Question about Haier HVTS18DBVS 18 Bottle Dual Zone Wine Cooler
Wine fridge is always running but never cools below room temperature.
We have since replaced the top fan in the back (it keep freezing up, bad bearings?) and now it seems the bottom fan isn't working. After replacing the top fan the unit still wouldn't cool below 60f. And the top fan looks like it is thinking about seizing up again, too. It doesn't seem worth it to keep buying fans from Haier so we are hoping to use a computer case fan (modding the 3 pin for the 2 wires) but that also seems to be tricky as the wires from the fan don't want to stay in the 3 pin holder that the haier takes.
  • 2,427 Answers
The processor cooling fans for the CPU and case fans are 3 PINS.. you can use them but remember that these are 12V fans. once its the same power it will work. Ps if needed you can cut the connects from your old fan and connect it to the new ones to get it to fit properly..
Posted on Dec 30, 2012
Testimonial: "The fans for the haier are also 12v. The problem is the 3 pin for computers is different than the 3 pin connector the fridge is using (I dont know if there is a male/female issue?). And would I need some sort of crimper to get the wires to go into the connector more securely? "
  • 3 more comments
  • Rishi Roshan Ali Dec 30, 2012
    not really ,, you can just pull them out using a needle nose pliers.. and tap it back in using a small bladed screwdriver.. To be honest i would just cut the wires and solder them together then insulate it with pvc or eletrical tape..
    once the wires are insulated and dont touch one another you'll be fine.
    and i almsot forgot.. if you look at some of the fan connectors you will notice a pice of it to the back pith the pin metal exposed. this is actually a clip, Use a small screw driver to push the clips back in while pulling with the pliers so you dont ruin the clips.
  • katzblood
    katzblood Dec 30, 2012
    We were tempted to try the soldering if it didnt work. This morning it is down to 53 degrees f so it must be working! Now to see if it lasts! Thank you so much for all of your help.
    no problem...
Why is there an occasional rattling sound from the rear?
Good afternoon Bob.
Wine coolers have a lot in common with mini-refrigerators. The cooling for the wine, to proper 'cellar' temperatures is done gently (one hopes) with circulating cool air that should keep the temperature stable, and the dust to a minimum.
The fan you hear is most likely one keeping the refrigerant compressor cooled off. Depending on how your unit is packaged, what you'll likely want to do is
  1. Unplug the unit. No pokey pokey into the guts of things plugged into the wall. Always err on the side of safe. Aside from shock rick, the small fans in fridges can actually cut fingers up pretty good if you let em.
  2. Look to the rear lower section of the unit and find the compressor(s) and associated fans and perhaps cooling coils. Much like with regular fridges, use a brush or a vacuum attachment to clear any dust bunnies or other debris off of the coils, compressors, and fans.
  3. Examine the fans. See if anything may have been sucked up into the blades or spindle - giant cobwebs, bits of thread of carpet fiber. See if the blade will spin freely, and whether it feels loose. If it won't move, or is obstructed, try to clear it and clean off any debris or fiber. If it will not move, the fan may have failed. You don't want to run a fridge this way, as the next thing to go after the cooling fan for the compressor is the compressor. At which point most honest techs will say 'buy a new fridge, I can't replace it for less than the fridge will cost you.
  4. You can also see if there is anything else obviously loose near the compressor or fan. There's a significant power surge needed to start the compressor, and the initial slow cycling may be making things shudder.
Hoping this is useful. Good Luck!
Nov 18, 2015 | Furniture
Fridge keeps freezing
Cold air falls so unless your fridge has a fan the bottom is always going to be colder than the top. Raise the temperature by a couple of degrees, as your thermostat is reading the temperature at the top.
May 29, 2015 | Refrigerators
Wine fridge is not getting cold anymore
Its really hard to determine without proper diagnosis, but are you sure it indeed has a compressor? does it run ? Does it have a circulating fan inside? A lot of the wine coolers I've dealt with were "Peltier" coolers. They use electronics to cool usually only to about 10deg below room temp. They require a load ( in this case wine bottles ) to operate properly. They don't have a cold control like a refrigerator.
Jun 30, 2014 | Koolatron KWD28SN 28 Bottle Compressor...
Wine cooler does not stay cool
Do only if you are properly trained on live circuits.. Do at your own risk. Check the compressor's capacitor and the relay. Is the compressor getting juice?
Nov 23, 2013 | Avanti Refrigerators
How to replace heater hose
Let the engine cool. Take off the radiator cap.Remove the drain bung from the bottom of the radiator.If you can't locate the bung, or have a hard time taking it out, then just remove the radiator bottom hose clip and hose.
Depending on which hose you want to replace, you can disconnect it at this point and refit your new one.
Replace the bottom hose if you disconnected that, tighten your radiator drain bung and refill your system with a 50/50 mix of water and antifreeze. Even if you live somewhere that doesn't go down to 0 degrees C, then you still need anti freeze as it evens out inner engine temperatures and prevents corrosion build up in the system.
Run the car up to temperature, keeping the internal heater set to the hot position with the fan on minimum.
Top the radiator up continually until there are no more air bubbles coming out of the top.
Replace the cap and keep engine running until the radiator fan cuts in. Then let it all cool back down again with the engine off. Remove cap again and refill.
Roadtest the car and recheck again.
Over the next few days keep an eye out for any fresh leaks and top up the radiator if necessary.
BTW, usually if one hose has failed, then the other isn't far behind. I'd recommend changing both at the same time.
Nov 13, 2012 | Cars & Trucks
SMEG Fridge Freezer FA561XF - the frame of the fridge/freezer gets very hot and freezer isn't freezing stuff in bottom tray
That is a very bad sign, but before you unplug it pull the machine out from the wall and check to see if it feels hot back there as well. Then remove the lower cover and find the condersor fan motor. Its the only fan back there. I'd willing to bet that the fan is not running. The purpose of the the fan is draw air across the compressor and blow it through the condensor therefore lowering the temperature on both parts. When its not working/ running, the heat from the compressor and the condensor is pass onward to the machine and the machine then acts as a heat sink.
Also, if the machine is too close to the wall or the condensor coils are dirty you'll get the same effect, so be sure to check those things out as well
Jun 21, 2012 | Smeg FA561X Side by Side Refrigerator
I have Kenmore Elite 59673503201 freezer fan went out replace then it started freezing at the bottom of the refrigerator put in new vent control at the top of refrigerator still doing the same thing
The temperature control thermostat, alson known as the colds control thermostat has gone bad and basically isn't converting electrical/temperature signal properly and needs to be replaced.
May 17, 2012 | Kenmore Refrigerators
Refrigerator not cooling
the damper vent door fan that blows the cold air from the freezer into the refrige compartment is bad,these are known to go bad a lot of the time,you need to buy the whole damper vent door/motor together
May 02, 2012 | GE Refrigerators
Whirlpool freezer won't freeze
you need to send the model number so i can see what fridge you have,is it a side by side freezer on top or bottom.check the back inside wall of the freezer to see if any ice or like snow is on the back inside wall of the freezer,if so you have a defrost problem,if it's a top freezer is there any water leaking into the fridge section,check under the crisper draws,if water is there you could have a blocked drain in the freezer,the water that's from the defrost mode leaks into the air ducts and freezes,or you could have a freon leak in the sealed system,remove the inside back wall of the freezer and check the frost pattern on the evap coil,if there's frost just on the top of the coil and nowhere else on the coil you have a freon leak,one more thing you could have a bad evap fan motor,open the freezer door,you should hear the fan blowing around,open the freezer door and push and hold the door or light switch in for a minute and then let it out,if the fan doesn't run it could be bad.the last thing is the compressor isn't running and you're hearing the condenser fan running and not the compressor,the start device on the compressor could be bad,feel the compressor,is it hot and feel it to make sure it's running.so bad start device,freon leak,defrost problem or bad evap fan motor or condenser motor.if you get back to me and let me know what you find and send the model number i can help you better.
Nov 02, 2011 | Refrigerators
Haier HVTS18DBVS 18 Bottle Dual Zone Wine Cooler Logo
187 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
