Question about Planar PX2211MW Monitor
After it attempts to start with the green light on it turns off switching to orange light
I thought it was the power-cable's problem - plugging loosely into the monitor. So I've changed the power cable, which didn't solve the problem If I hold the cable's plus up, to keep the connection to monitor steady and tight, the light on the monitor goes green, the sign "No power supply" shows on the dark screen, then the green light on the monitor changes to orange light.
  • Marta Tereshchenko Dec 30, 2012
    I've sold the problem for now by shutting down my computer, unplugging the power cord from the monitor. Then plugging it back, and rebooting my computer. So that tell me that the power supply might wound NOT be the problem. Many thanks to all my prompt kind helpers and advisors. Happy New Year, my new frieds! Marta
    Top Expert:
  • Planar Master
  • 43,031 Answers
The power supply has failed
Posted on Dec 30, 2012
2 Suggested Answers
joegoldman
  • 335 Answers
SOURCE: pl2010m orange standby light, black screen
Try booting the pc in safe mode (press f8 at startup). It may be possible that the pc is trying to send too high a resolution to the monitor...unlikely though. The symptom you describe usually indicates that the power board or the inverter board in the monitor are defective. If it does the same thing in safe mode, you have 2 options.
1. Replace the power board and inverter board (do the inverter board first.......it's the cheaper one (10-20 dollars).
2. Send the monitor back to the seller for a refund, or get a new monitor.
Sorry I couldn't give you more positive feedback. Hope this helps.
Joe
Posted on Oct 13, 2009
Green light wont come on
Is unit running? Orange switch - is that the fast freeze switch? If on and running, green light faulty. If nothing happening, start with fuse, test the switch and make sure power is to the thermostat.
Apr 04, 2014 | Freezers
NEC lt240 lamp light stays off and power light is orange, no Image
COULD HAVE HOUR COUNT LAMP LOCKUP YOU WILL NEED TO RESET HOUR COUNTER BY USING BUTTON CONFIG AND MAINS.
john
www.jvsvisual.com
Apr 15, 2013 | NEC LT 240 Multimedia Projector
My computer can't boot at all after switching it of for some days now. the power led just blinks orange and that is it...please what do i do?
Replace the jumper back into it's original position. Remove the power cable & hold down the power button for 15 seconds to reset the board. replace the power cable & attempt to boot.
Jul 16, 2012 | Computers & Internet
HP Pavillion a1514n Won't Turn On
Yes even with the green light on it could still be the power supply. Have you pulled the power, opened the case, and pulled the BOIS battery? Could be the BOIS needs to be reset. You might also pull all the memory chips, turn it on and see if you get a beep code. I have had that happen in the past. Then I would replace the power supply (if you have an old one laying around use it to test, with just the MOBO plugged in). If the power supply fails, that leaves only the mother board as the issue.
Good luck, I hope one of these suggestions works for you.
Jun 29, 2012 | HP Computers & Internet
Hook a monitor to the video output, if no change! the video graphics chip is bad located on the motherboard.
Jun 29, 2012 | HP Pavillion dv9740us Notebook
My dell gx260 ligth come green if i turn it on but for a few mins time it turn orange why
Do you mean the monitor's power light starts green and then turns orange when you turn it on? Most monitors will go to a power saving mode when they do not get a signal from the computer.
The Dell GX260 has a green power light when on. When the computer is off, the light is off. If it is green and blinking, then the computer is in a power saving mode.
Diagnosis: start with the obvious: is the monitor cable plugged into both the computer and the monitor (if not permanently connected to the monitor)? Are you connected to the active port? (You can add a video graphics card in most desktops. The motherboard video port usually needs to be disabled to use the card ports. If you plug in the monitor cable to the disabled port, it won't work.) Is the monitor set to the correct input? (This applies if the monitor has several ports. In that case, there will be a Source or Input button on the monitor.) Is the computer on? The GX260 has the power button on the front. (Other computers have the power button on the top.) There is also the power supply switch on the back which needs to be on.
Next try a different data cable between the monitor and the computer (if you can). Try a different monitor. If a second monitor works, than the monitor has a damaged main board. If the second monitor doesn't work, then the video graphics adapter has probably failed. Replace the add-on card, if in use, then boot in the safe mode to remove the old graphics driver. Then install the correct driver for the graphics adapter.
Note: the computer and the monitor should both be off when you connect the cables. Then turn on the monitor first and set it to the correct source before turning on the computer.)
I hope this helps.
Aug 21, 2011 | Dell OptiPlex GX260 PC Desktop
My Canon iX4000 has changed its colours during printing, with Red noticeably being printed as green. I have a Canon 5PGBK & Calidad 922 Cyan, Magenta & Yellow Cartridges. Do you think the...
Welcome to Fixya
If this happened recently then try to reset the printer to factory state. Please see procedure below:
1.Connect the Canon PIXMA iX4000 printer to the power cord. ( note : If the automatic power-on function is enabled in the printer, the printer enters the service mode for the first time, but it will never enter the service mode if the printer is turned off by the Power button. This is because the printer remains to be turned on internally if the power is turned off by the Power button. To prevent this, disconnection of the power cord is required before starting the printer in the service mode ) .
2.With the Canon PIXMA iX4000 printer powered off, while pressing the Resume/Cancel button, press and hold the Power button. (note : Don't release the buttons. The Power LED lights in green to indicate that a function is selectable.)
3.While holding the Power button, release Resume/Cancel button. (Don't release the Power button.)
4.While holding the Power button, press Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons.
5.When the Power LED lights in green, press the Resume/Cancel button 4 times to reset waste ink counter in the Canon Pixma iX4000. (note : If the Power LED does not light in green the printer does not enter the service mode, disconnect the power cord and plug it again. Then start from step 1 to start the printer in the service mode again).
6.At the end of the service mode, press the Power button. The paper lifting plate of the sheet feed unit will be raised.
Note :
Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.
Other specified number of time(s) according to the function listed in the table below.
Time(s) LED indication Function Remarks
0 times Green (Power) Power off
1 time Orange (Alarm) Service test print
2 times Green (Power) EEPROM information print
3 times Orange (Alarm) EEPROM initialization
4 times Green (Power) Waste ink counter resetting
5 times Orange (Alarm) Destination settings
6 times Green (Power) Print head deep cleaning (Cleaning of both black and color)
Thank you for using Fixya!
Jun 19, 2011 | Office Equipment & Supplies
Would a bad Flasher relay cause the brake lights not to work?
The flasher does not stop the brake lights from working. Check # 18 fuse in fusebox under lower left side of dash. if it's ok, the brake light switch, on the brake pedal arm is next. light green wire with red stripe is hot if fuse 18 is ok. Depress brake pedal, light green with no stripe should have power. if not, replace brake light switch. If light green wire has power with pedal depressed, combination switch under the steering is next. Remove the cover from around the combo switch {under the steering wheel}. depress brake pedal, light green wire should have power. If it does, pedal still depressed, orange with light blue wire & wire with light green & orange should have power. Those 2 wires are brake & rear turn signal wires. { The turn signal switch should be in the middle, not right position or left. while checking for power in the last 2 wires. Good Luck drvolt.
Feb 06, 2011 | 2004 Ford F250
Planar PX2211MW Monitor Logo
223 people viewed this question
Top Planar Computers & Internet Experts
William Miller
William Miller
Jay Plesset
syspro
Are you a Planar Computer and Internet Expert? Answer questions, earn points and help others
