Question about Lands Phones
My phones are not working again!!!
No dial tone on all my phones!
    New Friend:
When our Uniden Phone stops.I pull out the power pack and put it back in and it all goes again.
RX
Posted on Dec 30, 2012
SOURCE: GE portable phone model # 26928GE1-D No dial tone-installed new battery still no tone
what does it mean what your phone is out of range
Posted on Sep 06, 2008
SOURCE: avaya phone not working
Yes, check the wiring. Sounds like the blue pair isnt working at that jack.
What happens when you plug that phone into the extension port of the system?
Posted on Sep 17, 2008
funkyjacob
  • 76 Answers
SOURCE: No dial tone on handset
It may not be registed with the main unit. You may need to register the handset. With my uniden all i have to do is put it in the main base until it says what handset it is (it should be a number).
If you have any questions please dont hesitate to ask
Posted on Dec 02, 2008
  • 50 Answers
SOURCE: phone showing "unavailable" and there is no dial tone. I have tr
Unavailable and no dial tone usually means that there is a bad wire between the base and the wall or the wall jack is bad.
Posted on Jun 27, 2009
  • 52 Answers
SOURCE: no dial tone
I would contact your phone provider. It could be a coinceidence that the dial tone stopped working.
DSL does not require dial tone to work.
Posted on Sep 12, 2009
Will not dial out on pulse on one line, works on second line
try changing phone to tone dialing . one phone line has been setup for Decadic dialing and the other line may be setup for tone dialing.
If tone dialing is working on one line but not the other then get phone company to change the dialing type on the phone line.
Dual tone multi frequency is the technical name for tone dialing and is more efficient than decadic dialing or pulse dialing.
Jan 23, 2016 | Lands Phones
Fax problem
I want to make sure I understand this completely. You get no dial tone from the fax machine when hooked up to VOIP. In the past, was there an audible dial tone from the fax, or did it just dial silently and give you an error if there was no tone? When you said you got a dial tone by connecting a phone to the ext phone port of "the machine" did you mean the fax machine? If you get a dial tone by running a phone through the fax machine, then the line is good. I have used a fax machine over Sunrocket before they went defunct, which used the same technology base as Vonage - so it should work. If you used to get an audible dial tone when using the fax, and no longer do, and you are geting a dial tone on a regular phone that is connected to the ext. port of the fax machine, then the problem has to be in the fax machine itself, not the VOIP. If you can verify that, we can go from there.
Oct 08, 2007 | Brother MultiFunction Center MFC-440CN...
If I enter the phone number and then press "talk", the numbers dial extremely quickly, a dial tone comes on, and I have to enter the numbers again. How do I fix this? It is a Vtech 6.0 DECT.
Usually there are two modes provided to all fixed line telephones. Tone mode and pulse mode. Pulse mode will dial the call slowly and Tone mode will dial calls quickly. Your phone is in Tone mode i guess. You need not dial the numbers again. Wait for few seconds and the call will get accomplished!
Aug 01, 2010 | Vtech DECT 6.0 Cordless Phone with Digital...
No dial tone
Sep 04, 2009 | Vtech Lands Phones
No dial tone - I have to dial using the speaker phone
sounds as if this phone will need to paired with the base again.
May 30, 2009 | Panasonic KX-TG5632 Phone
Dell AIO 962 can't get a dial tone
There are 2 phone jack ports on the back of the 962.
One for line, one for phone.
You want to plug the phone line into the port that says "line" or "Fax".
If it's plugged into the wrong one, your fax machine will not get a dial tone.
Jul 31, 2008 | Dell 962 Photo All-In-One InkJet Printer
Dial tone
I disconnected the RadioShack phone/answering machine and plugged in an old phone. At first I didn't get a dial tone, but in a minute or so, I did get one. I doublechecked the connection with the incoming phone jack. (I had checked this before, but didn't see anything wrong.) Again, I didn't see anything wrong, but maybe that did it. Also, when I disconnected the RadioShack from the incoming phone jack, I disconnected from my computer (I used to have dial-up connection).
Don't know which of my actions worked, but now I have dial tone on Radio Shack.
Hoooooooray!!!!
Jun 22, 2008 | Radio Shack 433575 Cordless Phone
Radio shack phone c-4210
for my phone I hold down the flash key then the menu comes up and you can press * for tone or # for pulse. Hope it helps!
Dec 06, 2007 | GEH5450 Cordless Phone
Ge 900 MHz cordless phone set on rotary dialing
Lisa, If the 900MHZ phone is Model 26928M programming for rotary dial usually goes like below, can't hurt to try on any model. TONE/PULSE DIALING This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for touch-tone use. To set to tone or pulse dialing: 1. Press and hold the program button for two seconds. You will hear a beep. 2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing. 3. Press the program button again. You will hear a confirmation tone.
Sep 29, 2007 | Uniden Cordless Phone
Lands Phones Logo
16 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
