Question about Kodak EasyShare C330 Digital Camera
KODAK CAMERA MEMORY INTERNAL WORKS FINE,MEMORY CARD WILL NOT,SHOWS CARD FULL, CAMERA WILL NOT WORK WITH CARD,help,
  • Anonymous Apr 18, 2009
    Brand new memory card installed but camera reads that memory card is full?????
  • emebroid May 11, 2010
    NEED MANUEL ESAYSHARE FOR CAMERA #CW330FOR
    Genius:
  • Kodak Master
  • 1,099 Answers
Please test with a dif. SD card.
Download the firmware:
http://wwwuk.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=7148/7151&product=EKN030243
Pls. bear in mind that this model only supports:
SD/MMC up to 1 Gigabyte
If everything fails.
Kodak Digital Imaging Support Centre can be contacted on any of the numbers below:
UK 0870 243 0270
International Toll line +44 (0) 131 458 6714
Posted on Oct 12, 2009
  • 48 Answers
Some cards have a small lock on the side.make sure its not on.also you should set your pixels lower for more memory and more pictures,also if you used it for awhile you should format it.for emebriod,type in freeware and all what you have above,you should find what your looking for. good luck. hope i helped
Posted on Apr 14, 2009
Internal memory is full i bought a new memory card and it still say the same thing only took 4 pictures help the camera is a kodak easyshare c182
To get the memory card to work, you must first erase the internal memory. Here's how...with no card in the camera, go into the menu and find "format"...follow the on-screen instructions. After that, your new card should work properly.
Aug 06, 2011 | Kodak Easyshare C182 12MP Digital Camera
Getting an internal memory full message on my kodak easyshare c143 camera but it only has 9 pictures on it?
The internal memory is very small. You need to be saving the pictures to a memory card instead. However, Kodak cameras have this nasty habit....once you save a picture to its internal memory, it won't save to a memory card. To make your card work, remove it from the camera...go into the camera menu and find "format"....follow the on-screen instructions to erase the internal memory....insert your card and it should work properly.
Apr 11, 2011 | Cameras
Dear sir i bought kodak easy share M350 3 wks back i opened it today; it shows that memory card cannot store and that internal memory to be used please help
Your memory card is probably full. You need to transfer your photos onto a computer so that you can make space on the memory card.
Feb 28, 2011 | Kodak EasyShare M530 Digital Camera
Hi, got new kodak camera and 4gb memory sd inside. i only took 8 pictures so far and said internal memory full. i dont understand why? i want to keep 8 pictures and it should be plenty as using 4gb and...
4GB "SD" cards are almost always actually SDHC (high capacity) cards. SD and SDHC cards fit the same slots, but they are slightly different electrically. Many cameras won't work with SDHC cards. SDHC is not backwards compatible.
So your camera is not able to use the 4GB card, and is ignoring it and using internal memory only. That memory is tiny and won't hold many pictures, and when it is full, the camera cannot work at all. You need to delete the pics in the internal memory and get a memory card your camera can understand (2GB or less).
Jan 27, 2011 | Kodak Cameras
Brand new camera, unable to take any pictures. Internal memory is full. Even when we put a mmory card in place, still thinks internal memory is full. Why doesn't the camera use the memory stick to save...
If you used the internal memory even once, the memory card will not work until you get rid of whatever is in the internal memory. Do this...with no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory. Then, your card should work properly.
Dec 28, 2010 | Kodak Cameras
CAMERA SAYS INTERNAL MEMORY FULL. I PUT NEW CARD IN. STILL SAYS INTERNAL MEMORY FULL
The internal memory is the memory built into the camera, not the memory you put in with a memory card. This internal memory is rather small. If it is completely full, it will stop your camera working even with an empty memory card.
Take the card out of the camera, and delete some of the photos on the internal memory before you put it back in.
Nov 25, 2010 | Kodak Easyshare C190 12MP Digital Camera...
I am trying to take pictures with my Kodak Easy Share C160. Everything was fine until a message saying "internal memory is full" came on. I have a memory card and have emptied (I thought) the...
When the memory card is in the camera, you see the card contents, not the internal memory. Take the card out, then delete all the photos you can find. The camera needs space on the internal memory to work, even if the memory card is empty.
Nov 22, 2010 | Kodak EasyShare C160 Digital Camera
When I turn my camera on, it shows internal memory is full, but I have not had my camera that long or taken enough pictures for it to be full. Can't get any answers from the booklet that came with it. ...
If you have a memory card in the camera and pictures on the camera's internal memory, the memory card won't work until you get rid of the internal memory's pictures. With no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory. Now your card should work properly.
Oct 31, 2010 | Kodak EasyShare MD41 Digital Camera
My z950 is not reading my memory card. I got it a couple of weeks ago and it was working fine. I took my memory card out to print pictures and when I put it back in, the screen keeps saying internal...
make shore the memory card is out of the camera and reformatte the interal memory and reset the camera ,turn it off and put the memory card back in it should work now.
Aug 29, 2010 | Kodak EasyShare Z950 Digital Camera
MY kodak easyshare c310 wont work
Take the pictures off the camera first and then format the card IN the camera.
Jul 31, 2009 | Kodak EasyShare C310 Digital Camera
Kodak EasyShare C330 Digital Camera Logo
147 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
