Question about Delta 15710-DST Nura Single Handle Centerset Lavatory Faucet, Chrome
Low flow after installation
Aerator is not the problem
Just bought 4 moen Oxbridge bathroom sink faucets. Water pressure is very low compared to old faucets. Checked the aerator but no adjustment is available. New shower head is the same issue.
These days, you may find a disk with a small hole intended to restrict flow. It may be installed above the aerator. Check the flow with aerator removed.
Aug 13, 2017 | Moen Plumbing
Bosch AE-9.5 keeps tripping the reset
All resets and breakers trip with high heat.
Do you mean the tankless unit is tripping the 40 amp circuit breaker?
Or the thermal cut-out, located on unit, is tripping?
Is this a new installation?
Or was the tankless working before and stop working?
Copy following link to check wiring.
AE 9.5 requires 40 amp breaker and 6 gauge wire.
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
If the unit is tripping the thermal cut, -out, then product manual says to call Bosch or service technician.
Call Bosch 866-330-2729
http://waterheatertimer.org/pdf/Bosch-Powerstar-AE3.4-7.2-9.5.pdf
Thermal cut-out can trip if water flow is too low.
Try changing power selector screw from Hi to Lo so only 1 element is ON. See diagram page 6 of manual.
Adjust the 'outlet service valve:' The manual recommends that a ball valve be installed between hot outlet and faucet. Adjust the valve so more water flows to faucet.
Remove aerator, clean aerator, don't use low flow restrictions or low flow shower heads, replace leaky faucet cartridge on single-handle faucet.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 29, 2012 | Bosch AE-9.5 PowerStar 1.5 GPM...
Just put in a new moen kitchen faucet, why does it have hardly any water pressue?
You might have a clogged aerator screen. Remove the aerator from the faucet and see if the flow is normal. You can rinse the aerator off if it's clogged. It's also possible the stops (shutoff valves) aren't open all the way. Sometimes, if they're old, they don't turn on fully again after you shut them off to put in the new faucet. If you still have low pressure after removing the aerator, you may need to replace the valves.
I don't know if the instructions mentioned it, but it's good practice to remove the aerator and run a faucet to flush the water line after installing it. There's usually a lot of debris that comes through at first. That's usually why you'll have low pressure in a new faucet.
Jul 14, 2011 | Microwave Ovens
My kitchen facet will not activate the hot water buner now and it takes two hot water facets in the bathroom to activate hot water. Is there a maintenance pronlem I need to do? Where are instructions how...
There is a minimum water flow required to operate your Bosch tank-less water heater. It is around .75 gallons a minute. There are three things you can do to help the flow.
1.Turning the temperature down will help increase the flow.
2. Installing higher flow aerators on your faucets.
3. Clean the Bosch tank less water heater.
You are not alone in having this issue. The most common problems are low flow faucet aerators and low flow shower heads.
Aug 31, 2010 | Bosch Water Heaters
I installed Series 26 Avalon faucet. The water flow rate is very slow. All fittings to the faucet are new. Could the problem be a faulty valve ?
Remove and clean the Price Pfister aerator. Turn the water on after you remove the aerator and check the flow-rate. Many new Lavatory and kitchen faucets are now equipped with Eco friendly water saver aerators. if the flow is normal without the aerator, the faucet is OK. if you want more water flow from your lavatory faucet, you will need to buy one of the old style high flow aerators from your hardware store. If you remove the aerator and still get low pressure from both hot and cold faucets, you may need to replace the faucet. Call the Price Pfister warranty phone number that came with your faucet.
Aug 28, 2010 | Price Pfister Plumbing
Hi just moved in new home love it but the water pressure in kitchen is very low but the two baths i have the water pressure is fine can you help me please
One thing you could try is to remove the aerator at the end of the spout on the faucet, Turn water on and see if pressure is any better. If so the aerator is got something in it restricting the flow.
You also can remove the dime shaped flat in the aerator to increase water flow. It looks like a dime with a hole about 1/8" in center to restrict the flow to about 1.6 gpm. Remove it and reinstall aerator and check water flow
Most of the times when cold and hot side of faucet.It would be the first thin to check being you have good water pressure at other faucets. They catch debris and the flow slows down from the faucet's. Check out supply lines and faucet for a blockage if this doesn't take care of the problem.
Check out this web sire for a parts breakdown of parts in faucet. Check out installation and rough in sheet for information on faucet below.
http://www.needplumbingsupplies.com/Kohler-Kitchen-Sink-Faucets.asp?id=3628
Jun 15, 2010 | Kohler K-12176-PB Fairfax Single Handle...
Low pressure,cleaned screen in tip,checked incoming supply,seems strong,yet pressure is low??
Has pressure always been low? If faucet is new than there will be a flow restricter in the aerator. Most flow restricters can be removed easily. Some are a pain. Have you tried checking the pressure with the aerator off. That would tell you if the problem is there or in the valve.
Apr 20, 2010 | Moen 7310 Legend Single-Handle Kitchen...
Restricted flow old kitchen faucet
While not always the case, low flow is usually caused by a plugged aerator. The aerator is the device that softens the water flow as it comes out of the faucet. Unscrew it, remove it, and clean any debris out of it.
Before you put it back, turn the faucet on briefly to flush any other debris out and to see if the water pressure is better. If not, there could be a cartridge (if equipped) issue of some piping problem.
Mar 14, 2010 | Elkay Plumbing
I installed a Price Pfister kitchen faucet model low water pressu
yes it should have a flow restrictor in the end of the spout. You might need to clean it out
Mar 08, 2010 | Plumbing
Low water flow and pressure
remove aerator and cart. and soak in limeaway over night
May 21, 2009 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Delta 15710-DST Nura Single Handle Centerset Lavatory Faucet, Chrome Logo
Top Delta Plumbing Experts
john h
Craig Butler
Craig Butler
Mike
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
