Question about Microsoft Xbox 360 Wireless Controller
My XBOX 360 remote blinks twice and go's off
I just got a xbox about 5 days ago and i am now having problems with the remote. It blinks green for about enough time to press one button on it. I have been having alot of problems with it. I dont no what to do!
Watch this video and visit to fix your problem here:
http://tinyurl.com/fix-3-red-lights-on-xbox-360
Posted on Dec 30, 2012
  • 111 Answers
SOURCE: Xbox 360 will not send a picture signal to TV
sounds like you have a graphics card problem with the xbox 360. possibly loose/damaged electrical connections between the GPU and the motherboard which has caused the xbox to not display a picture. with this being a Hardware problem i would suggest calling the Xbox customer support, numbers can be found on http://www.xbox.com/support call up the support team and explain your problem.
I believe that microsoft will ask you to send the Xbox direct to them so they can fix the problem for you, it shouldnt take long to correct !
hope this helps
Posted on Oct 29, 2008
  • 34 Answers
SOURCE: xbox 360 red light
Unfortunately there is nothing that you can directly do to fix this problem without voiding your warranty,. This means that if you attempt to repair it and fail MS will not fix it for you.. The "Fix" posted by others SOMETIMES works, but NOT ALWAYS.
Pleae be careful with your expesive gear!
You have a hardware failure. Microsoft will repair your unit for you under warranty / recall.
http://support.microsoft.com/kb/907534
Sorry to be the bearer of bad news.
If my solution was helpful, please vote for me!
Posted on Nov 16, 2007
SOURCE: red light on my xbox 360
Turn console of, hold sync button down wich is the small white button next memory card slots, while holding turn on console and wait till it boots. If this does not work go to system blade, select memory, press y on the HD symbol, press xx left bumper right bumper xx, select yes. This will restart your console from scratch though all profiles and saved data will be lost, but it will clear any corupt data.
Posted on Sep 16, 2007
SOURCE: xbox 360 wireless control pad wont connect
have you tried to pair it... the little white button on both the controller and the 360? works just like the wii remote
Posted on Feb 07, 2009
  • 18 Answers
SOURCE: BEEP THEN FREEZE
You might check out the Informative article atEzinearticles.com to fix the freezing problem as the articlegives the information about a DIY guide, (though i don't remember thename of the site) but you can check the article from http://ezinearticles.com/?Xbox-360-Freezing-Fix&id=1527369
Posted on Apr 07, 2009
I have an xbox remote that wont sync to my xbox console. I used the remote with a different xbox console prior. Could this be the issue? How do i reconfigure my controller? I have pressed the search/reset...
Try this! Press and hold the button below the disc changer, also press the sync button near the charger port on the controller. Light should rotate clockwise and then blink twice. This will tell you which player you are.
Sep 16, 2011 | Microsoft Xbox 360 Controller
My Xbox 360 controller appears to be having some issues: i turned the xbox on, and it is immediay prompting me to download an update from Xbox Live, however, I cannot get my controller connected to get rid...
There is a connect button on the controller as well. See this site or follow the instructions below. http://support.xbox.com/en-us/pages/xbox-360/get-started/console/connecting-game-controllers.aspx
  1. Turn on your console.
  2. Press and hold the Guide button on the controller until the controller turns on.
  3. Press and release the connect button on the console.
  4. Within 20 seconds, press and release the connect button on the controller.
  5. When the lights surrounding the power button on the console stop flashing, the controller is connected.
Jun 30, 2011 | Microsoft Xbox 360 Controller
I cant sink my new remote to the controller. The controller just blinks when pressed. I cant get the controllers green lights to circle.
XBOX 360 repair guide available that covers this problem and also all other common XBOX problems. You can get your copy XBOX 360 Repair Guide, you can download it and get help to fix your console....
click here to download repair guide
Dec 26, 2010 | Microsoft Xbox 360 Wireless Controller
Comcast remote's ok button doesn't work with xbox 360
Sorry, the Red Button won't work, but you can map the A button on the Comcast remote instead. It's almost the same thing... Your fingers will barely know the difference.
1. Press the Aux button at the top of the remote.
2. Hold the Setup button until the Aux button flashes twice.
3. Enter 994 on the keypad. The Aux button will flash twice again.
4. Now push the Setup button once. Enter 00001.
Finally, push the A button The Aux button will flash twice. You now have the A / Select / OK / Green button mapped on the Xbox360.
--If you want to switch the A button back to default, just do the same sequence but this time push the A button twice.--
Apr 07, 2009 | Universal Remote Control Remote Control
One red blinking light on my xbox console
Hi, The red lights indicate an electronic failure, since you got this unit a week ago I would first contact the store where it was purchased to see if they will exchange it for you, if they won't, then the x box will have to be sent in for warranty repair. Call Microsoft and they will issue you a return label. Good Luck to you!
Feb 22, 2009 | Microsoft Xbox 360 Console
Flashing red ring on x box 360 console
3 Blinking red lights often means that your Xbox 360 has suffered from hardware failure.
4 Blinking red lights means that your Audio / Video cable is not correctly connected (it's the colorful one; Red, white, yellow; green, blue, red if Component)
If it IS just three lights, and you bought your xbox 360 under three years ago, call 1-800-4MY-XBOX
Jul 18, 2008 | Video Game Consoles & Games
I get red rings when i turn on my xbox 360
Xbox 360 problem
If you can still HEAR sound, but can't see. Check your Audio Video Cable.
It's the colorful one (red, white, yellow) (red, blue green, white, red)
Make sure the connections are secure into the back of the TV as well as the connection to the back of the Xbox 360.
Jul 18, 2008 | Microsoft Xbox 360 Console
The power button on my 360 puts the one green light on the right instead of the left
I have a very similar problem I had a few days ago. But what I did was I shut down the Xbox 360 console completely. Then I unplugged the power cord from the Xbox 360 console and the wall outlet, and then I disconnected the batteries from the wireless controller. let it sit for about 5 min. Then plugged everything back in, and finally I hit the the wireless connecting buttons on both the Xbox 360 console itself, and the wireless controller(s).
And from then on, I have had no problems, what so ever since I did that (above).
Jan 05, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Wireless Controller Logo
177 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
