Question about Electrolux EIFLS55IIW - Front Load Washer with IQ-Touch Controls Featu
Electrolux no water draining error
Sometimes the washer will run with no problems other times it will be most of the way thru the wash when it beeps and displays "no water draining" message. I have to restart the whole wash over again until it washes all the way through. I have checked all the water hoses and even had the drain hose outside to make sure it wasnt plugged and it still did the same thing. Any other suggestions?
3 Suggested Answers
taran_2005
  • 10515 Answers
SOURCE: electrolux washing machine model #
E31 indicates a fault in the pressure switch, the wiring from the switch to the main control board or the main control board itself.
This can happen if water gets into the switch.
Turn the machine off.
Hold the same buttons as before and while holding them, turn the dial 1 notch clockwise.
The leds will flash, let go of the buttons and the leds will scroll.
Turn the knob 1 more click clockwise.
It should start filling.
Watch it, if it's overfilling (more than 3/4 the way up the door), turn the machine off.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jun 06, 2011
hattonhall
  • 349 Answers
SOURCE: My Electrolux Washing machine wont
There may be a hidden blockage. Try putting a garden hose into the outlet pipe, tightly gripping the joining point of the hoses and turning on the water briefly. This can sometimes clear things.
Check also that when the machine is set to the "Drain" position that you can hear the whirr of the drain pump motor. If you can, then the electrics are intact and the pump impelllor inside the pump may have come loose on its shaft or be jammed with a small foreign object. It would be necessary then to remove the pump and dismantle it, or just replace it with a new one.
As always I warn non-technical people to beware of attempting repairs. Not because they may not be mechanically apt...........it is more about them not being used to the Strict Self Safety Disciplines that experienced servicing personnel have in place that protect them from possible injury or even electrocution.
It is simply not worth risking life and limb by trying to avoid the cost of a professional service call after all a life is surely worth much more than that.
Importantly ALWAYS unplug any appliance from the power point before doing anything !!
Posted on Jun 29, 2011
How do I fix error code E21 on Electrolux Front loader washing machine?
It is the customer fault code. Simply turn on and turn off appliance.
E11 - problem with fill water
E21 - problem with draining water
E41 - door open
All other errors require service staff !!!
Sep 13, 2014 | Electrolux Washing Machines
Washing machine beeps, doesn't run
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
Jan 08, 2014 | Kenmore HE2 Plus Front Load Washer
My Electrolux front load washer does not fill with water in the rise cycle and beeps and displays "draining, no water"
If this is a brand new product, I suggest that you MUST call for warranty assistance from their depot.
This can be related to failure or error of the controller, fault in the inlet or water level sensor which must be done free of cost.
Feb 12, 2013 | Electrolux EIFLW50LIW 4.2 Cu. Ft. Front...
Problem with electrolux washing machine
draining pipe its too low. check this link:
http://applianceguru.com/washers/drain-min.jpg
Aug 26, 2012 | Electrolux Washing Machines
Kenmore elite beeps all the time
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
4 Beeps/E40--Error: Door is open. Cause: Washer will not operate if door is open. Close door.
5 Beeps/E50--Error: Motor is overheated. Cause: Wait 30 minutes to cool down. Restart.
7 Beeps/E70--Error: Cold water doesn't enter. Cause: Hoses crossed,faucet problem.
15 Beeps/EF0--Error: Oversudsing. Cause: Too much detergent,or improper detergent for machine.
15 Beeps/EF0--Error: Hot water doesn't enter. Cause: Hoses crossed,faucet problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 05, 2009 | Kenmore Elite 45986 Front Load Washer
Washer doesn't run all the way thru cycles. It's
Removed hose connecting to water pump at tub. Removed clog (ink pen, coins, etc). Replaced and ran washer. Ran through all cycles - no leaking, no pausing of cycles. Problem is resolved.
Oct 01, 2009 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
I am having problems with an electrolux 12680 W. PNC 914522501 2007 production yr. It was making a strange sound and not pumping out water. No problem, I removed the front plug and cleaned out around the...
the hose coming from tub to the pump has a filter in it.you need to pull filter out and empty it.E20 means that you have a slow drain,or clog.If the pump is noisier than ussual then you may need to replace pump.but check filter first.
Apr 20, 2009 | Electrolux EW1000i Front Load Washer
I can't change the default wash cycle without it switching
Jan 28, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Electrolux EWF 1087 error code E60
My Electrolux washer always come up with an error code of E60, Why? can any one help
Mar 07, 2008 | Electrolux EW1200i Front Load Washer /...
Electrolux EIFLS55IIW - Front Load Washer with IQ-Touch Controls Featu Logo
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
