shows A B C the switch has only two positions, so there's a choice of two only. I doubt it's possible to fly 3 at the same time.
Nov 08, 2010 | SYMA Toys industrial New Syma S107 Radio...
My AH-64 is out
No you can't change it you must get the right transmitter.
Jun 11, 2009 | SYMA Toys industrial SYMA S009 Micro...
RC Micro X Copter Mini RC Helicopter Logo
141 people viewed this question
Top RC Toys Experts
Tom Chichester
Kevin K.
Brett Duxbury
Brett Duxbury
Are you a RC Toy Expert? Answer questions, earn points and help others
