Question about Acer X173WB Monitor
No signal I bought a new computer today and plugged in the monitor but it tells me there is no signal. What do I need to do to correct this problem?
  • Anonymous May 05, 2009
    when turn on the pc the acer monitor display no signal then stand by mode
    Champion:
  • 203 Answers
Start the pc in SAVE MODE to do that kep  F8 at the startup and than change size of the screen.
Posted on Jan 18, 2009
Monitor states No signal. this is a new computer, just today
Make sure you are connecting the monitor signal lead to the correct signal output on the rear of the machine. Some desktops have extra video out connectors when they have a graphics card fitted. If yours has a graphics card the display connector will be away from the back USB ,audio and keyboard ports and near to some silver pop out panels near the bottom of the tower.
Apr 20, 2013 | Acer Aspire m5640 PC Desktop
Monitor screen lights up for only a second then gives "No Signal Input" error message. I've rebooted both the computer and unplugged the monitor to start to no avail
Have you tried plugging the monitor to a different computer? This will tell you if the monitor is bad if it works correctly in another computer then most likely your video card has gone bad and needs to be replaced.
Jul 11, 2011 | HP Pavilion Slimline s3700f PC Desktop
It was working fine yesterday. Today is states VGA no signal. What is the problem.
A number of things can cause "No Signal" on a monitor
1) Check the cable between the monitor and PC is properly connected
2) If the PC has more than one display port try changing the display port the monitor is plugged into
3) Try an alternative cable between the monitor and the PC
4) Check that the correct input is selected on the monitor
Dec 17, 2010 | HP w17e Monitor
My monito is not getting signal
if your monitor says no signal and goes to sleep when your pc is on then the first thing to check is if it's plugged into the correct socket. I've had people tell me yes to this question and when I see them all I do is plug the monitor into the right socket. They had an additional graphics card as well as the on board graphics output. If this is not the issue then the graphics output is probably shot, add new graphics card or replace motherboard.
Nov 04, 2009 | Gateway FPD1760 Monitor
Monitor no longer works with the desktop, only with the laptop!
Maybe your new monitor don't supports the signal of your computer. Try finding another one, or otherwise, buy a graphic card, that will be supported from your monitor.
Hope this solve your problem!!
Jun 13, 2009 | BenQ FP731 17" LCD Monitor
CHECK SIGNAL CABLE
Typically this happens when the resolution of the display is out of range of the monitor. Normally this is when the resolution is too high. Have you changed the resolution settings? Also, not to be crass, but if there a video card in the system, be sure that you are connected to the correct VGA connector. With an extra card in the system, the onboard VGA connector is not used.
Keep us posted,
Dan
Jan 23, 2009 | Samsung Syncmaster 730B 17" Flat Panel LCD...
AGP problem
you need to uninstall addon card
Jan 06, 2009 | ASUS P4S8X-MX Motherboard
No Signal
Probably the settings on the computer graphics card output.
You need to selct the external screen.
Just to be sure it's not a screen fault, are you able to test it on another PC (desktop, not laptop)?
Jan 05, 2008 | Acer AL1916W 19" LCD Monitor
Acer X173WB Monitor Logo
66 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
