I keep losing my internet connection with my dlink router, i can get on but have to change my location to reconnect, i get kicked off about every 5-7 minutes
  • Brian Perry
    Brian Perry May 11, 2010
    Hmm... it sounds like you may need to change settings in your router to extend the amount of time it gives for leases. Is this a wireless D-link or wired. Do you have other computers on this router that do the same thing or is this the only computer that does this?
  • 55 Answers
I request u return the router and get anything but a dlink.
that will solve anything
Posted on Jan 18, 2009
Dlink wbr 2310
change the password with a new one (not the default), then change the ssid with a new one (not the default). then reconnect
Aug 25, 2013 | Computers & Internet
How to speed up bsnl 2g internet in dlink dwm 156?
Try with the following steps to get better internet connection from your wireless router
1.) Reset the wireless router by using the power switch on it or by unplugging it and plugging it back in.
2.)Place the wireless router in an ideal location. The higher it is, the better, but don't put it near metal objects.
3.)Get as close as possible to the router with whatever device you're trying to connect.
4.)Keep the router and your connecting device away from other electronics. You should especially keep away from phones, fax machines and microwaves. etc.,
5.)Adjust the Wifi antenna if it has one.
6.)Change the router's channel, especially if other wireless routers are nearby.
Following these steps would give you stable internet connection and also increased speed in connection. You can check your internet speed from www.ScanMySpeed.com before and after following these steps.
Apr 04, 2013 | Computers & Internet
Bsnl internet is very slow in dlink dwm 156
So, If you have internet connection speed problem with your wireless try with the following steps,
I keep losing the internet
CONTINUAL DISCONNECTION OF WIRELESS CONNECTION
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Dec 24, 2012 | Arris SURFboard SBG900 Wireless Router...
I keep losing my internet connection when I use the wireless router. When I disconnect the wireless router, internet works great but when I reconnect it it keeps cutting out. I unplug it for ten seconds...
Try changing the channel to 11. Cordless landline phones often interfere with the default router channel. It can even be your neighbors phone that is conflicting.
Feb 06, 2011 | D-Link DIR-615 Wireless Router
My WBR-1310 keeps losing connection every 10 mins or so. Is there a fix I can download to my router? (like an update or something)
I got your issue, since your facing the frequent disconnection in the internet connection,
ftp://ftp.dlink.com/Gateway/wbr1310/Firmware/wbr1310_firmware_104.bin.
Please download the firmware using this link and log into the router setup page of DLink with 192.168.0.1 and update the firmware
I'm sure this will help you to fix the issue.
Thanks & Regards,
Prema
Oct 09, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Diconnect internet connnection every 2-5 min (d-link dir100)so pls help ...
try using different PC or laptop or move to different location dependign on the streght of the signal and also make sure that dlink is properly connected. or unstall anr re-instal your Dlink if it does not work your dlink may be defective.
Oct 08, 2010 | D-Link (DIR-130) Router
Globe symbol won't turn green.
I was banging my head for 2 days with about 35 different configurations and finally tried the following and it worked just fine. Also, tried connecting 3 computers and they all connected with "NO" issues. Even connected wireless with "NO" issues. Now I am at 20mb download speed...J compared to AT&T 1.5mb download speed.
This is my DLINK model -> (DIR-601 Wireless N 150 Home Router Wireless router)
1. Reset your Comcast Surfboard Cable Modem by unplugging it for 5 minutes.
2. Then reset your DLINK Router to the manufactures default settings. Then Unplug DLINK Router for 1 minute then plug it back in (Just plug your cat5 cable into port 1 and connect it to your computer) there should not be anything else plugged into the DLINK Router at the time you make the changes. Just 1 computer can be connected.
3. Went into the DLINK configuration 192.168.0.1 and changed the PPPOE setting that I was using for my AT&T Modem to Dynamic IP (DHCP). Once you make the changes save them and then unplug your DLINK Router it's off.
4. Turn on Comcast Surfboard Cable Modem and wait until all lights are on. Now plug in a cat5 cable from the Surfboard Comcast modem (NOT A CROSSOVER CABLE LIKE THE CD INDICATES) to the INTERNET port of your DLINK Router. Now turn on your DLINK router.
5. Then turn on your computers or restart them and it will pick up IP Addresses from your DLINK Router
Jun 08, 2010 | D-Link Wireless N 150 Home Router 4Port...
Internet connection
You trying to connect wirelessly, or wired? If wirelessly, look in your manual on how to log into the router as an admin, and change the channel its wirelessly broadcasting
Jan 06, 2008 | Computers & Internet
Internet connection keeps dropping
Two possible reasons
If you have hidden your network name (SSID) in the wireless configuration in the router and use WEP or WPA security there may be a bug that can result in extended disconnect periods. Recommended solution unhide the SSID and keep the WEP or WPA security.
Second there are numerous wireless devices in use. Keep your wireless phone base station away from your wireless router. Try changing the channel your router's radio uses to transmit -- Channels 1, 6 and 11 are preferred. Try one you are not using, if that does not work try the other. (If you can see the surrounding channels in you connection wizard you may want to start with one no one else is using)
Dec 01, 2007 | D-Link AirPlus G DWL-G122 802.11g/b...
Computers & Internet Logo
302 people viewed this question
David Payne
David Payne
