Question about KitchenAid KESA907PSS Electric Kitchen Range
Power to kitchenaid stove, model #YKESA907PS stopped suddenly
We were cooking with the oven on and all 4 burners in use. Without warning everything quit and neither oven nor range show any power. Double checked circuit breaker and all is fine and even removed breaker from panel and breaker is fine. Does this stove have a hidden breaker or fuse somewhere (manual does not show this) or can you offer any suggestions.
Thanks
  • 1,031 Answers
If the oven light, stovetop fluorescentlight, clock or range outlet does not function correctly, often theproblem can be a blown fuse or a tripped circuit breaker. Many electric ranges include a fuse in the 120-volt circuit that operates such items as oven and stove top lights, the electric clock, convenience outlets, etc. In order to check the fuses on your electric range, the following steps should be taken:
  1. Before repairs or testing can begin you must disconnect theelectricity at the fuse panel, at the circuit breaker panel, or bypulling the plug. Make sure the power is off before proceeding. A jolt from 220 volts can be fatal, use caution!
  2. Refer to the owner's manual or to the wiring diagram for yourelectric range to locate the fuse you need to examine. The type of fuseused in electric ranges is usually the plug-type. This type has athreaded metal base (similar to a light bulb's base) and a flat topmarked with an amperage rating. The fusible link is visible through aglass window in the top.
  3. Visually inspect the fuse to see if it has blown. The fusible linkis visible through a glass window in the top. If the fuse is good, thislink will be intact. If the fuse has blown due to an overload, thislink will be visibly broken. If the link is broken and the glass windowis also blackened, this indicates a short circuit. In either case, theproblem that caused the blown fuse MUST be identified and correctedbefore installing a new fuse of the correct amperage rating.
REMEMBER YOU ARE WORKING WITH VOLTAGE - USE EXTREME CAUTION!!!
Posted on Jan 18, 2009
  • Starnley Johnwells
    Starnley Johnwells Jan 18, 2009
    Servicing Fuses
    If
    the range or oven is receiving power but doesn't work, the unit may
    have its own fuse or circuit breaker assembly. This assembly is usually
    located under the cooktop of the range. In some units, lift the top of
    the range to gain access to the fuse assembly; or lift the elements,
    remove the drip pans, and look on the sides of the cabinets. Inside the
    oven, look to the back to spot the fuse assembly.
    If
    the unit has this additional fuse or breaker system, components such as
    the oven light, the range heating elements, the timer, and a
    self-cleaning feature may be separately fused.
    If these
    components or features fail to work, don't overlook the possibility
    that the fuses have blown. To replace a blown fuse, unscrew the old
    fuse and install a new one of the same type and electrical rating. If
    the unit has circuit breakers, push the breaker or reset button, which
    is usually located on the control panel.
  • 10,515 Answers
Have the same problem w/my range as ds2 had w/his (below). All range elements quit working, but the cooktop still works fine. ds2 mentioned that he replaced a relay which corrected the problem. Can someone guide me on where this relay is and where I can buy one or any other suggestions for repairing the range. thanks
Your model# is just a partial number, if you could post the whole model# that would help us.
The relay is located on the electronic control board itself, you can test it with a volt meter with the oven turned on, before though, thats 240 volts, I suggest letting a qualified tech. do it, if you don't feel comfortable doing it.
What i do is ohm test the thermal fuse first if its equipped with one in the very back. Then ohm the bake and broil elements for continuity. Then if all that checks good, I do a voltage reading at the bake and broil elements themselves, if it doesn't get 240 volts between the 2 element terminals on the bake and broil separately, then you would need a new electronic control board.
ds2 didn't change the relay separately, he had to change the whole control board.....
Thanks.
Pad on oven does not work cant start oven
PDF]ELECTRIC RANGE USER INSTRUCTIONS - KitchenAid
https://www.kitchenaid.com/.../Use%20and%20Care_EN.pdf
KitchenAidIf you should experience a problem not covered in TROUBLESHOOTING, ... You will need your model and serial number, located on the oven frame behind the top right side of the oven ..... Do not press the Off keypad because the oven will turn off. START. Cooking start .... They could leave aluminum marks that cannot be.
Oven Won't Turn on - Repair Parts - RepairClinic.com
www.repairclinic.com/RepairHelp/...Fix...Stove-Oven/...---/Oven-won-t-t...
Most Frequent Causes for Oven won't turn on. ... The igniter is the most commonly defective part for a gas oven that won't turn on. ... For bake & broil burner ignition anoven burner spark electrode is used to ignite the gas.
Dec 01, 2015 | Ovens
What's wrong and how do I fix it?
The circuit breaker outside in the power panel for the stove has a bad breaker. It will be two breakers with their handles joined together by a pin so if one tripe it takes the other so 220 V is no longer present. When one, but not the other trips you only have 110 V. That's why the lights and clock still work but no heating elements.
Nov 16, 2015 | Frigidaire Kitchen Ranges
Stove top want heat up
the bulb i am sure is ok . but you have had a power failure to the burner . it could be the burner itself . if all the burners do not work the power to the range may be the problem .. ck the main fuse and make sure the 220 power is ok mm
Jul 12, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Stove top burner ignitors will not turn off
This tip I wrote to help people with the problem of the spark not shutting off...the clicking non-stop is a common problem.
Gas Range2_bing.gif Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Apr 30, 2010 | KitchenAid KGST307 Gas Kitchen Range
Wolf 4 burner stove developed a non stop ignitor clicking
If you have Wolf model AS30KI, most cases the top burners are misaligned or one of the electrode is bad.
Aug 31, 2009 | Wolfgang Puck BTOBR0040 Toaster Oven with...
Stove top gas burners are making my pots black with sut
the flames seem to be to high
try adjusting the air shutters underneath the cook top
May 27, 2009 | Magic Chef 9122 Gas Single Oven
KitchenAid KESS907 Electric Range E1 F1 Error Code
F1 E1, replace Electronic Range Control.
In other words, the controller board has failed.
Jan 29, 2009 | KitchenAid KDRS807SSS Dual Fuel (Electric...
My KERS 807 SSS Stove works fine but not oven
sonds like a bad hightemo thermostat, loacted on the back wall behind the rear panel, common issie for ovens ,espessially after going through a self-cleaning,part number 9759242, part is about $50 turn off power before attempting to change, LIVE WIRES!!!!
Nov 30, 2008 | KitchenAid KERS807SSS Electric Kitchen...
Frigidaire Electric Range model FEF366EC - Oven disabled
You probably have a short that is causing the stove not to heat up or you not to be able to control temperature settings. The stoves are made only to last as long as the warranty, and when it expires, the stove all of a sudden wants to break down. You might have to get a whole new stove.
Jul 14, 2008 | Frigidaire FEF366EC 30" Freestanding...
KitchenAid KESA907PSS Electric Kitchen Range Logo
333 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
