Question about Polaroid 7" Internet Tablet Wi-fi & Touch Screen 2gb
My battery completely died a little while ago and I have it charging now, but when I try to boot it back up it gets to the thinking rainbow screen and stalls...Is that just bc I need to wait for it to
Is this bad or do i just need to be patient and let it fully charge since it completely died.
  • Polaroid Master
  • 2,072 Answers
I would let it charge. You may also want to try hard resetting it. Press and hold the power button for about 20 seconds. It should continue to charge.
Posted on Dec 30, 2012
My tablet won't even charge or turn on
it's a factory thing, all You need to do, is open your tab, remove the battery cable for about 10 mins and plug it back again, unplug the screen from the motherboard, and charge it for about, two hours, then plug back the screen connector, and turn it on, if you see it works, turn off the tablet again, and plug in the power cord again, you'll see the charging animation starts, leave it charging for the time you think it's necessary to reach 100%, unplug the cable and turn it on, your tablet is alive, the only problem I've found about this, is that you'll need to turn the tablet completely off whenever you want to charge it, and finally this, VERY IMPORTANT! When your tablet is below 15 or 10% battery, charge it, because if you let the battery die, probably you'll have to do all the steps again.
You need more help give me a call at 1800-204-4427...
Sep 13, 2017 | Tablets & eReaders
After 4 months my Fusion tablet won't turn on??
To help you troubleshoot the issue, please follow the steps given below:
- If your device's battery is almost dead, you'll often see an empty battery indicator on the screen when you try to turn it ON. But if you let the battery completely die, your tablet won't respond at all when you press the Power button.
- To fix this problem, just plug your tablet into a wall charger and let it charge for 15 minutes.
- Now try to power it ON with the Power button, if the problem was caused by a dead battery, it should boot up normally.
- If it doesn't work at all, try plugging the device in with a different cable and charger. The charger or cable could be broken and preventing an otherwise-good device from charging.
- Your device may be powered ON and running but the screen won't turn on because the operating system is frozen and not responding to button presses.
- You'll need to perform a 'Hard Reset', also known as a 'Power Cycle', to fix these types of freezes.
- You'll need to long-press the 'Power button' of the tablet and hold it down for 'Thirty seconds' this will cut the power to your tablet and force it to boot back up, fixing any hard freezes.
Now check if your tablet works fine, if issue persists, please go to your device manufacturer website and see the instructions for performing factory reset or you can contact the manufacturer for further assistance.
GuruAid.com
Jun 02, 2016 | Tablets & eReaders
I need to replace or charge battery. I have back off but red and black wires coming out of battery are soldered. What kind of charger can I use or how do I change the battery?
Can a dead car battery be completely recharged by just ...
https://www.quora.com/Can-a-dead-car-battery-be-completely-rechar... QuoraThere's certainly no harm in charging a battery overnight with an external charger ... abattery is deeply-discharged, doesn't mean it needs to be replaced either.
If my car battery dies and I get a jump, how soon do I need to ...
https://www.quora.com/If-my-car-battery-dies-and-I-get-a-jump-how... QuoraIf your battery is several years old it may need to be replaced. It is also ... If thebattery held a charge after being boosted, you may be okay for now. However, if .
How to change a car battery safely - YouTube? 4:10https://www.youtube.com/watch?v=R5Xa6eMAriQApr 21, 2011 - Uploaded by Ask The Mechanichttp://www.askthemechanic.co.uk/ Help and advice on the best practice to fit a new car battery.5 Ways to Change a Car Battery - wikiHow
Jan 17, 2016 | Tablets & eReaders
If i took a break from my ipad to answer the phone and talked for 5 to 10 minutes, how do i get it to shut down in about 1.5 minutes. it did this before, and now it does not shut down. why?
Set the auto lock for 2 minutes. Keep in mind that the iPad will not auto sleep and lock during certain application evolutions, like video, game application etc.
if it's just sitting at the spring board, it will auto lock at the specified time interval. 993eeec1-2ff2-4698-acad-f9b1e7b2d782.jpg imthemobile guru
Aug 05, 2014 | Apple iPad 32 GB WiFi Tablet PC
Nexus 7 tablet flashing white light
I am very familiar with this problem with the 2nd gens and it is almost always a sure sign that the tablet is not getting enough power to charge up and will not boot. Sometimes this can happen from the tablet not getting used for a while and getting completely drained. The other possibilities are A) the USB charging port is becoming worn out and won't charge or B) the battery is no longer holding a charge, much like a car battery in the winter. Get an original Nexus 7 wall charger and leave it charging through the wall outlet and not a computer, this has more power. If the light is blinking, it makes me think the USB is not the issue, so chances are after an hour or two it will have some life again.
Jun 14, 2014 | ASUS Google Nexus 7 8GB Tablet Unlocked...
How do I solve a boot loop on my supersonic tablet
If you allowed the battery to go dead you will have to remove the back, unplug the battery, then take an old phone charger cut off the plug that goes into the phone, strip back the wires hook them (in the proper polarity) to the battery and plug it in and allow it to charge for a little while, every time my wife runs my battery dead on my Asus Memopad I do this overnight, in the morning plug the battery back into the tablet and you're ready to go. VERY IMPORTANT! get the battery and charger polarity correct, the battery wires are usually red +, Black - I hope this helps you
May 30, 2014 | Supersonic 7" Touch Screen MID Tablet
How to charge a cruz tablet r102
That happened to me about 2 hours ago. What i did was take the back piece of (be very carefull) and blow into the back. Then Plug the charger in and turn on the power put or oush the power button. It takes a little time because you have to keep trying. If the back is hot take the back cover off and blow on it also. If that doesnt work send me another message or a reply!
May 02, 2013 | Velocity Micro Cruz SE R102 Android Reader...
Polaroid 7" Internet Tablet Wi-fi & Touch Screen 2gb Logo
198 people viewed this question
Top Polaroid Tablets & eReaders Experts
John mullen
WTF Chuck.....
WTF Chuck.....
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Polaroid Tablet and eReader Expert? Answer questions, earn points and help others
