Question about Vector Black And Decker High Frequency Automatic Battery Charger
Vec1088AF when hooked up correctly charges not even five seconds then kicks off
No code comes up on the charger - just 0.0
2 Suggested Answers
  • 35 Answers
SOURCE: hi , i am in
Any auto parts store should have what you need.
Posted on Feb 04, 2011
Though my Worx WG781 cordless 36V, 19 inch lawn mower came with what appeared to be a fully charged battery according to the battery LED lights , it is suggested that it be put on the charger "over...
Could be.Those batteries leak charge even when not in use.I would let it go for 24-48 hours just to be sure.Unless the batteries or charger becomes very hot.
May 20, 2011 | Worx WG788 19Inch 36 Volt Cordless 3In1...
Even if i connected the charger its not charging
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Jan 03, 2011 | Nokia 7610
I have an ION Tailgater which doesn't seem to be charging. The unit power doesn't have to be on whilst charging, but approximately five seconds after plugging in to charge, the charge light goes out, and...
I just bought four units, 2 of them work fine but the other two have problem, but one of the unit did get charged up even without the charger light on. I switch on the unit, leave it plug in for a few days and the unit come back charged. I try with the other one, but it is not working.
Dec 20, 2010 | ION Audio Tailgater Portable PA System...
Wont charge
the batteries have failed or the fuse in the charger
ted
Apr 15, 2010 | Pride Mobility Products Hurricane PMV...
My magellen 3100 battery will not charge
its probably not charging...very common problem with this and many others.
make sure green light is on the car charger and let it plugged in for awhile, then hold the power button (upto ten seconds) until it starts..if that fails
the following magellan 2000,2200t,2500,3000,3100,3140,4000,4040,4050 and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...
you can get it repaired, here
or buy the port here
if you need further help, just let me know.
Oct 09, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
First charger flashes red for five seconds, then the charger flashes green. I put battery in circular saw and it runs for about thirty seconds and somewhat quickly dies out. this is after being on the...
When it is brand new only. If charged overnight and still does not last take back to purchase place and have them test battery..then make them replace it if it is bad...:)
Sep 07, 2009 | Ryobi Two 18V Lithium-Ion Batteries +...
Our tomtom one 3rd edition stopped working it will not switch on or charge up even th ough green light comes on charger when plugged into car
try resetting it, but first put it on the charger for a few hours to make sure its charged. using a paper clip or something similar, depress and hold the reset button located on the bottom of the unit for 15 seconds, then hold the power button for up to 5 seconds till the unit starts.
if that fails, hook your tomtom to your computer and run tomtom home and see if that will update or repair it.
tomtom
let me know if you need further help.
bill
Aug 26, 2009 | GPS
My Dell 1501 laptop turns off as soon as the charger is connected
Sounds like you have a multiple problem going on here honestly. If you have a constant light on your charger even when its completely disconnected from the wall outlet then your charger is bad for sure, cause the light shouldn't come on unless the charger is hooked up to power.
Your battery maybe shorting out the laptop which is why it needs to be taken out for a bit before the laptop will turn on.
My suggestion would be to try a known good working charger on your laptop to make sure it turns on properly and stays on without the battery hooked up.
Then if your laptop stays on for a while then with the laptop on and the charger hooked up, connect the battery again and see if the laptop will charge up the battery to 100%. If it does then disconnect the charger and see if the laptop stays on with just the battery hooked up. It could be that the battery is drained beyond 0% and just needs a good charging. If you can't charge up the battery or the laptop still turns off to where you have to take out the battery to get the laptop to turn on then the battery is bad and would have to be replaced.
Jun 02, 2009 | Dell Inspiron 1501 Notebook
I have an hp pavilion dv9350ea. Over a couple of years the battery became defective and I installed a new one. It showed 30% charge. I disconnected the charger to discharge the battery before re-charging...
I have to agree that the battery is defective or maybe it is NOT the correct one for your system, although it may be similar.
Did you buy the battery direct from HP a third party?
The AC adapter charger could be defective as well, maybe the defective battery ruined the charger.
I hope this helps.
Good Luck.
Mar 10, 2009 | HP Pavilion dv9000z Notebook
Vector Black And Decker High Frequency Automatic Battery Charger Logo
Top Vector Tools & Hardware - Others Experts
Are you a Vector Tool and Hardware - Other Expert? Answer questions, earn points and help others
