Question about Brother LS-2125 Mechanical Sewing Machine
Upper thread will not grab bobbin thread and pull it through
I have tried everything, and it will not pull the bobbin thread through.  Can you help please?????
  • joanne_1937 Jan 23, 2009
    I have a Brother Embroidery Machine. I can't get the top thread to catch the bobbin thread. Any suggestions to solve this problem? Thanks Betty Lynch
    joanne_1937@cox.net
  • teacher4a Mar 06, 2009
    I have a white 3300 embroidery machine and I need to see how to put the bobbin mechanism together. I can not get it to pick up the thread and pull it up.
    Sergeant:
    Champion:
  • 334 Answers
Take the bottom plate off where the foot rides and watch the hook as the needle bar goes up and down you will be able to see why. to cure this problem take the plate off where your tension adjustment is because to cure the problem you have to adjust the needle bar either up or down to make the needle meet the hook when the needle is just starting up.
Posted on Jan 18, 2009
Bobbin thread is jamming machine
it indicates that you have a situation called " bird nesting" and that is a result of the needle thread tension being too loose
needle tension should be tight so that when you pull the thread to thread the needle you have to exert a bit of effort to pull the thread through the tension plates
you can adjust up or down from that feeling
thread thickness affects the tension and needle eye size also affects the tension as a small eye on large thread makes the thread movement hard indicating less tension or a big eye on a small thread affects the tension as the thread slips easily and needs more tension to pull the bobbin thread up to the centre of the material being sewn
Dec 20, 2016 | Brother Sewing Machines
Try sewing but bottom thread on fabric is crumpING UP
needle thread tension is not adjusted up properly tighten the setting until you have resistance when you pull the thread to thread the needle
Oct 02, 2016 | Sewing Machines
Model 230. Why is it losing the thread at the needle everytime I sew?
The thread sounds like it is not running freely so the upper tension is either too tight or blocked by lint.
If neither of these solutions work then try changing your needle as a blunt or wrong needle can also be a cause
Nov 29, 2015 | Consew Sewing Machines
When I start sewing the back of thread is all overlap and tangled what can I do?
A more detailed description would be helpful, but my guess is that you have lost all of your upper tension.
Unthread the machine. Raise the presser foot. Turn the handwheel until the take-up lever is at it's highest position. Set the upper tension dial/knob to 5. Thread the machine.
With the presser foot up, the upper thread should pull through easily and then grab when the presser foot is lowered.
Test sew.
The upper tension pulls the stitches up and the lower tension pulls the stitches down. When they pull properly, the stitch is even.
Oct 29, 2010 | Kenmore 19233 Computerized Sewing Machine
The bobbin thread is not catching. I have rethreaded the entire machine multiple times, tried different bobbins, etc. However, the needle and thread are not catching the bobbin thread. The bobbin thread is...
try a new needle
make sure the bobbin is not warped
make sure the bobbin case area is free of lint or loose thread
make sure you hold the upper thread tail while it's going down to pick up the bobbin thread
make sure there is a 2 to 4 in tail for the upper thread to grab
Aug 01, 2010 | Brother Disney PE-180D Computerized Sewing...
My machine wont pick up the bobbin thread, and when it does, and I start sewing, it keeps jamming, and the thread locks around the bobbin spindle. It keeps sewing in one spot, which I have to cut the...
check that the bobbin thread is pulled thru 'the tongue' of the bobbin case: that is what controls general tension of the lower thread. also make sure the upper thread is threaded thru the tension disk and the disk is 'grabbing it'.
Feb 02, 2010 | Sewing Machines
The bobbin is bird nesting on my viking emerald
Check that it is threaded correctly (both top and bottom) making sure that the upper thread is in the takeup lever and the bobbin is guided through the tension spring in the bobbin case. Watch the needle as you slowly turn the handwheel counter clockwise (toward you) and the needle point touches the fabric (make sure presser foot is down). Is the thread still relatively taunt? If it is loose, the upper thread tension unit does not have enough tension. Check the areas where the thread goes and make sure you remove any loose threads or fluff which could be inhibiting the tension discs from closing over the thread. If the tension unit still is not tightening enough, the tension unit may need to be replaced or the circuit board replaced. If everything is ok in the upper thread area, now look at the bobbin area. With no fabric, watch as the needle enters the bobbin area. Does it go down and the upper thread catch the bobbin thread and pulls it to the surface? Check for anything preventing the bobbin thread from being pulled up to the surface through the needle plate. If you have still not been able to resolve the problem suggest you take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
Nov 15, 2009 | Husqvarna Viking 1
Can't draw up the bobbin thread on my Brother LS-1217 sewing machine... it just won't catch
Make sure you have enough of a "tail" from teh bobbin... Probably 4 inches or so before starting. If that doesn't work, check upper tension and needle is properly seated.
The needle drags the thread down and then starts back up causing a loop at the eye which a shuttle goes through and acrries the upper thread over the bobbin. The upper thread then drags the bobbing thread up.
Sep 13, 2009 | Brother LS-1217 Mechanical Sewing Machine
Bobbin problem
Suspect the needle and hook timing is off causing threads not to catch to make a stitch.
Try these troubleshooting tips:
With machine off, remove the bobbin and bobbin case. Push the needle bar to the left. Lower the needle to the bobbin case and notice when the needle starts traveling upward does the tip of the hook in the bobbin area align with the eye of the needle? If it does not align, the timing is off. If it does, move on to check upper tension:
Check that it is threaded correctly (both top and bottom) making sure that the upper thread is in the takeup lever. Watch the needle as you slowly turn the handwheel counter clockwise (toward you) and the needle point touches the fabric (make sure presser foot is down). Is the thread still relatively taunt? If it is loose, the upper thread tension unit does not have enough tension. Check the areas where the thread goes and make sure you remove any loose threads or fluff which could be inhibiting the tension discs from closing over the thread. If the tension unit still is not tightening enough, the tension unit may need to be replaced or the circuit board replaced. If everything is ok in the upper thread area, now look at the bobbin area. With no fabric, watch as the needle enters the bobbin area. Does it go down and the upper thread catch the bobbin thread and pulls it to the surface? Check for anything preventing the bobbin thread from being pulled up to the surface through the needle plate. If you have still not been able to resolve the problem suggest you take it to an authorized husqvarna viking dealer for service. You can locate a dealer near you by visiting the husqvarna viking website and clicking on the Dealer link on the left-hand side of the page - http://www.husqvarnaviking.com
Good luck.
May 19, 2009 | Husqvarna Freesia 415
Bottom thread will not catch
Unplug the machine and remove the needle plate so that the bobbin case if fully exposed. Lift out the bobbin case and the cup that it sets in will be visible. Locate the "hook" on this cup. It is a finger with a sharp point at the upper edge of the cup. The hook is what grabs the thread from the needle while sewing.
  • Thread the needle.
  • Turn the handwheel by hand.
  • Watch the hook as it approaches the needle from right to left.
If the hook passes by the needle AFTER the eye of the needle is above it, you timing has slipped and the machine must be taken in for repair.
If the hook catches the thread from the needle, put everything back together and try threading again.
Nov 12, 2007 | Kenmore 12102
Brother LS-2125 Mechanical Sewing Machine Logo
469 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
