Question about Refrigerators
My display is frozen can't change from crushed to cubed ice. Help me reset it?
I need my tablet set back to english usa
Posted on Dec 30, 2012
fridgetech
  • 473 Answers
SOURCE: crushed ice only
Behind the ice bucket is a metal housing that holds the auger motor and solenoid.  The solenoid is bad.  When you go for cubed ice that solenoid should pull up the metal rod on the ice bucket so full cubes will come out.  First check to make sure the metal rod on the ice bucket isn't somehow caught under the solenoid and not letting if move up and down.  You can take out the ice bucket and press for cubed ice.  You should hear a loud clunk noise.  If not then you know the solenoid is not working.
Posted on Oct 11, 2007
SOURCE: Ice dispenser only dispenses crushed ice
You may not need to replace the solenoid.  If you hear the hum, and not a loud click and don't see then rod move, it may be frozen with ice.  Test it manually with your hand, it should be free  to move up and down.  If not, then it is frozen with ice.  Remove the ice dispenser and let it thaw and dry out.  You should then be able to move to rod and it will work fine, at least until it freezes again.  Anyone know how to prevent it from freezing up? Its a continual problem for me
Posted on Mar 28, 2009
MNTECH
  • 1543 Answers
SOURCE: ice maker only crushes/does not cube
Remove the ice bin. Look at the back wall, behind where the bin was. You should see a rectangular hole, about 1.5 x 1 inches near the bottom of where the ice bin was. There should be a white plastic part inside the hole. This plastic part should be able to be lifted up with your finger, and drop down again when you release it. If is does not move, it may be frozen, or the electrical solenoid connected to it may have melted. If the part moves freely, just replace the ice bucket and try to dispense cubes again. (the metal arm sticking out the back of the ice bucket might have gotten on the wrong side of the white plastic part in back)
Posted on May 23, 2009
SOURCE: Ice maker frozen on "crushed" ice mode
Check the bar below the icemaker bin. There is a gold color metal bar that goes from the front of the bin to the back and goes into a lever at the back of the freezer. If the bar gets on the wrong side of the lever it will be stuck in crushed mode.
Posted on Jul 28, 2009
SOURCE: Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Posted on Jul 30, 2009
Why am I getting crushed ice when I have it on cube ice
there's a shifter rod that runs along the side of most ice containers that ships it from crushed to cubes try to manually move that rod if it does not move then check for the rod being frozen somewhere. when you press crushed there's a solenoid valve that is supposed to move and actuate that rod. you will have to press the light switch to the off position while someone presses the crushed ice and cute as buttons to cs that solenoid moves the ice maker and that solenoid will not do anything with the light on. the light on indicates the door is open and it's in the interlock. I'm here to help you if you will answer this post I can't help you if you don't answer.
Appliance 911 Sea Breeze
Dec 02, 2015 | Samsung 28 Cu Ft Stainless Steel French...
Ice maker crushes ice but wont dispense Crushed ice
Good Afternoon Friend,
I understand that the ice maker in your Frigidaire refrigerator, model# FRS23H7CS, is crushing your ice, but will not dispense the crushed ice. It sounds like the dispenser is possibly jammed. Follow the following steps for a possible resolution:
    1)The ice has melted and frozen around the auger due to infrequent use, temperature fluctuations, and/or power outages. Remove the ice container, thaw, and empty the contents. Clean the container, wipe dry, and replace it in the proper position. When new ice is made, dispenser should operate.
    2)Ice cubes are jammed between the ice maker and the back of ice container. Remove the ice cubes that are jamming the dispenser.
    3)Ice cubes could be frozen together. Use the dispenser often so that cubes do not freeze together.
    4)The ice cubes are hollow or smaller than normal. The ice & water filter cartridge could be clogged. Replace the filter cartridge. Dispensing system operates best at 20 - 100 psi water pressure. Well water pressures should fall within this range.
    If the above does not work, I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Turn the power back on and try dispensing crushed ice. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
    -Best Regards-
    WP
Jun 20, 2014 | Frigidaire FRS23H7CS Side by Side...
Ice crusher stuck on crush
your ice solenoid is frozen. It is located behind the ice bucket next to the auger motor. It will need to be removed, unfrozen, and squirt a little wd40 to prevent it from happening again
Mar 19, 2014 | Frigidaire FRS26H5AS Side by Side...
When dispensing ice, it only gives crushed ice and not cubed even when you are on the cubed ice setting.
most likely the solinoid to change from crush to cubed is bad or frozen. if you pull the ice bucket the metal arm on the back of bucket goes into plastic piece back by auger motor. that is where solinoid is. put finger in plastic piece see if you can move it up and down..
Jan 03, 2010 | Frigidaire FRS3R5EMB Side by Side...
My ice despenser has a switch for cubed and crushed ice. I have the switch on cubed and only crushed ice comes out
usually there is a device in the ice bucket that activates or deactivates for cubed or crushed..that is controled by another (stirup) behind the bucket, that may be frozen up, thaw the whole refer...then see what happens. It might be in the switch...as well, if so call some one
Oct 24, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice machine growles; crushed or cubes
Remove the ice bin and throw out the ice. Run water through the ice bin to clear out the frozen ice in the bottom. Dry the bin really well. Re-install the bin and start over.
Sep 23, 2009 | Fisher and Paykel Refrigerators
Ice dispenser gives crushed ice only
Your selector solenoid is bad. It is usually located behind the ice bin in a white box with the auger motor. Most of the time they are good still, but they get frozen. Try to defrost it.
Sep 07, 2009 | Refrigerators
Ice maker only operates on crushed ice mode
There should be a solenoid behind the ice bucket that moves an metal arm on the ice bucket to move the crush teeth away for cubes or keeps the crush teeth in place for crushed cubes. Bad solenoid, bad wire at the solenoid, broken solenoid/mechanism piece, bent arm, no power from dispenser to the solenoid are -some- possible trouble makers.
Also the solenoid that controls the crush/cube function is probably frozen. First, pull out your ice bucket. On the bottom of the bucket is a long metal rod the runs all the way to the back wall of the freezer. That rod runs into a little square hole in the back of the freezer. The hole is about 1 and half inches square. Just put your finger in there and see if the solenoid plunger moves up and down easily. If it doesn't move, then it is frozen. Just hit that area with a hair dryer and it will release. If it moves easily, then make sure that the the rod on the ice bucket is seated in there properly
Feb 09, 2009 | Kenmore Refrigerators
My icemaker is not making ice. This has happened 3 times in the past 3 years but this is the longest it has gone without making ice. The other 2 times it lasted 2 days. It has now been 4 daysince the ice...
Check the following:
 Is the freezer door closed completely?
 Is the ice storage bin installed correctly?
 Is there ice in the storage bin?
 Has the ice frozen in the storage bin?
 Is ice stuck in the delivery chute?
 Has the wrong ice been added to the storage bin? Use only
cubes produced by the current ice maker.
 Has the ice melted around the auger (metal spiral) in the
ice bucket?
Dump the ice cubes and clean the ice storage
bin.
 Is the ice dispenser stalling while dispensing “crushed”
ice?
Change the ice button from “crushed” to “cubed.” If
cubed ice dispenses correctly, depress the button for
“crushed” ice and begin dispensing again.
 Has the dispenser arm been held in too long? Ice will stop
dispensing when the arm is held in too long. Wait 3 minutes
for dispenser motor to reset before using again.
May 15, 2008 | Amana Refrigerators
Apr 06, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
37 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
