M3N-HD/HDMI came with no Q-sheld for the back of the I/O ports.
I have lookted all over for one i even ask tiger the place i bought it from and they seaid to call the asus they said that they don't sell them separate unless you got inshrents on it but i did not becaus it was bout open box.and i could what and then maybe it would be at there asus stor but all they have are the M2N ones . can some one plez help me i have looked every ware for one can someone help me.
  • manslayerdbz Jan 28, 2009
    i wont the real one thnx tho
    dus sombuty have one frome an old board or no a sight with this part trll plez
  • 2,692 Answers
I have made then from stiff paper with tin foil around them for old computers that I could not or did not get or find one for. Or cut one from light tin. In my wexperience they do not seem to be necessary. Pleant of cooling even with the larger opening.
Posted on Jan 18, 2009
My Comcast remote quit working with the cable box. The guide wont come up any more and my hd doesn't look like hd....just standard. I went to look in the back and I thought I had hd but I only have coax....
You need an hd cable between your cable box and tv. They don't provide them for free. Once you plug in your hdmi cable to the tv, change its input to the hdmi port you just plugged into. The guide is updated by the cable system on their internet but over the coax. Give it time, it should come back. If not, reset the cable box by unplugging itfrom the wall power, wait 5 seconds, plug it back in. It should come back.
Sep 02, 2017 | Televison & Video
Bush hdmi port broke?
hi just take it back get a better make tv like a panasonic thanks
Apr 17, 2017 | Televison & Video
No video
Hello here is the homepage:
Your power supply is probably failing, or to small for the system.
Are all drivers and the bios upgraded ???
If you are useing the onboard graphic, try to add a better graphic card on the mainboard for better performance.
I suggest you to buy a 500 watts power supply, or bigger depending on the systems specs.
Good luck
Feb 13, 2013 | Nvidia Asus M3n-hd/hdmi Nforce 750a Sli...
How do i connect my hdmi cable from my ibuypower desktop to my sansung led tv?
Make sure the input on the TV is set to hdmi port 2. If it doesn't automatically view on the TV, you have to go into the graphics card adapter settings to set the view to an alternate monitor (your TV). Normally there's also a hotkey command as well (normally one of the F# keys) to switch between displays
Dec 20, 2012 | iBuyPower Gamer Computers & Internet
Hi guys I have a Phillips Plasma TV 42PF5521D/10 model UK version bought in 2008 Guess what untill now i only used the HDMI ports to connect a Home Media Center PC to watch HD content. So last...
hi First, remember the old HDMI reset tech tip. Unplug all HDMI cables (one end will do.) Then remove power from all things in play. No, not just turned off but remove the AC. Wait 5 to 10 minutes, hookup re -test thanks
shaun .
Mar 09, 2017 | Philips 42PF5521D 42 in. HD-Ready Plasma...
We bought a new samsung 32" flat screen TV. Our HD cable box is connected to the tv using the red/yellow/white cables. Is there an alternative way to connect my Wii without unplugging the HD box...
You'll need to purchase an HDMI cable and use that to connect your hd box to your tv. Your tv should have several HDMI connections on the back to facilitate the hookup and you will not have a true HD picture without that cable. You can buy this cable from the same place you bought your tv or www as well as many other electronics supply stores, hardware stores, or places like Kmart, Walmart, Bimart, etc. You can also buy a multi port Rh connector box that you can run multiple components through and just push the corresponding button for the component you wish to operate.
Hope this helps and please rate my solution!!
Nov 27, 2010 | Nintendo Video Game Consoles & Games
Drivers for m3n-ht
Here is a link to your drivers and software.
Remember to choose the correct operating system.
Hope this helps
Oct 20, 2009 | ASUS Motherboard M3n-ht Deluxe/hdmi
Which do u install first the support disc or the os
Always install Operating system first so your driver disk has somewhere to put its drivers
No O/S no drivers
Oct 27, 2008 | ASUS Motherboard, nForce 750a SLI, Phenom...
Converting up to 1080
Hello. You have to use the HDMI port and connect to the HDMI, or DVI, port on the back of the TV to get 1080. Even if playing HDDVD, this cable is necessary to get the increase. That, and the TV has to be in 1080 too. If you look at the display, on the front of the player, while watching the DVD, it will tell you at what resolution the DVD is playing. The HDMI to HDMI/DVI must be installed to get the increase in resolution. I have a Panasonic HD 34" 1080i widescreen TV, with DVI connection. When connected, the player played my DVD's at 1080i on my TV, while at only 480i thru the composite cables.
On some older movies or series(I like Star Trek- TNG), it doesn't work well due to the transfer to the DVD. Most newer DVD's, such as Batman Begins (there is an HD out, but I have DVD only), improved on the upconvert for me nicely.
Jan 21, 2008 | Toshiba HD-A30 HD-DVD Player
Computers & Internet Logo
294 people viewed this question
David Payne
David Payne
