Question about Canon PIXMA iP90 Mobile Printer
Error message that my IP90 Canon is offline.
Error message that my printer is offline. Worked fine yesterday. Plugged and unplugged; rebooted; did trouble shooting....still getting same message.
    Problem Solver:
  • 8 Answers
Check that you haven't accidentally changed it setup to being off line, you will find this in the devices section of the control panel. If that doesn't work I suggest you re-install the printer software using the setup disk that should have come with the printer. Hope this helps.
Posted on Dec 30, 2012
  • 121 Answers
SOURCE: Canon IR 1600 Error message E000
You'll need to replace the fuser unit. Not exactly the cheapest part of the machine...
Unless, that it, you were taking things apart and happened to unplug something accidentally. If you take the cover off where the paper comes out, look at the connectors directly inside there under the black piece of paper that you'll see. If one of those are pulled out, it could cause the problem.
Otherwise you need to replace the fuser unit.
Erice
Posted on Nov 23, 2007
  • 97 Answers
SOURCE: error 5100 canon ip90
You may try this to rest the 5100 error:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Posted on Dec 07, 2008
SOURCE: Canon Pixma ip90 printer
service error 5100
Posted on Jan 04, 2009
SOURCE: printer not working wireless (printer offline)
Phoned Canon with the same problem. Everytime I installed the printer it would work until I rebooted. Canon advised that all I had to do was right click on the MP620 printer in printer control panel, then make sure that "Use Printer Offline"is not selected. Worked for me. Goodluck
Posted on Jun 30, 2009
komguy
  • 2306 Answers
SOURCE: Canon iP90 error 5C00
5C00 is a purge unit error, thats the cleaning unit on the right where the printhead parks. Look inside with a flashlight, if nothing is blocking it's operation, you willl need a new print engine, qm2-2020-000 around $150.00
Posted on Jul 21, 2009
Printhead not installed error message on iP90
hello, i think your print head is not installed properly, i had found a service manual for you that it will help with identifying the error, disassembly the printer, cleaning and more...you can download the manual from the below link:
http://goo.gl/1N7aD
Good luck.
May 20, 2013 | Canon PIXMA iP90 InkJet Printer
My Canon PIXMA IP20 printer is showing error message: the waste ink absorber is almost full.
hi;
to reset the counter follow these step:
1) Unplug power and USB cable.
2) Open door and hold power button.
3) Connect power.
4) Close door, then release power button
Oct 29, 2010 | Canon PIXMA iP90 Mobile Printer
Printer says '' error- offline" everything is hooked up worked fine yesterday and last 3 years
is the correct driver installed? also is it plugged in to the same usb port? Visit the manufactuers website and update youre rivers but do it while the printer is unplugged then plug it in
Sep 15, 2010 | HP Officejet 5610 All-In-One InkJet...
Won't print-- says the printer is offline (everything is on and plugged in)--just had my hard drive rebooted--something must have gotten unclicked...help!
Find your printer in control panel. This varies with OS installed (which you did not mention).
1) Right click your printer name
2) Choose "Use printer online"
Try your print job again.
Dec 20, 2009 | Canon PIXMA iP90 Mobile Printer
1p90 remains offline
i have had a little board inside the machine the connects the usb lead to the logic board fail and this causes this fault. You will need to call out a canon service engineer to fix your problem.
if your in the uk i can give you some contacts .
Hope this helps
Sep 30, 2008 | Canon PIXMA iP90 Mobile Printer
Canon MP 600 Will Not Turn On .... grumble.
I had this same issue. Lost power in the house for just a second, but after the printer would not turn on. I think that the loss of power caused the printer to get stuck in a locked state. Tried everything I could think of including changing outlets that the printer was plugged into but nothing seemed to work. Saw a troubleshooting tip on the Canon webpage about unplugging the unit for 5 minutes and thought it was hooey, but tried it anyway. Ended up leaving the unit unplugged for probably 15 minutes and when I re-plugged it in it fired right up.
Oct 09, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Another Offline error problem
Go to your printer in control panel and right click on it and de-select off line.
Feb 23, 2007 | HP Deskjet F340 All-In-One Printer
Canon PIXMA iP90 Mobile Printer Logo
198 people viewed this question
old marine
old marine
