Question about Maytag Refrigerators
Msd2651heb maytag refrigerator not making ice
rickead1
  • 1998 Answers
SOURCE: maytag refrigerator ice maker opens and closes?
replace the icemaker you can order one directly from marcone or allbrandsppliance
Posted on May 18, 2010
heatman101
  • 43501 Answers
SOURCE: Maytag side-by-side refrigerator ice-maker inoperative
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on Jun 04, 2010
ZJLimited
  • 17970 Answers
SOURCE: My MAYTAG - MSD2651HEB is only cooling on the
From my expierance the problem is either mechanical or electrical in nature. First check all over the freezer and see if you have any frost. then push on the waiis and floor and see if you hear and crunching of frost or ice. If either of these tests show positive for frost or ice you probably have a defrost problem. The first thing to check is for a wire diagram or possibly for a code key that will tell you if your defrost heater circut is open or closed, and if you have frost you want it closed, If tyhe heater circut is closed then the only item left I can think of is the defrost iniator, or timmer depending on if its solid state or electromechanical. If the computer in a solid state lost memory on how often to defrost you may have to reprogram it or if this option isnt available replace the iniator assy.
Now if you dont have any frost - any where - you have covered most of the areas that can be, namely cleaning the unit. Now to the 1 clue that gives me the most insight is your "clicking every minute". This sounds verry much like a defective relay/overload/(possibly) capicator assy on the compressor or the compressor itsself. If you find the parts list look for all of these items and purchase them and replace them on the compressor. If it does the same thing - sorry its no go and your compressor is bad most likely. If it starts and sounds normal you may have another 5 to 6 years or more use. If Im wrong and the compressor is runnig and the click is something else then you could have developed a leak and lost all refrigerant. (I wouldnt believe so from your discription of the clicking, this usually dosnt happen on loss of a charge but it can). If Ive got you lost Im sorry. Tell me where I lost you and I'll try to help ya over the hump.
Keep us updated.
Posted on Oct 05, 2010
tbreeze47
  • 3083 Answers
SOURCE: Ice maker worked fine. After
I read a lot of blogs about your model, and one lady swore that she believed the line was freezing up, since she's thawed out part the her frige and got it working again for two days. If this is what's happening, you could have a faulty defrost timer problem.
Another blog said to ensure your water pressure is good, of course, but I doubt it's your problem.
There is a switch that locks the arm, another person reported, but they didn't mention where it was.
I found your model's diagrams and parts lists on the following web page, but couldn't find a switch in the ice-maker diagrams, but perhaps it's somewhere else on the unit.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=47966&diagram_id=667246#d667246
Here's what they mentioned about the switch on Ehow.com:
Ice/Water Malfunction
  • If the ice maker is not working, ensure it is turned on, that the water supply is turned on and that the freezer is set below 32 degrees Fahrenheit. If you have low water pressure, the water may not make it into the fridge, causing your ice maker and water dispenser not to work; contact a plumber for repairs. Evaporating ice cubes are caused by infrequent use and are normal. If the ice dispenser is not working, it is probably jammed; remove some ice from the bin, and run the cubed function until it clears. If neither dispenser is working, ensure the lock switch is off. If the problem remains, contact a repair center.
  • Good luck, and hope this helps.
    Posted on Nov 22, 2010
    • 135 Answers
    SOURCE: MSD2651HEB Maytag refridgerator - buttons
    http://maytag.custhelp.com/app/answers/detail/a_id/1674/session/L3RpbWUvMTI5NDcxNzExOC9zaWQvRklFTWhNams%3D
    goodlock
    Posted on Jan 11, 2011
    Maytag-refer & freezer get cold & not cold- off & on cycles
    are you able to pull the refrigerator out unplug the power cord from the wall and take the back cover off of the bottom back side near the floor of the refrigerator? The problem could be related to the start relay being defective run capacitor these are parts that start the compressor and keep it running. The problem also could be a defrost control board found in the control panel inside but the way it sounds it's the start relay from what it sounds like from your description I just need to know if the compressor is clicking and hot
    Appliance 911 Sea Breeze
    Sep 18, 2015 | Maytag Refrigerators
    Msd2651heb
    Is the humming coming from the compressor?
    Nov 28, 2012 | Maytag Refrigerators
    Maytag msd2651, icemaker stopsmaking ice & after a few days icesicles are forming and there are frozen puddles throughout the freezer. What is wrong?
    Sounds to me your model MSD2651HEB has two problems. If you see icicle forming near where the water enters the ice maker the problem is the water control valve is defective and allowing water to enter the ice maker even after the ice maker is already filled with the next ice harvest. To repair the ice maker overfill problem you will need to replace the=> 67006531 Dual Water Control Valve
    10_16_2012_7_51_14_pm.jpg67006531 Dual Water Contriol Valve
    . I am pretty sure you are having a defrost drain blockage problem. Most defrost every eight hours and over a period of time the drain line that comes down from freezer into a cup like object top middle and back of the fresh food section. If blocked by gunk or ice you will see trails of liquid leaking down the rear wall of fresh food compartment until it reaches the crisper drawers.This is not always the same with every model as you may see frozen ice flowing down the rear wall of freezers on side by sides. Every refrigerator is made different so these are examples only. The key is to find if ice or just gunk has blocked you defrost drain. Unplug and then remove the rear panel in back of freezer. We need to see if the water is overflowing the condensate drain tray or if the blockage is in the turn the drain leads down back of your refrigerator. Much more on this page=> Leaking Refrigerators! If you have questions please ask, Thanks, Sea Breeze
    Owner's Manuals (1)
    MSD2651HEB.pdf (4536.63 KB)
    You will need Adobe Acrobat Reader
    to view these documents. The Adobe Acrobat
    Reader is available as a free
    download.
    Get Adobe Acrobat Reader
    For other models Click HERE
    Oct 16, 2012 | Maytag MSD2651 HE Side by Side...
    Maytag refrigerator model msd2651heb not cooling. Hear fan running but not condensor
    if you mean the compressor isn't running most likely you have a bad start device part 67005560,pull out machine unplug it and remove the bottom back panel,look at compressor,pop off metal clip and remove cover on the side of compressor,slide off the device and shake it,if the device is cooked you'll hear pieces rattling around inside it,install new part,if it still doesn't start could have a bad compressor.
    Jul 14, 2012 | Refrigerators
    My freezer is low on freon. And I don't see ports to attach to and add freon. Are there ports put on during assembly or do I need to add those on myself. My freezer model number is MSD2651HEB. Thanks...
    Please tell me if you have not been able to attach gauges to determine that its low on REFRIGERANT how doyou know for absolutly sure its low??
    Sep 11, 2011 | Maytag Refrigerators
    I have a maytag side-by-side refridgerator. 5.5years old. model number MSD2651HEB. compressor failed two years ago and was replaced then. now, wife said strange noice came from back of fridge side a...
    Problem with Maytag is they were bought out by Whirlpool who say those are not are problems.
    Go figure. Anyhow call for service you should be covered with warranty on new compressor.
    Oct 31, 2010 | Maytag MSD2756G Side by Side Refrigerator
    Ice maker not making ice
    check the water solenoid for the ice maker on the back
    Jun 11, 2010 | Maytag MFI2266AES Stainless Steel Bottom...
    My refrigerator is not cooling and the door is closed tight. the model number is msd2651heb
    Sadly, the most frequent cause for this problem is compressor failure. There are other less costly failures that could cause a lack of cooling, but it would be nearly impossible to diagnose on-line. Try to find someone you know that possesses at least a basic knowledge of refrigeration to look at your unit.
    Jan 11, 2010 | Maytag Refrigerators
    Refrigerators Logo
    Top Maytag Refrigerators Experts
    John Tripp
    John Tripp
    Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
