Question about DISH Network IR Remote Control
I can't find a code for my BOSE Solo on the Dish network Hopper remote. Can anyone help?
Don't go and search for IR codes as you'll waste your time. Use the learning method. Take your bose remote and put it on a flat surface and point it toward the little square receiver on the dish remote (located on the top left side). Then press the "aux" mode button on the dish remote until all the mode buttons light up and the aux mode light starts to blink. Then press the record button on the dish remote for 3 seconds until the aux mode button lights up and stays lit (it then stays lit during the whole learning program). On the dish remote press the button you want to learn but don't hold it down (I started with the up volume) . Then press the corresponding button on the bose remote but hold that down until the aux mode button blinks once and comes back on (if the mode button blinks three times the dish remote did not learn the command and you should try changing the batteries on the dish remote if it happens repeatedly that it fails to learn). Program the remaining commands by repeating the process of pressing a button on the remote, then pressing and holding the corresponding button on the bose remote. Don't be afraid to do it with the mute and the power buttons too. During this process if you don't press a button for more than 30 seconds it will time out and nothing will be recorded and you will need to start again. To end the programming press the aux mode button. When you are using the bose solo using the dish remote you just need to remember to press the aux mode button first so it flips to command the bose solo.
Posted on Mar 16, 2013
  • Peggy Mar 17, 2013
    thanks, this helps
I recently got a replacement Dish 21.1 remote replacing a Dish 21.0 and could not get my Bose Lifestyle Model 5 volume to work. I could get all the functions except the sound putting in all the codes per Dish Tuner/Amplifier download. I found an extra Dish 21.0 remote put in my previous codes and it works! Is there something wrong with the new upgrade remote?
Posted on Feb 18, 2015
ward_knutson
  • 64 Answers
SOURCE: dish network remote with a element tv
Since you dont have a popular brand set you should try using the scan method. Here is a link with a video to help program your dishnetwork remote to work with your set. http://www.disheez.com/videos/dish-network-video/programming-dish-network-remote/
Posted on Nov 25, 2008
  • 374 Answers
SOURCE: new dish network remote not working
The 6.3 remote has a blue number two key tab on it when it is shipped from the warehouse. If you remove the battery lid you will be able to remove the tab by pulling it out.You will need the other keys that should have come with the remote and use the black colored uhf key and insert it into the remote and put battery cover back on. Ensure the UHF antenna on the back of the receiver is tight and in the upright position. Now turn the TV on and using the buttons on the receiver press menu twice. This should bring you to the system info screen. There will be a remote address toward the bottom of the screen and usually this number is 1. Now take the new remote and press and hold the clear SAT button on top until all the lights across the top illuminate. Now release and key in 01 and press the pound key. The SAT button should flash three times. Press the record button and noe try to navigate the highlight to the done or cancel option using the left and right key. You should now have control of the receiver if not the antenna port which receives the commands could be faulty. If you were successful with the remote remember you will also need to program it to the TV itself to enable you to turn the TV on and off and control the volume with the remote. The FINAL issue that may be causing your issue is that the part number you gave does not match a 6.3 remote. A 6.0 WILL NOT WORK WITH THE 510 EVEN IF YOU DO ALL OF THE ABOVE as I tried it the other night to verify the accuracy of information that is put out internally. I hope this resolves your issue and if you need help programming the remote to the TV itself please let me know. Thanks for using Fix Ya.
Posted on Jan 07, 2009
  • 374 Answers
SOURCE: How can I get my Dish Network remote to control my surround sound
If there are no codes in the manual then you may have two options left for you. You may order a 20 or 21 remote from Dish after verifying it will work with your system with customer service or you may get an ALL IN ONE REMOTE. Thanks for using Fix Ya and let me know if you need further assistance.
Posted on Jan 16, 2009
  • 336 Answers
SOURCE: dish network remote stopped working for on and off and volume
First before trying to repair the remote lets try to just reprogram it. The easiest way to do this is to do a search. 1st Turn the tv on, then on the remote press and hold the tv button until it flashes. Next press the tv power button. Next press the up arrow button slowly until the tv turns off. Then hit the # key. Now if you pressed the up arrow to many times and the tv doesn't respond to the remote just start the process over, except using the up arrow use the down. You may have to push the up arrow button many times before it finds the code. The batteries usually last quite a while since there are 4 of them. If this doesn't work call 1-800-333-dish they will either send out a tech or just mail you a new one. If you have the user guide for the 722 the instructions to do this are on page 82.
Posted on Sep 16, 2009
  • 54 Answers
SOURCE: need remote control code so we can use 2 remotes
All manuals for remotes are on the internet.
Posted on Jul 14, 2011
Tip
DISH VIP612 Program AUX Remote Code
DISH Solo DVR VIP612 Program AUX Remote Code
Would you like to program the Universal Remote that came with your Dish Solo DVR VIP 612 to control your receiver, tuner, stereo, second TV or second VCR using your remote's AUX mode? (Instructions to setup a primary TV or a VCR are a little different, but can be found here.)
To setup your Dish Solo DVR VIP 612 Universal Remote, follow these steps to enter the remote control codes to control a device with the AUX mode:
  1. Turn the device you would like to control on.
  2. Find the brand name of the device you would like to control in the control code tables on page 112 of the Dish Solo DVR VIP 612 User Manual.
  3. Press and hold the AUX mode button until all the other buttons light up, and then let go. The AUX mode button will flash.
  4. Press 0 for a TV, 1 for a VCR, or 2 for a receiver, amplifier or tuner.
  5. Enter one of the three-digit codes from the tables in the manual.
  6. Press POUND (#). The mode button will flash three times.
  7. Press POWER to turn off the device. If the device does not turn off, skip to step 9.
  8. Turn the device back on and try some of the other buttons to make sure they work. If the code works, stop here.
  9. If the code didn't work, repeat steps 3 through 7 with the next device code from the tables in the manual.
Your device control codes for your amplifier or other AUX device are now programmed into your DISH Solo DVR ViP 612.
Now you probably want to set your Dish Solo DVR VIP 612 Universal Remote up so that it always controls the volume of your stereo, rather than of your TV, regardless of whether it is in SAT, TV, VCR or AUX mode. Help for this remote control programming can be found here.
(Help for programming a TV or VCR using the TV or VCR mode buttons can be found here.)
I hope that helps.
________________________________________________________________
DISH Solo DVR VIP612 Manual Download
DISH Solo DVR VIP612 Quick Reference Download
DISH Solo DVR VIP612 Remote Code Scan
DISH Solo DVR VIP612 Program TV VCR Remote Codes
DISH Solo DVR VIP612 Program AUX (Stereo/Receiver) Remote Codes
DISH Solo DVR VIP612 Amplifier Control
DISH Solo DVR VIP612 What Is Limited Mode
DISH Solo DVR VIP612 Change Limited Mode
on Jul 05, 2010 | DISH Network ViP 612
Tip
Changing DISH Solo DVR VIP612 Limited Mode
What is DISH Solo DVR VIP 612 Limited Mode?
To turn Limited Mode on or off, follow these steps:
  1. Press and hold the correct mode button (for example, TV) until all of the mode buttons light up.
  2. Release the mode button.
  3. Press PAGE UP to turn Limited Mode on, or PAGE DOWN to turn Limited Mode off.
  4. Press POUND (#).
Note: Limited Mode is not used with amplifiers (AUX mode).
I hope that helps.
I want to program Bose Solo 15 to my dish hopper with sling remote
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window, and press enter to get all related posts. It will make surf easy.
Jan 11, 2015 | DISH Network 40.0 Remote Control for...
Dish code for bose solo
065,029,018,028,000 are the codes to check. It you wish to get more setup codes to dish, check this link.
Mar 08, 2013 | Bose Solo TV sound system - Black
Tip
DISH Solo DVR VIP612 Limited Mode What is DISH Solo DVR VIP 612 Limited Mode?...
You can program your remote control in Limited Mode to keep from accidentally changing the channel on your TV or VCR and causing a snowy or blue screen.
  • When the remote control is in Limited Mode for TV mode, you will only be able to use POWER, MUTE, and VOLUME functions for your TV.
  • When the remote control is in Limited Mode for VCR mode, you will only be able to use POWER and the VCR functions for your VCR.
I hope that helps.
Tip
DISH Solo VIP612 DVR Quick Reference Download
Download DISH Solo VIP612 DVR Quick Reference Guide
Would you like to review the features of the DISH Solo DVR VIP612?
Have you lost your DISH Solo DVR VIP 612 Quick Reference Manual?
Would you like a digital, searchable, pdf version of the DISH Solo DVR VIP 612 Quick Reference Guide?
Follow this link (& click FREE) to download a pdf version of the DISH Solo DVR VIP 612 Quick Reference documentation.
I hope that helps.
on Jul 04, 2010 | DISH Network ViP 612
3mc0sk1,
I can definitely provide assistance with this! Our Hopper receive uses a special function to program the remote for you.
Go to Menu > Settings > Remote Manager. Select the option, 'TV Code', 'DVD Code', or 'AUX Code', based on the type of equipment you are programming. Once selected, follow the prompts on screen and it will automatically scan for codes!
Let me know if you have any other questions.
Tommy Faust
DISH Social Media Representative
Dec 30, 2012 | DISH Network IR Remote Control
We just got a new Dish HD/DVR Receiver and need the remote code for the Bose remote control to operate it.
Here is what I did for my Bose Solo Tv to work on the Bell 9242 receiver.( see page 17 of Bell 9242 guide) 1. Hold down the aux button until all lights flash. 2. Press 2 to ensure Aux is set to audio. 3.Enter code 761 and press the pound (#) button. Now to have the satellite remote default volume to Bose Solo do the following. 1.Press and hold AUX 2.press # pound 3. Press the + side of volume 4. Press 0 5. Press pound ( AUX button will flash 3 times) 6. Press SAT mode 7. Test the volume on Bose Solo. (see page 22 of Bell 9242 guide)
Jul 05, 2010 | Bose 3 2 1 GSX System
Tip
DISH Solo VIP612 DVR Manual Download
Download DISH Solo DVR VIP612 Manual
Would you like to review the features of the DISH Solo DVR VIP612 ?
Have you lost your DISH Solo DVR VIP 612 Owners Manual?
Would you like a digital, searchable, pdf version of the DISH Solo DVR VIP612 Users Guide?
Follow this link (& click FREE) to download a pdf version of the DISH Solo VIP DVR 612 documentation.
I hope that helps.
____________________________________________________________________
DISH Network IR Remote Control Logo
2,295 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
