Question about Primos Trigger Stick
The bottom of my trigger stick will not lock - Primos Trigger Stick
On the vacuum can I lock the on and off switch
Hi there, it's Jack at Dyson.
DC59's light touch trigger on/off switch is engineered to ensure that power is only used for cleaning, and not wasted while picking up obstacles, moving from room to room or changing accessories etc. Some other cordless vacuums remain switched on from start to finish, and runtime is wasted between tasks.
The on/off trigger has been engineered to be as light as possible to hold down. It also fits flush with the handgrip so load is spread across the whole hand.
I hope this information helps, but just to confirm it's not possible to lock the trigger in place as the vacuum hasn't been designed to be used in this way.
Feb 15, 2015 | Dyson DC59 Animal Bagless Cordless Stick...
How do you reset all family settings on xbox 360
There are different codes for different 360 consoles and different dash versions:
1. On the 360 dashboard, scroll over to the "System" tab.
2. On the System tab, click "Console Settings".
3. Scroll down in console settings and click "System Info".
4. When the system info box comes up SCROLL TOP THE BOTTOM and type in this sequence:
LT RT X Y LB RB Y "Left Stick in" (press it in and hold it in) Y Y
A box should come up and say, "Would you like to reset the console to the factory defaults?"
Click Reset and you're done!
!!!HERE ARE MORE CODES THAT HAVE BEEN TESTED AND WORK!!!
LEFT TRIGGER, RIGHT TRIGGER, X, Y, LEFT BUMPER, RIGHT BUMPER (Do this twice)
LEFT TRIGGER, RIGHT TRIGGER, X, Y, LEFT BUMPER, RIGHT BUMPER, X, X, UP, DOWN, DOWN. Then down, down again.
Left Trigger, Right trigger, X, Y, Left Bumper, Right Bumper, DOWN (dpad), Y, Left, Left
Jun 22, 2014 | Microsoft Xbox 360 Console
Whay is my Saitek X 52 flashing
Most likely a wire going thru the stick to the hat switches trigger button etc have been rubbing on the tube that makes up the base of the stick. I removed the four screws on the bottom and found the solid blue wire had completely broken. I ended up soldering back together and used some liquid insulation let it dry and put it back together and worked fine. I to just had flashing lights on the flight stick. And this is what I found
Jun 02, 2014 | Saitek X52 Flight Control System
Primos trigger stick trigger does not release legs
I fixed my Trigger Stick Tripod using this method. https://youtu.be/X0w88XCyxgs
Nov 30, 2013 | Primos Trigger Stick
Bostitch framming gun sticking?
Most likely the headvalve is sticking. An easy fix would be to remove the head and lubricate the headvalve orings with white grease or silicone paste. The upper bumper should not have any cracks. If the problem continues replace the trigger valve (tva6). The trigger valve can be bostitch or generic sold on ebay for usually less then $20. The trigger valve has an inner valve that can stick due to swolen or hard orings.
Nov 19, 2011 | Stanley Bostitch Nail Gun
The fast idle button on my Poulan 2050 is stuck down all the time. I assume it should pop up and lock into place when depressed. I can get a total replacement part, with pins, no problem. How do I...
The trigger and lock out lever comes as a kit, part no. 530071305, remove the top cover, depress the trigger and pry up the throttle wire away from the trigger, knock out the two roll pins, drop the trigger out of the bottom of the handle, lift the throttle lock out of the top of the handle.
Oct 27, 2011 | Garden
Troy-bilt presswasher that is running fine but has no pressure from the unit and any water that is flowing thru is very hot when the engine is running.
Your machine is air locked. Air in the supply line reaches the pump and the pump cavitates, allowing very little water to get by. Since the pump is just chewing air, it is getting very hot, producing the result that you see.
With the engine off, turn on the supply water and allow it to flow through your washer. You may need to lock the trigger on the wand in the open position, or hold the trigger down while purging the supply line. Make sure that there are no kinks in the supply hose and that any loops in the hose are straightened out. Raise the hose above your waist and walk it the length of the hose to the washer, forcing any air pockets through the hose and through the machine. This entire process will take about 5 minutes or so.
Release the trigger, start the machine and get to work. If the machine doesn't put up enough full pressure when you crank it, try cranking it while holding the trigger open. Sometimes the overpressure valve sticks, and can prevent full pressure from being reached. Holding the trigger open bypasses this issue, but doesn't repair it.
Best regards, W/D--
Jun 10, 2011 | Garden
I previously used my 2GB with movies, but i can't delete anymore, message is USB is write protect
does your usb stick have any small "hidden" lock key on it? try searching for it. Your issue reminds me of floppy disks that you could lock simply with one small trigger they had on them. Hope i helped. Cheers
Apr 29, 2011 | Computers & Internet
Vacuum lock when releasing trigger. water will
It sounds like the valve in your trigger gun is sticking. Depending
on the model it can be rebuilt or repaired
Sep 08, 2009 | Karcher Garden
How to reset xobx pass worad
try this
left trigger
right trigger
x
y
left bumper
right bumper
left with left stick
up with left stick
right with left stick
Jul 31, 2009 | Microsoft Xbox 360 Console
Primos Trigger Stick Logo
Top Primos Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
james laughton
james laughton
Are you a Primos Optic Expert? Answer questions, earn points and help others
