Error code p4 on my split type kolin inverter aircondition unit
SOURCE: my carrier split type non-inverter aircon always blinking
I got the same problem in Samsung aircon. The unit I purchsed died slowly. After that Samsung replaced it with the one have the same problem. They are swearing that the green light blinking problem as a normal function and refusing to fix. Their user manual says it is a problem. I think the affected consumers should join hands to take legal action against this scam.
Posted on Dec 20, 2011
hvac1960
  • 2133 Answers
SOURCE: the led panel on the
C6 - compressor run current high
- check [resistance of] compressor windings all equal 1 to 4 ohms
- check [resistance] to earth 50 Mohm minimum
- check run current
I'd also check the motor capacitor(s) , In maximum, it is due to weak capacitor. Replace and try.
Posted on Dec 16, 2010
hvac1960
  • 2133 Answers
SOURCE: Split unit airconditioning DSA099L. Trips
F-6=High discharge temp/overheating compressor.
Due to condenser block (Clean it),/less RPM of fan motor (Replace capacitor)/Noncondensable gas( Remove gas flush out system, vacuum and do gas charging..
Helpful?
Posted on Jan 02, 2011
hvac1960
  • 2133 Answers
SOURCE: Hi my LG healthplus inverter
Indoor Pipe Sensor or Outdoor Sensor Assy fault, Open or Short. Disconnect from PCB and measure resistance. Air sensor = 10 kOhm at 25C, Pipe sensor = 5
kOhm at 25C. If not replace sensor
Posted on Jan 20, 2011
SOURCE: WE have Amcoraire Mini split unit heat pumps. One is
We have an Amcoraire 12,000btu mini split. The heat doesn't seem to be working. We can hear it trying to go on, the outside unit fan runs, but nothing comes out of the inside unit at all. This doesn't seem to be affecting the a/c part and we get no error codes. Is there something wrong with our unit?
Thank you.
Posted on Feb 19, 2011
What error code PO kolin split type.no cold coming also the fan motor suddenly stop.
My personal suggestion would be to go for these repair catalogs. I know this website reliable-store.com that i used to buy them from, and they have
online it was very good manual. Go ahead, I bet.
Mar 05, 2018 | Heating & Cooling
Kolin inverter window type aircon shut down with FO code
when you post the same question more than once in a few hours most here tend to ignore them. once is enough. when someone who knows the answer comes on maybe youll get lucky.
Jan 28, 2018 | Inverter Heating & Cooling
Hi, when i turned on my Senville mini split the fan will go on for 2 - 3 minutes and then the air conditioner will display P4. On the error code description, it say inverter compressor drive error.
contact the manufacturer to see if they can help you with this type of failure. the compressor and its controller are the two most expensive parts of the unit to repair.
Jul 29, 2016 | Inverter Heating & Cooling
Es error code kolin split type
What is the make / model of your air conditioner. With out that information i cant help you with your ac repair problem.
For more information on AC Repair Tamarac Check us out.
Apr 19, 2016 | Heating & Cooling
Streamline. What does error E0 mean?
How to fault find a Daikin Air Conditioner, troubleshoot split ...
? 4:22
www.youtube.com/watch?v=i30rEvyuDKs
Feb 10, 2012 - Uploaded by Fully Airconditioned This video shows how to get fault code from remote control and reset fault, you ... Daikin Inverter AC Unit Fail - Moisture / Salts Damage to PCB ...
Sep 30, 2015 | Inverter Heating & Cooling
My orient split a.c shows Ec error in digital display
sir plz answer me my ac orien 1 ton showing EC error on display what is this i can't understand what is this plz reply
Jul 12, 2014 | Heating & Cooling
P 4 code means problem with the outdoor unit, Most likely low on refrigerant. Check all copper pipe connections for leaks first, then add refrigerant after checking pressures.
Jan 17, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
Heating & Cooling Logo
892 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
