Question about Krups XP7230 Compact Super Automatic Espresso Machine
Water leaking under a krups model number 8250
4 Suggested Answers
  • 22 Answers
SOURCE: Krups model KM7005 water wont heat
Mine had the same problem ... all the lights are on, but no heating on the plate, and no dripping of water.
After a weekend on the workbench, I've mastered this machine. The KM7005 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. I'll be happy to advise you to fix this, or fix it for you. Write me at KM7005@flightsystems.biz.
Posted on Jan 31, 2010
espressonist
  • 1711 Answers
SOURCE: krups xp 4050 leaks water under unit
There are many possible points that the leak can be.
All points of the water supply from water tank to the pressure pump then to boiler and finally to coffee group. All this are connected together with plastic or Teflon pipes with easy fit unions secure with clips
You need to disassemble the machine and work it without the side panels of course with extra care since power electrical cables are exposed.
In this way with a very good visual check while the machine is in operation you can identify the leaking point and fix it.
Posted on Sep 27, 2010
SOURCE: krups kp 2000 water leak
I had the same thing happen. It turned out that the rubber hose connecting the water reservoir to the heating element had disconnected, probably due to grinding vibration. I found a triangular screw driver to open the coffee maker up at MicroCenter: http://www.microcenter.com/single_product_results.phtml?product_id=0332974
After removing the bottom of the coffee maker, the repair took 1 minute and it is brewing coffee again like new!
Posted on Feb 02, 2011
I have a krups 12 cup coffee maker that leaks when I pour water into the resevoir. How can I fix this?
Probably providing more info that includes the model number will help someone to help you. Have you any idea how many coffeemaker models Krups have made?
Jul 16, 2017 | Krups Coffee Makers & Espresso Machines
Filling machine necessary press ok'. HOW KAN I FIX THIS PROBLEM
The magnetic float in the water tank is probably not floating, jam something plastic between the float and tank bottom or buy a new tank.
Apr 29, 2016 | Krups Coffee Makers & Espresso Machines
How to change the seal on the outside bottom of the krups water tank model 905? It leaks badly. Or should i buy a new tank.? But thay are hard to find.
If your full model number is F9054 then Part number for the seal is F909378. It is not part of the tank, there is just a spring loaded stopper valve in the tank. The tank seal for when the tank is in place is in the socket the tank plugs into. You need to remove the top of the socket to expose and change the seal. If you want to mess about you can hook out the old seal without removing the seal cover but it is very difficult getting the new one in properly this way.
Dec 06, 2014 | Krups Coffee Makers & Espresso Machines
Leaking from under the machine
Descaling will not fix a leak. If you want proper help you really need to identify the product you have by model number.
Jan 16, 2014 | Krups XP Coffee Makers & Espresso Machines
Krups ea 8250
If it doesn't grind , than there is no coffe , it will surely come as water .
Grind it first , and than brew the coffe .
Oct 24, 2013 | Coffee Makers & Espresso Machines
How do I increase water temperature on Krups KP 2100
Heat the cup before you use it, run hot water over it, or boiling water. The machine does not make very hot coffee otherwise.
Sep 22, 2012 | Krups Dolce Gusto KP 2100 Espresso Machine
Krups xp 4050 leaks water under unit when sitting on counter
Jun 13, 2010 | Krups Small Appliances Espresso Machine
KRUPS XP7240 leaking water
My XP7240 has the same problem. I went through all cleaning cycles and the filter in the boiler still gets clogged up with coffee oils. This causes back pressure and blows the boiler seal out. Easy replacement if you can turn a screw driver.
Part number for Seal: MS-5015004. You might as well change the Jack too. (the part that slides into the boiler that compresses the ground coffee. (this is a redesigned double seal unit) Part Number MS-0697072.
Both these parts you can get at http://www.krups.com/Tools/Contact/Contact.htm choose your country and email the parts list. Mine cost in Australia $27.00 including shipping.
Good luck.
May 31, 2010 | Krups Small Appliances Espresso Machine
Krups type 889 Espresso machine leaks water
I have found the two parts mentioned in my previous Email on a webpage other than yours, however I have not ordered the parts at this time. If you have the parts in stock, let me know the price.
Once I receive the parts and replace them, I will know for sure if my troubleshooting is correct.
Dec 21, 2009 | Krups Orchestro 889 Espresso Machine
Leaking from the water Chamber
The Krups heats the water through a horseshoe shaped aluminum tube which the heating element is wrapped around the tube in the same fashion, the tube is corroded or cracked most likely, if you poured cold water into the machine when it was hot, this will crack the tube, they are made by Cesod ? which is stamped on the element with a number on it,  and I have seen between 700 and 1100 watt elements. I have the same problem with my 7 year old krups coffee maker, Im trying to repair the tube with aluminum welding or find a new element.  It could also be the high temp tubing may be cracked.  You need tamper proof Torx bits to remove the bottom cover on some models.
Jan 21, 2008 | Krups Caffe Bistro 867 Espresso & Coffee...
Krups XP7230 Compact Super Automatic Espresso Machine Logo
51 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
