Back to:
Tags:
HP Pavilion ze4125  PC Notebook
Will not complete boot sequeance
posted by hunter2 on Jun 22, 2007
when attempting to turn laptop it starts to boot then stops and goes to screen asking if I want to boot in safe mode or start notmally or last known good configuration, I tried all of these and nothing works, keeps returning back to same screen, not sure where to turn, please help
Comment by hunter2, posted on Jun 25, 2007
thanks for trying, canot get computer to boot or stay running long enough to re-install windows, do not have restore disks anymore, will have to take hard drive out and check with another computer when I have the time, hopefully this will be the problem and not a bad mother board, again thanks for your help.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jun 22, 2007
Thanks for Trying (70)
antiochpc
Rank:Guru Guru
Rating: 87%, 327 votes
Several possibilities.
1. Your windows installation is corrupted. You will need to use your recovery CDs or the recovery partition to reinstall windows.
2. Hard drive failure causeing windows corruption.
3. Bad memory.
4. Bad motherboard.
Chances are, it is one of the first two. When you first turn on the computer, press repeatedly the F10 key until the laptop boots into recovery mode. It should automatically go to a place where you can do a soft recovery of the hard drive or, that is to say, a non destructive recovery, only removing the windows files and reinstalling the original windows files. This leaves your data intact. After the operation and if it is a success, you may have to reinstall some software programs again if they don't work but your data will remain in tact. If that doesn't work, do it again only when the recovery screen comes up, press the advanced button which will take you to a complete system recovery where it will reformat your hard drive and reinstall your laptop to its factory preset, just like it was the day you bought it.
If neither of those work, you need to get a program that will run a scan on your hard drive to check it for errors but, normally, the first solution will do just fine for you.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on will not complete boot sequeance:
I don't want to Accept this solution
Can you Help with these PC Laptops problems?
PC Laptops
I have had a pink line running vertically down my laptop...
PC Laptops
I am having bsnl broadband connection with Siemens C2110...
PC Laptops
My screen on the left has a bright pink color all the...
PC Laptops
eu preciso de um progama de camera da toshiba
HP Pavilion ze4125 (F4892H#ABA) PC Notebook
tried restoring my computer because i thought i had a...
Loading problems.
Repair Service
Find PC Laptop Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
