Question about Onkyo TX-SV444 Receiver
Laptop into my YAMAHA HTR-6130 Receiver has Static
I plugged my laptop into (portable slot) and then tried RCA (red and white)slot on the Receiver (YAMAHA HTR-6130) There is sound , but alot of static ,what can i do to fix that.
  • mb1681 Jan 18, 2009
    im still having problems , everything works fine except when i plug my lap top into it. The cables are fine, i pod works fine in the same slot , i have no idea what it could be.
  • 4 Answers
One possible reason would be a damaged ground in the cable (check with a DVD/CD player or any other device if possible to see if static persists.) if it is not the cable, then try plugging the laptop into the same power outlet as the Yamaha receiver and see if static persists. if static no longer persists, the problem is a discrepancy in the grounding on either end causing static in the signal and you can either buy a filter at most electronic stores. or you can just continue to use that power outlet if it is not an inconvenience. if it IS the cable, well, replacing it should be fine.
Posted on Jan 18, 2009
All Yamaha HTR-6130 codes don't work on DirecTV remote
try 30176 and dont forget to assign the remote to turn up the receiver not the tv
Jul 04, 2009 | Yamaha HTR-6130 Receiver
No sound unless VIDEO signal is plugged into receiver
Connect the DVD player audio with digital coax into the digital audio connection as you described and the DVD video directly to the TV. Now switch the input mode on the receiver to DVD. Then switch the video output mode on the TV to correspond to the input you plugged into. Any source in 5.1 dolby digital or dts should now work properly and have picture too.
May 07, 2009 | Yamaha HTR-6130 Receiver
Yamaha HRT 6130 cable questions
You would need 1 component and 1 HDMI cable.
Mar 15, 2009 | Yamaha HTR-6130 Receiver
Xbox 360 to the yamaha htr 6130
All you is connect the to audio jacks (red,white or black) to the receiver input or aux port then switch the receiver to aux or line in
Jan 13, 2009 | Yamaha HTR-6130 Receiver
Different sound levels dvd and cable hdtv yamaha htr-6130
Well, first of all, the method you are using is the lowest quality. You should upgrade to a toslink(digital optical cable) or a digital RCA cable. The toslink is the best all around. But it is normal for some devices to have higher sound output than others.
Jan 08, 2009 | Yamaha RX-V461 AV Receiver
I have a Yamaha HTR-6130 Reciever of which I want to connect my Nintendo Wii and XBox 360 to. I already have my PS3 connected to the HDMI and the audio connected to the red & white a/v inputs, but I've...
Not sure if this is your problem, or not, but the red and white wires are for audio. There is a separate yellow wire for composite video. Alternatively, you can use the red/green/blue (RGB) connector cable for component video.
Jan 06, 2009 | Yamaha HTR-6130 Receiver
No Audio Coming Through On HDMI DTV/Cable INPUT
The HTR-6130 cannot decode HDMI audio. It can only act as an HDMI switch. To get the audio from the cable box to be output from the HTR-6130, you will need a separate audio connection (e.g. RCA cable).
Dec 28, 2008 | Yamaha HTR-6130 Receiver
Yamaha HTR-6130 Front right and left speakers with no sound
As simple as this sounds, try hitting the speaker a/b button on the front of the unit, next to the headphone jack. I had the same problem, and was about to package the whole thing back up and go back to Best Buy when I hit this button and then the audio test worked.
Nov 23, 2008 | Yamaha HTR-6130 Receiver
211 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
