Hitachi hard drive htc426040g9at00 stopped working
  • 27,725 Answers
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Remove the memory modules from their slots. Take the opportunity to clean the slots on the motherboards and the memory module connectors. Use compressed air to blow dust away and clean contacts with a soft cloth. Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components. Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r Allow the pins to dry. They will air dry in a matter of minutes. If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer. Check the memory module and memory slot contacts. They are either copper tin or gold. The colour will tell you which they are. Mixing tin and gold can result in corrosion that prevents proper contact. Look for any sign of physical damage to the memory module, memory slots or the motherboard. Reseat the memory modules. You should hear an audible click when they are in place. Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard. The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible. Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/ There is a connection problem such as a bad cable for internal hard drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide this will be the first to fail Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty. or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Hope this helps.
Posted on Dec 30, 2012
MY HITACHI 1 TB HARD DRIVE IS NOT BEEN RECOGNIZED BY MY SONY LAPTOP. IT WAS WORKING WELL 2 WEEKS AGO , HOWEVER TODAY I UNPLUGGED THE HARD DRIVE DURIN TRANSFER SOME FILES. UNTIL THAT MY COMPUTER STOP...
hello, if the hdd is not being recognize by your Sony laptop, may be because the device is not responding any more, anyway this is still new you can have that Hitachi replace via the warranty, but your not suppose to tell them what happen cause that would fall for intentional damage. Just tell them it stop working. Thank you for using Fixya
Mar 06, 2011 | Hitachi 1 TB SATA Hard Drive
Hi, my laptop stopped recognizing my HITACHI HTS541612J9SA00. on device manager i get two general storage devices, and their properties say that they're both working properly plus they're both located on...
This sounds like a single drive with multiple partitions that's working properly. Just because it doesn't identify the device by name doesn't mean its stopped working. Have you lost drive letters? Also, if it stopped working then you wouldn't be able to boot Windows unless you have multiple drives with some type of redundancy like a RAID array that's mirrored. : ) You can right click My Computer or just Computer IIRC in the later OSs and Manage to bring up your management console. Go to Hard Disk management and check what's active and if you have any drives/partitions that haven't been assigned a letter. This is the place to tell you more about your drives than you probably knew was possible. Good luck!
Feb 14, 2011 | Hitachi HTS541612J9SA00 120 GB SATA Hard...
I want to know, where is the Service Center for Hitachi Hard Disk
www.hitachigst.com/
But with a 80GB they stopped making them i believe you can try that.
Dec 09, 2010 | Hitachi TravelStar 80GN 80 GB Hard Drive
I have a Hitachi DeskStar T7K250 - hard drive - 160 GB - ATA-133 and a masscool UHB 330U 3.5 IDE to USB case for it, however windows will only stop at ''searching for preconfigured driver folders.'' Help...
This is typically a corrupt mass storage driver in windows. You can try removing C:\windows\driver cache (may be c:\windows\system32\drivercache too.
Then reboot; and see how it works. This resolves most of of the issues. http://techrxgb.com (please join us on facebook for hints / tips and tricks)
Feb 25, 2010 | Hitachi Deskstar T7K250 160 GB Hard Drive
Hdd error
Dear i have send a link of your problem in camcorder for hdd error .
if to use this link instructions you are solve your problem.
Hard Disk Error / Hard Disc Error Warning, "recording failed".
These cameras often give Hard Disk Error / Hard Disc Error Warning.
We can recover the video data from hard drive - these cameras often use 1.8" ZIF Hitachi Hard Drive with following numbers (we also recover from all others!)
20GB HTC426020G5CE00 HTC426020G7CE00 HTC426020G7AT00 HTC424020F7AT00
30GB HTC426030G5CE00 HTC426030G7CE00 HTC426030G7AT00
40GB HTC424040F9AT00 HTC426040G8CE00 HTC426040G9AT00
60GB HTC426060G8CE00 HTC426060G9AT00
Feb 14, 2010 | JVC Everio GZ-MG130 Camcorder
My hard drive suddenly started beeping and stopped working
Your drive has failed. to try to get back some of your items put the drive in the freezer for a day. the chill will make the heads condense enough for about 3 hours of use for emergency backup.
Nov 07, 2009 | Hitachi 500GB External USB 2.0 Hard Drive
Hitachi easy drive 1tb problem
I have a 640 GB easy drive. It hit the floor and now when I turn it on, all I get is beeps and hear movement in the harddrive but it does not work
Jul 09, 2009 | Hitachi 1TB External USB 2.0 Hard Drive
Hitachi external hard drive recovery
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Aug 27, 2008 | Hitachi USB 2.0 to IDE 1.8" Aluminum...
Computers & Internet Logo
David Payne
David Payne
