Question about Cell Phones
Cherry mobile c2 speaker not working
Cannot get speaker when on phone call. No volume when ringing. Have tried various profile settings but no luck.
2 Suggested Answers
  • 158 Answers
SOURCE: can't get speaker volume or audible ringtone
sir
dismantle your phone and clean the contacts of the speaker and buzzer or replace them... it will solve your problem
Posted on Feb 04, 2009
My phone is not ringing when I get incoming calls, beeping when I get txts, and it won't go on loud speaker. The volume is high. Its set to normal profile, with ringing volume high. Please advise.
Some how your phone was reset or had the tone turned off. Just follow the below guide and your audio should come back on. I would do a soft reset (turn off the handset, remove the battery then reinsert) before performing the instructions.
Tone settings
To select a ringing tone for voice calls, select Tones >
Ringing tone.
To select a ringing tone for video calls, select Tones > Video
call tone.
To set the ringing type, select Tones > Ringing type. You
can also set the device to sound a ringing tone that is a
combination of the spoken name of the caller and the
selected ringing tone, when someone from your contacts list
calls you. Select Tones > Say caller's name.
To set the volume level of the ringing tone, select Tones >
Ringing volume.
To set the various alert tones, select Tones > Message alert
tone, E-mail alert tone, Calendar alarm tone, or Clock
alarm tone.
To set the device to vibrate when you receive a call, select
Tones > Vibrating alert.
To set the volume level of the device keypad tones, select
Tones > Keypad tones.
I have included a link to download your user manual if needed, it comes as a PDF file so you need to have adobe PDF down loader
http://nds1.nokia.com/phones/files/guides/Nokia_E63-1_UG_en.pdf
Apr 23, 2011 | Nokia E63 Cell Phone
Tip
Phone is not ringing
Please try the following troubleshooting tips:
  • Ensure that you phone is on and that there is sufficient signal strength.
    • Signal strength is indicated by the signal indicators at the left side of the phone's display,
    • These indicators move up as the strength of the signal increases and down as the signal decreases.
    • To increase your phone's signal strength, try moving your phone slightly, or move towards a window if you're calling from inside a building.
  • For some phone models, if there is a headset attached to the phone, it will not ring through the speaker, only through the headset. Detach the headset and retest the phone to determine if that resolves the issue.
  • If the phone's profile is set as "Silent", "Flight", "Online", or any other profile where ringing is silenced, it will not ring. Change the profile to the "General" or "Normal" profile and retest. Instructions for checking and changing your profile are included in your user guide.
  • Ensure that a ring tone has been enabled and the volume is not too low. Instructions for adjusting volume and selecting a ring tone are included in your user guide.
  • If call divert is activated, your calls may be going straight to voice mail without your phone ringing. Instructions for activating and inactivating call divert are included in your user guide. For assistance with voice mail, please contact your operator or service provider.
on Sep 13, 2010 | Cell Phones
How to increase my nokia 5230 ringing volume?
try this steps
go to menu > settings > personal > profiles > {tap on profile you want to increase volume} > personalise > {select Ringing volume and set Ringing type - Ringing}
Feb 25, 2011 | Nokia 5230 Cell Phone
Where is the ringtone volume adjustment for the Nokia N73? Thanks
Hello !
Look in Profiles -General - Options - Personalise - Ringing volume.
You will have to set the volume and Ringing tone for every profile ( General,Meeting,Outdoor.... ).
You can find Profiles in Menu - Tools - Profiles.
Good luck !
Nov 18, 2010 | Nokia N73 Cellular Phone
Speeker volume sir
Hello loverman911
There are many factors that affects on the speaker volume.
One of them is, you are using silent profile rather than general mode.
You also need to keep in mid that you can not hear sound on speaker when you plugged the earphone.
You can also try to reset the factory setting of your mobile as this may solve the volume problem of your mobile.
or
You can plug head phones in the the input jack, play media turn the volume up and pull out the headphones while media is playing.
It work for me and hopefully it will work for you.
If your mobile is under warranty period, then try to replace this faulty Motorola mobile phone that is having speaker problem.
Take care.
Sep 16, 2010 | Motorola Mobility C118 Cellular Phone
How do i put phone on silent
User profiles
This is used to set up the different ways of incoming call prompts in various situations. Use
the up/down key to choose this option and click the left functional key to enter. There are
many modes of setting available and the default setting is the general mode.
To switch to a new user profile, use the direction key to select the target mode and click
“OK” to enter. Then select “activate” and click “OK” to confirm. Your phone will give an
“activated” prompt, indicating that the user profile is active. The “headset” mode does not
require activation; your phone will automatically switch to the “headset” mode if a headset
is connected to your phone, and back to the previous mode when unplugged.
You can also customize each user profile setting for your preference, the following
operations are available:
(1) Ring tone settings:
Incoming calls: Enter “user profile”, select “personal setting”, and set up the ring tone.
Power on: set up the music for power on.
Power off: set up the music for power off.
Message: set up the message ring tone when a new message arrives.
You can also download ring tones online.
(2) Volume
This allows you to set up the volume for ring tones and keypad tones. There are 7 grades
available. Enter this function and use the up/down key for testing and adjusting.
(3) Alert type
This is used to set up the alert type for incoming calls. Please select the suitable alert
types in different situations.
Mar 25, 2010 | Cell Phones
How do I increase the volume on my Nokia 1661?
There are 2 types of volume in your nokia phone that you can increase or decrease.
The first one is the ring tone volume. You can either increase or decrease your ring tone volume by pressing the menu key then go to settings, go to profile, select any desired profile go to personalise go to ringing volume, then increase or decrease by using the navigation button to the right or left.
The second way is to increase or decrease the volume of the speaker of your phone which i think is the cause of your question (this volume enables you to hear clear and loud the person on the other phone). You increase or decrease the volume by making a call, as soon as the call starts ringing, press the navigation key to right to increase the volume or to the left to decrease the volume.
Jan 19, 2010 | Nokia 1661 Cell Phone
My ringing volume is very low i have tried advanced profiles and put all setting on high however its still very low i can hardly hear it.
I have the same issue. It is a manufacturing fault. The fix with mine was to fold up a gum wrapper and place it over the camera flash, and re-fit the back cover. It may take some fiddling around as too much pressure will cause it to go low in volume again. another solution would be to place a dab of glue around the camera flash and let it dry before replacing the back cover. In the end, you just want to applie a slight pressure to the camera lens / flash area. Hope this helps
Oct 27, 2009 | RIM BlackBerry Bold 9000 Smartphone
No sounds for alarm texts calls or windows media
Mine did that and I just changed to profile and changed it back to normal and it worked. I hope it helps
Jul 21, 2009 | Motorola Mobility Moto Q
Low custom (individual) ring volume
This is not a B/B fault, unfortunatley the person who recorded the ringtone has recorded it at a low level, import into a wave/mp3 studio program and alter the recorded levels.
That is if you have tried the following:
Select Speaker Icon on the front screen of your 8100 (top right) press pearl in, scroll down to advanced, select the current profile (this is defaulted to Normal). Scroll to Phone and press pearl in.
Change Volume to High, if it's already on high, try the option above.
Gadget
May 27, 2009 | RIM BlackBerry Bold 9000 Smartphone
Cell Phones Logo
320 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
