Question about GE DPSR483EA Electric Dryer
GE PRofile DPSR475EWOWW
Dryer is Squealing when in operation. I have removed back access panel and inspected the belt and tensioner pulley. Both look fine and tensioner pulley moves easily by hand. Added a small dab of grease to the shaft at the pulley just incase. Did not solve squealing problem... Please any suggestions on where to look next!?!? Also, can you please tell me what is the best way to get the entire back panel off. Took all the screws out but panel would not come off! Thanks in advance for you help! Don
  • Don Sanderson Jun 23, 2007
    Thanks, Catriver!
    I'll give that a shot and let you know how it goes!
    poorman1
    President:
  • 878 Answers
Don, the drum on this model rotates on a bearing in back. This is most likely where the sqeeling is comming from. You will have to service this from the front. Should be 2 screws just above the door on each side. Remove them and the top will lift up. Slide the top off forward. Once the top is off, you will see a couple of screws holding the the front panel and door assy. on. One on each side inside front panel. Unplug the door harness and remove the front panel and door. Undo the belt and the drum should pull straight out. Watch out not to get the belt hung on the motor. Now you will see the rear bearing and shaft bracket that the drum rides on. It may need to be replaced or just lubed up real good. Catriver.
Posted on Jun 23, 2007
This soulution is very easy and solves the problem. Don't be afraid because it says bearing. It is no ball bearing but a nylon bushing inserted in a hole and the drum axle fits in the bushing. I put some dry lubricant on the drum axle after shining it up with a fine steel wool. The fix really impressed my wife as she had visions of needing to spend money on a new dryer. Excellant advice "catriver".
Posted on Jun 27, 2008
SOURCE:
How do I stop dryer from squealing
the squealing noise is most likely a loose drive belt , the drum is powered by a large belt to a motor , the belt and idler pulley are most likeslyin need of replacement
Dec 11, 2014 | Dryers
Can you give me information on how to replace the belt in the dryer.
From back of dryer remove access door to disconnect belt from motor & tensioner.(remember how belt was placed on tensioner & motor pulley) You must remove dryer front panel ( look for 2 screws at bottom of front panel) Pull out from botton of front panel to remove, exposing drum end retainer brackets, remove brackets, allowing access to drum. Slide old belt off & new one on.
Feb 13, 2011 | Dryers
How do you get the belt tensioner pulley off
Thank you for contacting Fixya.com.
Pull your dryer out from the wall. Behind it, on the bottom, you will find a lower panel that will give you access to the unit's belt tensioner (also known as an idler pulley arm). Remove the screws holding this panel in place, and then remove the panel itself. Reach inside and release the belt tension by removing the belt from the motor pinion.
Please check this bellow link if it helps:-
http://www.wikihow.com/Change-a-Clothes-Dryer-Belt
Please get back to us if you have any further query.
Nov 29, 2010 | GE Dryers
Have an old Amana dryer Model # LE3402w - hasn't been used in a while. Heats up great but makes a awful loud noise while on. What can be the problem
The belt tensioner pulleys bearing is dried up squealing while turning. My advice is to replace the belt & the pulley on the tensioner
The top and front panel will have to be removed to access these parts
Jul 16, 2010 | Amana Dryers
Maytag electric dryer is making a high pitched noise
The squealing noise is from the belt tensioner. Replace the pulley only on the tensioner along with a new belt. The bearing in the pulley is causing the squeal. Sears will sell this in a kit. The top and the front panel of the dryer will have to be removed to replace these parts
Jul 16, 2010 | Maytag Dryers
I have a Kenmore Stacked washer/dryer that was given to me. The dryer has a pretty loud sqweek. Is this normal?
A loud squeek is normally caused by the tension pully or the rear drum rollers seizing. Remove the two screws holding the inspection panel between the washer and the dryer. Remove the panel. Slide a 1/2 inch paint scraper between the top and the cabnet front and releave the spring loaded clips that hold the top on and remove the top. Loosen the two screws at the bottom of the dryer front panel. Looking down inside the front panel remove the two screws holding the front panel to the cabnet. Mark and remove the wires going to the door switch and remove the front panel. At the rear of the dryer remove the inspection plate at the bottom of the dryer and remove the belt from the spring loaded tension pulley. Go the the front of the dryer and remove the dryer drum and belt. Now you can check to see if the rollers are worn or seized and check to see if the tension pulley is seized.
Purches a kit that includes a new belt, drum rollers and tension pulley and replace all. Reassemble the dryer in the reverse as to how you took it apart.
Jan 30, 2010 | Washing Machines
Maytag neptune dryer makes a loud squeaking noise
This noise will normally come from a defective idler pulley. Access to the idler pulley varies by model, if your dryer has a lower front panel (kick plate) start there. It should lift up and off or it may be held in place with a few screws or snaps; it may also have a catch at the edges or center gap between the kick panel and main panel. To release the catch, push a putty knife, wrapped with masking tape, into the gap and push back the catch. The next easiest access point is the rear panel. The rear access panel is held in place with several screws along the outer edges. The last resort method of access is the removal of the entire front panel. The front panel supports the front of the drum and so removal is more difficult. Front panel removal varies. In general, access is gained by lifting the top (remove the lint trap screws first), removing the screws that secure the front panel, and detaching the panel from the drum.
When reaching into the dryer be careful of sharp edges on the cabinet and interior supports. Reach in to the belt and give it tug. It should be taught and have only a little give. The belt should go under the idler pulley and over the motor pulley. Lift the idler pulley toward the motor to relieve tension on the belt and remove it from the motor pulley.
Turn the idler pulley wheel, it should turn smoothly, quietly and without any wobble. Inspect it for cracks or uneven wear. If the idler pulley does not maintain proper tension or is damaged it should be replaced. Depending upon your model, the entire assembly or just the wheel or bearing may be replaced. Check the bearings as well for excessive clearance also(roller bearings)
Sep 29, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Squealing noise when running
HI, Most squeaky noise will come form the idler pulley. it may have excessive bearing clearances or , the pulley may just be damaged. i recommend inspecting it.
When reaching into the dryer be careful of sharp edges on the cabinet and interior supports. Reach in to the belt and give it tug. It should be firm and tight, and have only a little give. The belt should go under the idler pulley and over the motor pulley. Lift the idler pulley toward the motor to relieve tension on the belt and remove it from the motor pulley.
Aug 05, 2009 | Whirlpool LGR5636L Gas Dryer
Squealing dryer
Most dryers have a vented access panel on the back on the bottom that is held in place by a couple of screws so you can get to the motor & pully assy. Check to see if the grease has dried up on either the iddler pulley or drive pulley. If needed, push down on the iddler to release pressure on the belt and give the pulleys a spin. If they seem fine then it will be the belt or possibly an overloading problem.
Jul 09, 2009 | Kenmore 98702 Stacked Washer/Dryer
Dryer wont spen
The dryer only has the 1 belt that drives the drum. Shock Hazard Warning! Remove the dryer from its power source before accessing internal components.
Look for an obstruction in the blower which is attached to the front of the motor. Look for a foreign object stuck between the drum and bulkheads. Inspect for a broken belt. Inspect all drum rollers for free operation. Inspect idler pulley on rear of motor for free rotation with belt removed. Inspect drive pulley on rear of motor. All this can be done through the front of the dryer by removing the front panel enclosure.
Hope this helps!
May 26, 2008 | Roper RES7646KQ Electric Dryer
GE DPSR483EA Electric Dryer Logo
1,014 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
vince
gbob59
Are you a GE Dryer Expert? Answer questions, earn points and help others
