Question about Sewing Machines
Threading a pfaff grand quilter hobby 1200
Having thread breakage and not a clear picture in manuel
3 Suggested Answers
SOURCE: can not get thread tension on hobby 1200 grand
Adjusted the dial to the right until the stitches we better.
Posted on Dec 27, 2009
  • 1456 Answers
SOURCE: I have a Pfaff grand Quilter and my top thread is
Hello
If you have changed the needle and rethreaded the machine, then take apart your bobbin and make certain there are no small pieces of thread or lint in it. Check your tension. Do you have an automatic thread cutter? I had the same problem and it was because my automatic thread cutter was cutting the thread too short. Some how the cutter had gotten bent...I could not tell it, but it was.I put the blade of a flat head screw driver under the cutter and GENTLY bent it back down. Fixed the problem. Works perfectly.
Posted on Jul 15, 2011
My Pfaff grand quilter 1200 keeps bunching up the top thread on the bottom side of my quilts. I've replace the needle and thread. It won't pick up the bobbin thread. Could this be a timing problem?
Remove the thread from the machine. (Always raise the presser foot and pull the thread up, NEVER down!).
Install a brand new needle.
ALWAYS RAISE the presser foot when threading.
Rethread from the beginning and verify the thread pathway is correct.
Set the upper tension to midway between High & Low numbers--you may need to tweak this for your particular machine, but this is a standard starting point.
Confirm the bobbin is loaded and threaded correctly in the bobbin case.
Begin sewing slowly. It helps if you begin sewing with the needle in the uppermost position.
Test on medium weight woven cotton.
If it is still not picking up the bobbin thread, then it most likely is a timing problem. You can search the internet for web sites and videos regarding sewing machine timing or take it for service.
Sewing Machine Thread Bunching Up Here Why
Birds nest under the fabric big loops of thread top side looks good...
What causes Bird Nests Superior Threads
Nov 21, 2016 | PfaFF Sewing Machines
What are the correct thread tension numbers on thePfaff hobby grand quilter 1200
Usually, the standard tension for upper thread is midway between high & low numbers. However, every machine differs and may need to be tweaked. Unfortunately, finding the correct tension is generally a test and adjust method. Be sure you are using a brand new needle and good quality thread.
Oct 10, 2016 | PfaFF Sewing Machines
How do I raise and lower the feed Dogs on the PFAFF hobby 1200 Grand quilter
According to the following web site, the feed dogs do not drop on this machine, Instead, there is a plate that covers the feed dogs:
Fluffy Sheep Quilting Do you have one of these Do you like it
Also thought this was interesting:
Oiling the PFAFF Grand Quilter 1200 Bernina Sewing Center Tampa
Dec 10, 2015 | PfaFF Sewing Machines
How to thread a PFAFF Hobby 541 machine.
Here's a manual to download. It should have threading instructions:
Pfaff hobby 541 Owner Manual
Aug 09, 2015 | PfaFF Sewing Machines
How to thread a pfaff 1200 grand quilter sewing machine
contact Pfaff website about a manual or try youtube for a video
Aug 25, 2014 | PfaFF Sewing Machines
Thread has wrapped around in behind the cb hook system and I can't figure out how to get if off to clear the thread. There is so much thread that I can't even move the needle up or down, it is jammed. Is...
If you can open the machine cover you may be able to get access to the hook. That should allow you to remove the thread without having to remove the hook.
Mar 27, 2011 | PfaFF Sewing Machines
Sewing Machines Logo
118 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
