Question about Dell W3707C 37 in. LCD Television
Stuck on power save mode - Dell W3707C 37 in. LCD Television
5 Suggested Answers
  • 732 Answers
SOURCE: stuck in power save mode
stlmeuzyk, Internal "switch-mode-power-supply"/"ccfl-inverter-supply" will probably need to be refurbished (repaired). Use Dell warranty first if valid option! Try monitor on different pc or verify your pc is working properly with old, but known-good monitor. If your E228WFP unit is still not working then you or qualified electronics technician will need to tear-down monitor to evaluate and repair the ac to dc power supply printed circuit board. Before you do anything read my fixya profile to learn flashlight test that every ccfl back-lit lcd monitor owner should know how to do and interpret the results of test. The basic design and operation of your E228WFP isn't any different than any other brand!!! Read the older solutions in my profile and follow the links you find there. Then do additional comment if need more info. Good luck with the repair. 12fixlouie
Posted on Mar 26, 2010
supertech6
  • 513 Answers
SOURCE: Dell Monitor is stuck in power save mode. tried
Hmmm...Stuck in power save. I guess when you push the power button, the monitor says power save, then blanks to power save, no matter if the Computer is on or not.
This means the monitor does not see any signal from the computer. I would suspect the computer first. Try a different monitor (borrow one).
If the size of the monitor picture is too high and the monitor is an older LCD, you may have set the image size too high (1280x1024 will not work with this monitor and it will do this very thing).
A broken or damaged connector cable to the monitor can also cause this. Was the monitor unplugged from the computer just before this problem?
Posted on Mar 30, 2010
  • 86 Answers
SOURCE: igot a deel and its stuck in power save mode
It maybe a power source issue, this is not easy to detect, consult a local expert. You may also want to check your home power infraestructure.
Posted on May 13, 2010
budmrtn
  • 11361 Answers
More likely to have failed power supply/invreter board.
http://www.lcdrepair.us/E228WFPc-inverter-power.html
Look for bad caps first (leaking/bulging tops).
Possible lamp assemblies failed also.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on May 16, 2010
I open my computer today but suddenly the monitor says " entering power save mode" and its stuck there. ive tried to do simple ways to fix but still nothing. can someone help me? im using windows 7
Switch off and remove the power cable then put in the power cable again and switch on again...try to disable the power saving mode once it is on.
Apr 05, 2013 | Dell Computers & Internet
Gateway desktop enters power save mode while in use.
boot and adjust the power settings for all "when on A/C" to never. to take it out of power save press any key on the keyboard or press the power button (but dont hold it down)
Jul 08, 2012 | Gateway Computers & Internet
Tried unpluging and nothing tried al buttons nothing the computer was at a shop to BE FIXED AT SHOP OK CAME HOME STUCK IN POWER SAVE MODE BUTTON ORANGE ON MONITOR HIT GOES GREEN SAYS PAWER SAVE MODE HIT...
Press and hold the power button for 5 seconds this will turn the system completely off wait 5 seconds then turn it back on as soon as it boots up go into power options in the control panel and click the option from power saver mode to do nothing as there is a fault with some computers that it gets stuck in power saver mode
Jun 27, 2011 | Computers & Internet
Igot a deel and its stuck in power save mode
May 13, 2010 | Dell Dimension 3100 PC Desktop
My Dell monitor is stuck in Power Save Mode. Any
The monitor is not receiving signal from the computer. Verify the computer is on and the monitor input is set to the correct mode or auto. Try another monitor if possible.
Aug 10, 2009 | Computers & Internet
My Gateway 500s monitor is stuck in power save mode
Try tapping the F8 key while booting the computer, you will get the start up menu, choose safe mode, when you log on, go to the display settings, that is right click on the desktop, properties, screen saver, advanced and make sure that hibernation is off, along with turn off disks or whatever , probably see turn off monitor after XX minutes, I make ours 15 minutes (150 computers and servers), I don't let the disks turn off. Choose always on also, not home/office. Try this and see if these settings help.
1r1sh
A+
Net+
MCP
Jan 24, 2009 | Gateway 506GR PC Desktop
My ibm desk top is stuck in power save mode monitor won't work
So the only way you have to act is, turned off and directly on the mainboard, so do it carefully.
You'll have to find out, where, on the mainboard is located the battery, (a small coin like
unpluggable metallic piece)
Remove it and let all static electricity completely disapear, so, let the cpu power unplugged,
battery removed, for 1h,
Then, place back, battery, try to start again if not working it's hardwaire failure.
Nov 20, 2008 | Computers & Internet
Stuck in power save mode
Have you have selected the input you are using? You can switch between analog and digital input. The monitor would stay in power save if the input other than the one you are using is selected.
I believe the default input is DVI. Are you using VGA?
In the menu, under advanced, you can select the input.
May 04, 2008 | Princeton Digital VL1916 19" LCD Monitor
Power saving mode
go to comtrol panel and change the settings in the power saving control options... everything wi be fixed without any big problem
Feb 20, 2008 | Gateway FPD 1730 17 in. Flat Panel LCD...
Dell W3707C 37 in. LCD Television Logo
44 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
gwix50
Level 1 Expert
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
