Question about Vivitek H1080FD DLP Projector
My vivatek h1080fd after running for a while starts to flicker, loose resolution then shuts down
My vivatek h1080fd after running a while will start to flicker, change colors, lose resolution and then shuts down. The original bulb had 2000 hours. We changed out the bulb thinking this was the problem. It is still doing the same thing.
  • 2 more comments
  • Jason Mar 13, 2013
    I'm sorry I don't have a solution.....mine is doing exactly the same thing with 1500 hours on the bulb.
  • Blayne Moseley Jun 05, 2013
    mine is doing the same thing, had 2000 hours on the bulb and now the new bulb is doing the same thing
  • Blayne Moseley Jun 06, 2013
    I have temporarily fixed this issue by directing a fan at the intake vent on the side of the projector. it's gotta be the intake vent and not the exhaust.
  • Rodrick Crider Jr
    Rodrick Crider Jr Apr 10, 2014
    I fixed this issue by removing the black circular panel around the lens, so that more air could flow through the projector. I also took the whole thing apart and blew it out with a leaf blower to get all the dust out. After doing that it works like a charm, even in regular mode. Previously I could only get it to stay on for about 5-10 minutes even in high-altitude mode.
    New Friend:
Posted on Jun 06, 2013
DMD error code
the DMD is good ,
the Projector will still start up,even if the DMD is defective.
the lamp ballast or the mother board is defective
Feb 20, 2014 | Vivitek H1080FD DLP Projector
The picture is flickering when I am in games!
What about the screen resolution? If you have big screen resolution, try to set it down to 1024X768 and try again to launch game.
Also take a look at that
Dec 11, 2012 | XFX Computers & Internet
Predator 500cc.i was out trail riding and it started to bog down alittle, shut it off and when i went to start it wouldnt turn over. my lights were flickering
First thing to check would be the battery connections. Make sure the positive and negative cables are tight. I've chased problems on several atvs, especially Predators, to find out the battery cables were loose. They will make the atv cut out or bog down while riding and make lights flicker. Let me know if you need anything else, Daniel.
Oct 10, 2011 | Polaris ATV
Parking and dash light flickering
First. I would look for a loose connector plug going to one of the fuseboxes, there could be corrosion in the connector even, Under the hood or under the steering wheel. 2nd. I would try to locate the ECM, could also be a bad connector there as well.
Jan 13, 2018 | 1995 Oldsmobile Cutlass Supreme
Flickering in the main PS3 screen with 1080p resolution
1080 i is what you run going to higher resulution causes that your provider is 1080i or 1080p
May 02, 2010 | Sony Playstation 3 (PS3) Console
Screen flickering
Not likely a bad monitor...
The monitor cable on the back of the computer is loose.
Could also be the screen setting that is difficult to achieve and maintain.
If the cable is already tight on both ends, you might try a lower resolution setting for the monitor.
1. Right-click anywhere on the desktop
2. Go to "Properties" on the drop-down menu
3. Select the "Settings" tab
4. Slide the Resolution knob to the left a little (1024x768 or 800x600) and press [OK]
Hope this helps
Sep 14, 2009 | HP Pavilion dv6000z Notebook
After being on for a while sometimes 10 minutes, smoetimes 2 hours, the projection loses color and flickers, I can hear a squeeling noise, and eventually shuts down
Mine does the exact same thing, but usually before it overheats and shuts off. This started after I replaced the lamp the third time. I haven't found an outside solution to this, but pointing a floor fan at it to keep it cooler works for me. Did you ever find a resolution?
Sep 09, 2009 | Optoma EP1690 DLP Projector
The screen flickers, have to reboot it
Start by checking Dell's support site for updated video drivers, then uninstall the drivers for the screen from the device manager, then reboot. It will find and reinstall them. If this doesn't cure it, then this is going to be a hardware issue. Start by checking the screen connections, they sometimes work loose. If the connections are good and the problem persists, it's going to be the inverter or screen, and unfortunately, replacement is your only option.
Jun 28, 2008 | Dell Latitude D820 Notebook
Dell Latitude cpx
Symptoms of a Bad Video Driver
Monitor Resolution issues:
screen flickers, screen is cloudy, screen shows horizontal lines, screen goes black, goes blank, goes into sleep mode, goes into power mode, size magnifies or reduces, video is jittery, fonts change, screensaver will not appear, cannot extend display on dual monitors.
Download it from here
VIDEO DRIVER FOR LATITUDE
May 28, 2008 | Dell Latitude CPX Notebook
Vivitek H1080FD DLP Projector Logo
360 people viewed this question
Top Vivitek Office Equipment & Supplies Experts
Miguel Luiz Martins
Are you a Vivitek Office Equipment and Supply Expert? Answer questions, earn points and help others
