Question about Keurig B60 Coffee Maker
My keurig does not have the rubber piece that goes around the needle
Can I get a replacement for this rubber piece being missing?
5 Suggested Answers
  • 60 Answers
SOURCE: RUBBER GROMMETT THAT GOES AROUND NEEDLE THAT
It cant be purchased you will have to call keurig for a replacment 1800 cup brew
Posted on Mar 23, 2010
cmccune04
  • 213 Answers
Send me an email and I can have you one Today. My websites are listed below. I don't have your part listed but I can't certainly get it and process your order Today.
My shipping is USPS priority mail 2-3 day delivery so you can expect it quickly.
If you need a part just email me at help@igotsweetdeals.com
If you’re looking for Keurig Parts, you can find them on this website.
http://www.igotsweetdeals.com or http://igotsweetdeals.ecrater.com/
We have most parts for Keurig b30, b40, b50, b60, b66, b70, and b77.
If your parts not listed just send us an email and let us know what part you need. In most cases we can have the part pulled and shipped the same day!
Our parts are used and the prices are exceptionally fair. Ask about our scratch and dent parts to save more money!
If you have any questions about your Keurig or your having a problem just give us a call and we may be able to help you.
I hope this helps you. I know that needle seal is essential.
Posted on May 14, 2010
cmccune04
  • 213 Answers
SOURCE: Keurig B100 NEEDLE BROKE....
Can You send me a pic I may have that part. And I have a store you could buy it off me from. My email is cmccune04@yahoo.com and my site is http://www.igotsweetdeals.com If you send me the picture I can double check and have it listed very quickly. Thanks and good luck to you
Posted on May 18, 2010
cmccune04
  • 213 Answers
SOURCE: lost orange seal for keurig b50
Here is the part your looking for: http://iwantsweetdeals.com/Keurig-B30-B40-B50-B60-B66-B70-B77-Replacement-foam-Needle-seal-P1227320.aspx
Hope this helps you
Posted on May 26, 2010
Water sprays
Ken - this too sounds like the rubber gasket that goes around the water output is either missing or defective. I had that issue with a keurig at work. There is a small cylindrical rubber gasket that goes around the water output in the top of the brew head that helps seal over the top of the k-cup when closed. Make sure this didn't come off.
Mar 28, 2014 | Keurig Coffee Makers & Espresso Machines
Keurig K10 water spills out top and sides while brewing
Check to make sure the rubber gasket is still on the water output in the brew head. It goes around the water output needle in the top of the brew head. Without that gasket, there is no seal on the top of the k-cup and water can leak. Run it with no K-cup in it and see of water does not leak this way. If it doesn't leak then it points to a missing seal. Hope this works for you.
Mar 22, 2014 | Keurig Coffee Makers & Espresso Machines
I have a K10 mini cup keurig brewer. It worked fine until this morning. When I try to brew a cup, it comes out the top. It does with this with or without a k-cup in. I tried to clean out the needles...
First: You need to check a Upper Rubber Gasket (fits around the top puncture pin). If it missing you will have leakage because here's no seal to protect leakage. You can buy it online or call Keurig Customer Service (if you still have warranty)
Second: Upper Rubber Gasket not making a seal with the K-Cup or Reusable Filter and the water and/or coffee grounds leak out. To fix it simply move Upper Rubber Gasket 1/4" down. This should close the gap between K-Cup and upper needle.
Oct 27, 2013 | Keurig Coffee Makers & Espresso Machines
Keurig leaking from bottom
Check the Upper Rubber Gasket (fits around the top puncture pin). If it missing you will have leakage because here's no seal to protect leakage. You can buy it online or call Keurig Customer Service (if you still have warranty)
OR:
Oct 07, 2013 | Coffee Makers & Espresso Machines
I have a Keurig B60 coffe maker and when i make coffee it seems to leak out the sides such that that coffee is not directly coming out the bottom holes. I have cleaned the bottome holes to ensure...
Hi, Yes, you are missing the gasket around the top needle...
Here is a tip that I wrote about how and where to get replacement parts foryour Keurig Coffee Brewer
Keurig CoffeeBrewer Replacement Parts
heatman101
Sep 20, 2011 | Keurig B70 Coffee Maker
Rubber grommett that goes around needle that punctures K cup missing. Where can is purchase one?
May 12, 2010 | Keurig B50 Coffee Maker
Special Edition B60 Coffee Maker: Coffee grounds coming up through the k cup???...
make sure the k-cup is being punctured at the bottom... If the answer is YES... then take the K-cup holder out of the Keurig unit... verify you can put a paperclip into the needle of that piece from the inside of the shell and it comes out the bottom
that shell is actually 2 pieces and unsnaps... making it earier for you to check... once we know there is no obstruction in the bottom needle, then we need to make sure the rubber gasket in the top arm is ok... didnt come off..
the top needle that punches a hole in the k-cup, has a round rubber seal around it..
If it's not there, then it got stuck on the top of a k-cup, and you need to search the garbage for it...
in summary
clogged bottom needle
missing rubber top seal
If the rubber seal is there... hmm. while your making coffee next time....press down on the top arm... just enough to see if the ground stop... id that's the case, then we need to step back and think if we are dealing with either a bad seal, or a fatigued top arm..
My hunch is a bad seal... and possibly try to attempt to reseat it back into the arm... it cound be smashed in and needs to be coaxed back out..
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/lisa_52daba487e5b4d53
May 06, 2010 | Keurig Special Edition B60 Coffee Maker
RUBBER GROMMETT THAT GOES AROUND NEEDLE THAT PUNCTURES K CUP MISSING. WHERE CAN IS PURCHASE ONE?
Mar 21, 2010 | Keurig B50 Coffee Maker
I need the little rubber part that goes over the neddle
I lost the little rubber gasket that goes over the top needle. WHere can I get a new oone. THanks
Sep 21, 2009 | Keurig B50 Coffee Maker
Keurig B60 Coffee Maker Logo
134 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
