Question about Vizio 60" E601I-A3 Full HD LED-LCD TV
No picture on Vizio 60" E601i-A3
It was working fine when i left the room, but came back and the picture was out. I assume the sound is too, but have the sound turned off. I disconnected everything, unplugged the tv from the surge protector for 10 minutes and the tv power light comes on, the screen gets slightly lighter, but nothing else. No commands are working on the remote, except for power. I also used the universal remote and tried to push the buttons manually on the side, but nothing. TV is about 6 weeks old. Possible that a board is blown?
  • Roger Selover Jan 14, 2013
    I have same problem what was the fix email Paladin_RDS@yahoo.com ?
  • bridgette Jul 21, 2013
    These TV's have a chip that is defective if the TV is less than a year old call Vizio they will either have it repaired or replace the tv
    Sergeant:
  • 183 Answers
Yes take it back 6 weeks i would return it
Posted on Dec 30, 2012
Testimonial: "Thanks losuer. I called and they are replacing it. -josh"
  • 4 Answers
SOURCE: only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
Posted on Jan 03, 2009
SOURCE: only vizio light on
RJW34 I have a 37" Viizio LCD that has a similar problem. I power it up and I get a lit screen but it's blank. No controls work except power on and off.
Posted on Feb 20, 2009
rylee_smith
  • 8619 Answers
SOURCE: vizio 42 hdtv mo picture,no sound
Hi
Thanks for using FixYa. Please check the following—
1. Is Power board output +5V?
2. Is J1 (#19 in the right diagram)connector good?
3. Is DC-DC OK, check the voltage at J1 using a multimeter.
4. Is U4 (3.3V) working ok, U4 is an IC, you’ll need an IC tester or an oscilloscope to check this IC.
After checking this if it still doesn’t work then check P3 D-sub Input (on the D-board). See this schematic for details--
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Oct 17, 2009
  • 88 Answers
SOURCE: tv screen went blank
sound like the inverter circuit board problem. check & replace back same part# inverter circuit board. hopefully could help!!
Posted on May 17, 2010
budmrtn
  • 11361 Answers
SOURCE: I have a Vizio VO370M. The power briefly went out
Try unplugging it for about an hour to let it reset itself first, if it is still bad, you will have to do in-depth troubleshooting to narrow down the cause.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make a kit for you.
Posted on Aug 14, 2010
I replaced the T-con board on my Vizio TV, but I still don't have any picture, just sound. What else could it be?
Think something may have gotten unhooked when you put everything bacK together? Check out all connections and ribbons between boards for proper contact.
Jun 22, 2016 | Vizio 60" E601I-A3 Full HD LED-LCD TV
Fix a vizio tv e601i-a3.has sound no picture
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jun 01, 2016 | Vizio E601I-A3 60-inch Class Razor LED...
How to fix no picture on vizio e601i-a3
Try the flashlight test for image in a darkened room. If you see image checkout the inverter board.
Mar 28, 2016 | Vizio 60" E601I-A3 Full HD LED-LCD TV
My TV isn't displaying sound or picture, how do I fix this?
Assuming your PS is fine then I would look at the main board since it works with the audio and video signals. The T con board is video specific and you have backlighting. So..............
Nov 17, 2015 | Vizio 60" E601I-A3 Full HD LED-LCD TV
Lip sync
Vizio HDTV- Lips out of sync
Anyone with a new Vizio E601i-A3 60" or 70" HDTV that is having audio "Lips out of sync problems" with a cable or satellite box.
On Comcast cable boxes (or others), here's what you need to do: FIND MENU for AUDIO or HDMI setup on CABLE BOX or Satellite Box.
FOR COMCAST
1. Turn on TV and have Cable box Turned OFF.
2. Press MENU on COMCAST REMOTE.
3. Go to AUDIO Setting OR HDMI Setting. (On cable or Sat. BOX)
4. Change setting from Auto to L-PCM. (Turn off cable box to exit)
This should resolve any "out of sync" lips to picture after commercials on HD channels.
*This is a handshaking issue from the cable box to the Vizio E601i-A3
Dec 08, 2012 | Vizio 60" E601I-A3 Full HD LED-LCD TV
Open Questions:
See all Vizio 60" E601I-A3 Full HD LED-LCD TV Questions
Vizio 60" E601I-A3 Full HD LED-LCD TV Logo
2,726 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
