Question about Kenwood KDC-MPV622 CD Player
Volume control not working
Stays at same volume when trying to raise or lower; also lowers when trying to raise, raises when trying to lower, etc. Seems like contacts are dirty? How can I clean them?
  • 2,427 Answers
You need to open the face up by removing the small screws.. use some rubbing alcohol and a cotton swab to clean it.
Posted on Dec 30, 2012
  • 8 more comments
  • eric_nevel Dec 30, 2012
    OK great, but what exactly do I clean? There doesn't appear to be any contacts. Do I just clean this lens in the center?
  • Rishi Roshan Ali Dec 30, 2012
    thats not a lens its a small light and no not that.. using the picture you have above notice the plastic wheel that turns to adjust the volume ?? its called a variable resistor. notice the metal contacts that connect to the board ? thats what you clean and also if you resolder the contacts its even better, just heat it and add some solder to it.
    OK, I did both - cleaned all 5 contacts (in the photo above, there are 3 contacts at 3 o'clock, 1 at 7 and 1 at 11 o'clock. I resoldered the 3 at 3 o'clock, and cleaned all of them. It didn't seem to help. Any other suggestions?
    yeah there is one, the one i was hoping it wasnt,, the variable resistor is just a resistor that you can adjust the voltage on hence its great as a volume contoller. The problem is the inside of it often gets corroded or the contacts bend or break (yes the inside of the plastic thing).. I have sucessfully on occasions managed to take it apart (unsolder it first then disassemble it. clean it, resolder the broken contacts or straighten it) and in some cases it was to bad to be repaird and if i could get an old one i would replace it or had to end up buying a new face or a new radio.. In your case i would suggest you prepare to get a new face or replace the system.. and then try to fix it, if it works your set if not well you were prepared for the worse anyway.
    btw taking it apart ofen reguires epoxy to reassemble it as someof the plastic pins holding it together gets broken.
    ps it can also be a potentometer but more than likely variable resistor. but in any case the same applies.
    Well, i was planning on replacing it anyway.. let me see if i can take it apart and bring it back to life. Thank you for your help
    no problem,, I'll be online if you run into any hurdles let me know..
    I don't do electronics, but with your help, I think I fixed it. I de-soldered the var. resistor without destroying the pcb, took the resistor apart, ensure the contacts actually made contact, smeared around some of the contact grease, and reassembled. I thought I had ruined it (resoldering wasn't pretty), but the volume seems to work great now. Thanks so much for your help!
    No probelm at all.. besides remember this,, once it works you did a good job no matter how ity looks.
2 Suggested Answers
richroth
  • 9472 Answers
SOURCE: i have a kenwood touch
DO you have a model number? What is written on the front of the unit?
Posted on Jul 24, 2011
Minimum volume way to high
There may be a low/high switch which lowers or raises the base sound level before the volume control has any effect.
Mar 11, 2015 | Coby CX-CD248 Radio/Cassette/CD Boombox
I have a Motorola aur12000 Cordless Phone and it does not ring loud.
Hi debora maisonave!
To modify the volume level on your phone please follow this steps:
To raise the volume:
  • During a call: press the key up to raise the volume of the call.
  • When the phone is ringing: Press the key up to raise the volume of the ringtone.
To lower the volume:
  • During a call: Press the key down to lower the volume of the call.
  • When the phone is ringing: press the key down to lower the volume of the ringtone.
Hope these steps help!
Regards
Gaby
Motorola Customer Care.
Feb 11, 2015 | Motorola Mobility Dect60 Cordless W...
Why can't I raise or lower the deck?
Sounds like you have jammed linkages which raise and lower deck, you can try this which usually works best with assistant.
With engine off, shake the deck vigorously (up,down, back and forth) while try to raise deck with lever.
Check for worn or damaged arms, springs, deck mounting points, etc and repair or replace.
Sep 01, 2014 | Garden
I have a 6th generation iPod Nano. This is the fifth one I've had and they all have had the same problem. At some point (usually after I've had it about a month) it starts to turn the volume down...
The only thing I can think of is that maximum limit has been set low and is somehow lowering itself. To set the maximum limit
On the home screen, tap settings
Tap Music, then tap Volume Limit
The volume limit control will then come up to raise the limit move the slider all the way to the right.
If you want to stop the volume limit moving you can put in a passcode by clicking on the Lock Volume Limit and entering a passcode (I'd just put in 1234, so you can remember it easily(
Hope this helps.
Sep 07, 2011 | Apple iPod nano 3rd Generation
How to increase the volume when all sound controls are high??
press start at the lower left corner and choose control panel to raise the volume sound
Mar 31, 2011 | Acer Aspire 5610-4648 Notebook
. unable to lower or raise volume, comcast remote on olivia tv
Open the thing up and clean off all the dirt on the volume buttons with a dry rag and clean the remote sensor.  Put in fresh batteries and now give it a try.
Nov 18, 2009 | Televison & Video
Cannot raise or lower the volume
resorted contacts on bottom of control board.
Feb 16, 2009 | Hitachi 50UX57B 50" Rear Projection...
Volume won't go up
CAMBIALE EL IC02 EEPROM 24C02 O EL 24C04 Y TE GARANTIZO QUE SALDRAS DE ESE PROBLEMA...
Aug 07, 2008 | Samsung TXG2548 TV
Kenwood KDC-MPV622 CD Player Logo
49 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
