Question about Hunter 52" Ceiling Fan With Light And Remote Control
Newly installed Hunter remote will work light and fan if only 2 of the 3 bulbs are installed.
Just installed a new hunter remote in a Hunter fan and light fixture. Both fan and light work by remote as long as only 2 light bulbs are screwed in but does not work if third bulb is installed in the 3 bulb light fixture. All wiring rechecked several times. How do I fix this?
    Genius:
  • Hunter Master
  • 1,617 Answers
Did you install the correct wattage? If you put in 2-60 watt try 3-40 watt instead .
Posted on Jan 24, 2013
  • 122 Answers
SOURCE: My Hunter fan with light
this sounds like the remote in the fan went out the diod will burn out and cause this issue if you go in the fan by the breaker box and see the board you will see a burnt out diod you just need to replace the remote at lowes there about 45dollars good luck
Posted on Aug 04, 2011
Testimonial: "Thanks for taking the time to help me. I did not know where to go to find the part. I'll check Lowe's, as you suggest."
  • 51 Answers
SOURCE: Hunter ceiling fan
Sounds like the remote receiver units (located where the mains connect to the fans) took a surge and have failed.
Posted on Jul 25, 2007
KMusselmann
  • 247 Answers
SOURCE: Hunter ceiling fan type 3 not responding to remote
Sounds like the black wire from the fan is not properly connect(lose)
Here is an example wiring diagram
Posted on Mar 17, 2009
SOURCE: Hunter fan/light with remote installed turns on by itself
Many times this is caused by stray frequencies in the neighborhood. And, sometimes changing the frequencies on the remote and receiver reduce the occurrence.
But it sounds like this may not be the case, here. If not, the receiver in the fan is the culprit and should be replaced. No danger, just annoying.
Posted on May 31, 2009
rtpflh
  • 546 Answers
SOURCE: Installed a Hunter ceiling fan yesterday for a
60 watt bulbs are the maximum recommended,and can be used.if using a remote control, a slight delay is normal,compare it to the delay when turning on a TV.
Posted on Oct 12, 2009
Testimonial: "No remote was used, just a wall switch."
Hunter-ceiling-fan light wont work
Make sure your contact in the socket is touching the bulb.
Mar 27, 2014 | Dryers
Hunter Light transponder fail?
Only way to know if it's the light is to take the remote receiver out and try the pull chain on light after rewiring to house wires.
Jan 03, 2014 | Hunter (25417) Ceiling Fan
Hunter ceiling fan fan is working but lights are not
Make sure light wire is connected at the ceiling & at the bottom. Otherwise it's probably the receiver. 1-888-830-1326 ( Hunter parts )
Jan 05, 2013 | Hunter 52" Ceiling Fan With Light And...
Fan works, light doesn't on Hunter ceiling fan
I would begin by testing each bulb in a different socket somewhere in the house.
Apr 06, 2009 | Hunter 27187 Remote Control
Fan does not work, light does
Your remote uses a slightly different band of IR for one and the other functions; lamp or on/off. This IR lamp or the circuit that controls the IR lamp has failed. You will need a new remote.
Hunter is good about making replacement parts available but as you said this is five years old. You may have to look for an after market seller on Ebay and chances are very good you can find a new one there.
Try Hunter first:
From Hunter Customer Care
Email:
Use Our Contact Form
Phone:
1-888-830-1326.
Monday-Friday 7am-6pm CST
Regards,
Worldvet
Jun 03, 2008 | Hunter 27177 Remote Control
Dryers Logo
313 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
