Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
If you removed the cover to replace the chain and you are trying to reinstall the cover and it won't slide all the way in, it's because the metal brake inside that plastic cover is still in the BRAKE position. Hold the cover in your hand, and move the brake handle over to release the metal brake. Hope this is what you were looking for.
Posted on Mar 03, 2013
SOURCE: carb rpl and adjustment
you have 2 screws marked H and L. With the engine running, turn the L (low) screw for best idle. Then for the H (high) screw, Hold at full throttle, turn screw, and listen for smothest and fastest revs.
Posted on Apr 28, 2010
SOURCE: My poulan chain saw will not start 42cc 14
K, I just looked at their site for another reason but they indicate that you need to make sure of the fuel, the on/off switch and also the spark plug (which I have personally seen) and dirty or clogged fuel lines. If you need to view the manual for the troubleshooting you can go to Poulanpro.com or call 1-800-554-6723. Good luck and let me know if you need more help
Posted on Feb 18, 2009
SOURCE: chain sprocket
I looked at a breakdown for the 42CC not sure if the same one or not but it appears that the chain sprocket is held on by an Eclip and behind that a flat washer. If this doesn't look like yours give me the model number and I will research another breakdown
Posted on Feb 25, 2009
SOURCE: Poulan Pro 42cc Just Won't Cut It
The chain is directional, only cuts one way. If a new chain won't cut, it must be on backwards.
Posted on Apr 28, 2009
SOURCE: 18"poulan chainsaw
Start at 1.5 CCW form lightly seated then tune for performance like this:
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too.
I think your starting procedure may be the cause of flooding. Flooded is the #1 cause of hard starts in 2-cycle engines. Read carefully the recommended start in your manual. most miss the second note. It should be similar to this (read 3, read it again):
Warm start in the manual says 1/2 choke BS. Close choke, (sets fast idle) open choke, pull rope.
Start Procedure
Cold:
Warm:
If you still have trouble reply as you did before. I will get back to you. HTH
Lou
Posted on Feb 19, 2010
Testimonial: "you'all have been very helpful.to even ask a question at a repair shop around here you must first hand them your wallet! Thank kindly"
Aug 12, 2013 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Sep 17, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Aug 28, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Jun 25, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Oct 19, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Mar 12, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Apr 27, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Mar 07, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Feb 25, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Feb 18, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
265 people viewed this question
