My Elba Washer, model WA37T26EW2, does not turn on.
My Elba washing machine, when reaches the rinse cycle, water is very loud, never before, but it never stops adding water. Water is draining fine but water does not stop to cycle to rinse.
The water inlet solenoid valve is being held open. Take off the hose and look in the opening to see if you can find anything. Otherwise replace that solenoid valve.
Sep 02, 2016 | Fisher Paykel Fisher & Paykel Elba 3.7 cu...
Elba washing maching wa65tm stops at rinse
have u got a rinse hold switched on.this is to keep clothes from getting creases it holds until someone tells it to complete cyle
Nov 20, 2015 | Fisher Paykel Fisher & Paykel Elba 3.7 cu...
No power completely dead
Most likely the PCB is dead, but feel free to give us a call to speak with a tech : http://appliancerepair.biz/
Sep 21, 2014 | Fisher Paykel Fisher & Paykel Elba 3.7 cu...
Elba washing machine wont drain or spin
The pump filter is blocked ,so it wont empty,remove filter cap and clear out lint, coins etc.
Jan 03, 2014 | Fisher Paykel Fisher & Paykel Elba 3.7 cu...
Elba washer is not washing or spinning right...the only thing its doing is adding water
I couldn't tell if the water was draining. When you advance the cycle to spin the first thing it should do is drain the water. This will happen for a short time before it spins. If it is not draining then you need to check the drain pump for blockages( and pipes) the machine will not spin with water in it! If it is draining but not spinning then it is probably a faulty lid switch and needs replacing. There are a couple of other causes but they will usually create a fault code which you don't seem to have. Most likely blocked or faulty drain pump.
Jul 05, 2013 | Washing Machines
What number of elba repair
Wa37t26ew2 will not power up
Dec 03, 2012 | Ovens
My elba c96df oven has stopped working . The oven lamp comes on but theres no heat . Is it the elements or the thermostat?
Elba Oven not heating? How to replace a Elba fan oven element
This video will show you how to replace fan oven element in your
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. You searched for Elba element How to Repair Home Appliances
Mar 06, 2011 | Microwave Ovens
Washing Machines Logo
67 people viewed this question
Top Washing Machines Experts
