Question about Intel (8W501B1M3G) CPU Fan, CPU Cooling Kit, Cooling Fan
Intel Cpu Fan ReWiring
I have an Intel Processor Fan that I do not use anymore.
It used to be used for my computer, but now its just lieing around.
I would like to use this fan without a computer.
On the fan it says
E21984-001
DP751H00
DTC-AAUO1
12VDC 0.60A
DELTA
I cut and stripped the fan wiring and it has 4 cables coming out of the fan.
A blue cable. A yellow cable. A green cable. A black cable.
Please help me find out how to wire this into a battery so that I can power it.
    President:
  • 1,901 Answers
Here is the pinout for the wiring:
Pin Name Color 1 GND black 2 +12VDC yellow 3 Sense green 4 Control blue
In case this doesn't show...Black is Ground and Yellow is +12VDC.
Not sure if it will work w/o a Sense (Green) and Control (Blue) line though.
Posted on Jan 18, 2009
Which Replacement Computer Fan is compatible
IF you are using Intel processor then I'll suggest you to go for Original Intel CPU fan and if you are using AMD processor then you go for Original AMD CPU fan
Aug 03, 2012 | Computers & Internet
My Core 2 Duo CPU Fan has got a problem recently. Would any replacement of the Original CPU Fan be harmful to the computer? If there is any such problem, please let me know. Please suggest any CPU...
Try newegg.com, tigerdirect.com,directron.com,geeks.com. You want a Core 2 Duo cpu fan oem (socket LGA 775). Should be able to get one around 10 dollars or so plus shipping. You can pay more for a bigger fan but you really would not need it. OEM will be just fine.
Jan 11, 2011 | Intel Computers & Internet
Overheating intel 915 2.8ghz processor 50degrees
The overheating problem (ie. thermal shutdown) is most likely caused by a faulty CPU fan or dust clogging the CPU fan and heatsink.
Check the BIOS CPU fan speed could be set too low, check the fan speed/temperature setting.
If this problem is not fixed, then the CPU will eventually fail.
Check the fan to see if it spins freely, if not then replace the faulty fan.
If the fan and heatsink are cligged with dust, loosen and remove the dust and use a can of compress air to blow away the dust.
Sep 22, 2010 | Intel Pentium D 915, 2.8 GHz (BX80553915)...
Real time clock failure. Invalid configuration
..plz do check the following as in order:..
the Hardware part:..
3) unplug mains supply..pick open/remove the cmos battery..check (above +3v)..resit..change if required..
6)remove/clean dust neatly..dust is non-uniform in nature n may cause jam/short circuitry/excess resistance n many more..resulting an increase in heat..
7) open the CPU Heat-Sink with fan out of the socket..put some "Heat Sink Compound" (available in local electronics chip level spare market) between the cpu/processor and the CPU Heat Sink *** fan..resit/fit it tightly in position..
8)on main/mother board..see with a debug card for mb error..may bshort..look for defective capacitors(esp above1000mfd)/mosfets..go through the mb's south bridge n the circuit lie around atx connector..the crystal clock generator (if cpu isn't heating up)..
if u r not a professional, always better to seek advise from ur system admin/vendor....
Nov 16, 2009 | Intel Computers & Internet
Old PSU fan lying around.....
Fan voltage must be the same as the one you want to connect it to
Apr 15, 2009 | Intel (8W501B1M3G) CPU Fan, CPU Cooling...
I have 2.6 celeron processor with intel 865 motherboard i am up grade tell us who is processor best
on mb with intel 865 the bigest CPU is pentium 4 @ 3GHz. socket 478
however your MB might require to update microcode for the new CPU.
one more thing: this chipset Intel 865 is obsolete, and intel does not manufacture this cpu type anymore.
Feb 22, 2009 | HP Celeron A , 2.6 GHz (DL458AV) Processor...
Cpu fan
If you're talking about the fan on your processor that is very noisy and you already clean it and still the same
you will need to replace the fan already because sooner or later that fan will not function properly anymore
and it will cause your system some overheating....
Don't forget to rate the solution FIXYA thank you...........
Nov 07, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
My computer won't start but power supply and Motherboard is okay
if i understand correctly you swapped the cpu to another computer and it did not work... you need to purchase or find another cpu that is compatable with your motherboard.
Robert
Aug 25, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Support
pentium 2? the minimum required for xp is around 233mhz. I would recommend atleast 500 mhz for faster useage. and more than 128mb ram.
Jun 06, 2008 | Intel Pentium II slot 1 233Mhz...
Trouble shooting
OC failure = over clocking failure. Make sure the CPU fan is clean, free from dirt & dust. Check CPU fan plug is connected correctly. If the CPU fan still stops after a few seconds replace the CPU fan.
It's harder to find just a fan to fit your heatsink, which sits on your CPU. It is easier to find a new heatsink \ fan combo for your Intel. Use your manual to find what Intel chip is on your board. Use that information & search google for a heatsink & fan combo. Pay close attention to how your current heatsink is mounted to the Gigabyte board.
Mike
Mar 24, 2008 | Computers & Internet
Intel (8W501B1M3G) CPU Fan, CPU Cooling Kit, Cooling Fan Logo
3,982 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
