Question about IBM ThinkPad T40p 2373 Notebook
What is the location of the hard drive? - IBM ThinkPad T40p 2373 Notebook
    Problem Solver:
  • 8 Answers
Easy, please search in the bottom or base of notebook, in the right side a screw near to the corner, only you have to remove it and pull, voila, you have the hard drive.
What is the location of the hard drive? - 12_30_2012_3_46_36_am.jpg12_30_2012_3_46_54_am.png
Posted on Dec 30, 2012
    Habit-Forming:
    Scholar:
  • 69 Answers
To get to the hard drive, you only have to remove one screw on the bottom. Pictures are worth a thousand words - so, even though it's in Russian, the following YouTube video clearly shows how to remove the hard drive (at about the 2 minute mark on the video).
http://www.youtube.com/watch?v=C-qUlkoOYU0
Cant open my hard drive in my laptop
Locate the power cable and USB cable that came with your hard drive.
Connect cables to the appropriate locations on the back of the hard drive.
Sometimes a USB cable doubles as the power source, so you might not need a wall outlet to power the device.
Turn on your computer and allow your operating system time to load before continuing.
Plug the hard drive into the power outlet if necessary, but wait on powering up the device.
Connect the USB cable to the computer while the hard drive is in the "Off" position.
If the USB cable doubles as the power source, the device might turn itself on once connected.
Turn on the hard drive and wait until the hardware has been detected by the operating system. A message should pop up that lets you know new hardware has been detected.
Click on the "Start" menu and go to "My Computer."
Notice all your disk drives are listed in this window. The external hard drive should be visible, and holding the mouse cursor over the location will help you locate the correct drive.
Right click on the location of the drive, and move the cursor to "Open" or "Explore" and click.
Hope this helps
Sep 26, 2012 | Transcend StoreJet 25 Mobile 500GB USB 20...
Tip
Make a back up of your music on an external Hard Drive or Flash Drive
Copy iTunes folder to your external hard drive
To copy all the items in your iTunes library (including the iTunes Library file that holds all your playlists, playcounts, ratings, and other data) to your external hard drive, follow these steps:
Quit iTunes.
Locate your external hard drive.
Mac: On the desktop or Finder sidebar.
Windows: In My Computer
Locate your iTunes folder:
By default, the iTunes folder is located in:
Mac OS X: /Users/username/Music
Windows XP: \Documents and Settings\username\My Documents\My Music\
Windows Vista or Windows 7: \Users\username\My Music\
If the iTunes folder is not in the default location listed above then you can find where the iTunes folder is located by following these instructions:
Open your iTunes Preferences:
Mac: Choose iTunes > Preferences.
Windows: Choose Edit > Preferences.
Click Advanced.
The location of your iTunes folder will be listed in iTunes Media folder location box, as pictured below.
Drag the iTunes folder to your external hard drive. This can take a while if you have a lot of items.
When the transfer is complete, your iTunes Library will have been successfully copied to your external hard drive.
on Apr 15, 2010 | Computers & Internet
How to make a master fujitsu mvh2080ah? Which jumper do I have to use to render the 2.5" hard drive master? Thanks a lot, Mustapha
Fujitsu might be different have a look on top of the hard drive this is if your hard drive is IDE 40 pin flat bibbon type leads
if its a SATA hard drive the larger drive takes the master
you can find the jumper location next to the power on a hard drive and the settings for plastic jumper location is usually printed on the top of a hard drive
IDE-0 means Pri master
IDE-1 means Pri slave
IDE-2 means Sec master
IDE-3 means Sec slave
single or master :::::
master with slave ::'::
slave :::':
black line between dots is plastic jumper
note the plastic jumper is ' located at the rear of the hard drive between the EIDE and electrical lead/s
hope thie helps
Jul 20, 2012 | Fujitsu Computers & Internet
How to remove hard drive from laptop
It depends upon the make and model.
Some hard drives are fitted on the side of the laptop. Remove the screws on the bottom of the case where the hard drive is located and then slide out the hard drive.
Other laptops have the hard drive located on the bottom of the laptop behing a panel. Remove the panel to reveal the hard drive and slide the hard drive off the connector.
Jun 05, 2012 | Computers & Internet
Remove a hard drive
Depending upon your model laptop, the hard drive may be located behind a panel on the bottom of the laptop or it may be located on the side of the laptop and the retaining screw/s will be on the bottom of the laptop.
When you remove the panel the hard drive will be screwed to a hard drive caddy. Remove the screws on the caddy to release the hard drive. Keep these screws as you will need them to fix the hard drive to the caddy.
Feb 11, 2012 | Sony Computers & Internet
Select as master
slave :::':
Nov 14, 2011 | Samsung (SP0411N) 40 GB Hard Drive
Where is the location & how to remove the hard drive for toshiba satelite P15-S470
The hard drive is located under the CD/DVD drive. Before you start taking apart the laptop, remove the battery and unplug the AC power.
1. You have to remove the CD/DVD drive. Turn the laptop over. Remove one screw right above the dive and slide the drive out of the laptop.
2. When the CD/DVD drive is removed, you'll see a metal plate. The metal plate is secured by 4 screws. Remove them and lift up the plate from the bay. The hard drive is located right under the plate.
3. After you remove the plate, you'll see the hard drive. The hard drive also secured by 4 screws. Remove the screws, slide the hard dire to disconnect it from the connector on the moterboard and lift it up.
4. You have to transfer the brackets from the old hard drive to a new hard drive. Also, if there is a foil shielding around the old hard drive, you'll have to transfer it to a new hard drive too.
Below is website with a picture guide on how to remove the hard drive>>>>
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-P10/remove-hard-drive.htm
Regards.
Apr 21, 2011 | Toshiba Satellite P15-S470...
Hard drive replacement
Hard drives are easy to replace, they are located in a separate compartment. Depending upon the model of your laptop, it could be located on the bottom or on the front or left or right hand side of the laptop. The hard drive may have an adapter connector that fits over the 44 data pins on the hard drive.
For further information please click on this link :-
http://www.fonerbooks.com/laptop_1.htm
After you install a new hard drive, you need to format the hard drive and install Windows on the hard drive plus the device drivers of the devices that are installed on the laptop eg. video, audio, modem, LAN and wireless etc.
Jan 21, 2010 | Fujitsu Stylistic ST5010 Tablet PC
Locate the hard disk
Laptop hard drives are mainly located underneath. A screw holding down a plastic lid covers the drive. In some cases of older laptops the hard drive is slot mounted and you'll have to remove screws underneath and/or on the side to release the drive followed by pushing a switch which well push the drive out.
Jan 14, 2010 | KDS Computers & Internet
IBM ThinkPad T40p 2373 Notebook Logo
69 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
