Question about Vizio Televison & Video
When I turn my 27 in Vizio on it takes ten to twenty minutes for a white screen to come on then I turn it off and then on again it it tunes to a regular program. What card needs to be repllaced and where do I get one. The TV is only a couple years old.
    Sergeant:
  • 183 Answers
Power supply
Posted on Dec 30, 2012
  • 105 Answers
SOURCE: No picture when on for approx 15 minutes
It sounds like you are saying the "video looks scrambled but the audio keeps playing OK"
Normally this is a Video Processor Problem that requires a Board to be replaced.
When the problem happens, can you see the TV menu or the TV's On Screen Display clearly.
I suggest checking to see if the problem happens with the video inputs like, Composite(yellow/red/black), component(RGB/yellow and black), HDMI and S-video. If it happens to all inputs then you need to replace a board.
Posted on May 22, 2009
  • 10 Answers
SOURCE: Vizio screen went off but power light is still on
may be a mainboard problem. If you can see the orange light it usualy means that there is power running through the TV... usually inverter boards are a problem when you do not see any backlight at all.
Posted on May 23, 2009
  • 2973 Answers
SOURCE: 27' vizon tv black screen
It seems to be a PSU (Power Supply Unit) problem. When you unplug it and replug, the screen comes on for a moment. That means that the capacitor does not hold charge for long. Open the back and look for bulged or burst capacitors on the module where the power cord meets inside. Replace the whole module if you can not replace the capacitor with exactly the same specs.
Posted on Nov 07, 2009
  • 11 Answers
SOURCE: Vizio SV470m with a pixelated screen after being on for 5 minutes
verify if it only happens on the antenna/cable input and if it works fine with dvd or other input, then it is a signal issue with the cable or antenna u r using and repair that problem and not the tv
Posted on Apr 18, 2010
SOURCE: Vizio flat screen tv screen goes all green (no
if you have comcast you can use your remote to change the tV program from cabke to DVD then change it back to cable. your image should come back.
Posted on Apr 24, 2010
My TV was taking forever to turn on
YES SIREEE, THE BULDGING CAPACITORS ARE MOST LIKELY YOUR PROBLEM. DO YOU KNOW HOW TO CHANGE THEM OUT??? IF YOU DO, I WOULD SUGGEST REPLACING THEM WITH NICHICON OR PANASONIC CAPACITORS.
May 10, 2012 | Vizio VW26L 26 in. LCD TV
Security light stays on and vehicle won't start
Try keeping the key in position for at least ten to twenty minutes, the security light may be blinking .
Leave it as such for twenty minutes and then turn off the key and then again turn the key on and try to start , it must reset the security system.
Nov 27, 2010 | 2001 Ford Expedition
I turned on the cleaning switch for my self cleaning wall oven and now it seems to be finished but mthe door lock is still on and the oven keeps making a buzzing noise what do I do?
If the lock does not open after the oven has cooled down, then try this: First, unplug the range or shut off the circuit breaker for ten minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. Next, set the self-clean cycle again and only allow it to work for twenty minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door
Mar 13, 2010 | Frigidaire 27 in. Electric Double...
Toshiba 27D46 Black Screen - White Horizontal Line
I fixed the problem by taking it to a repair shop
Apr 24, 2008 | Toshiba 27D46 27" TV
Black Squares on the Screen
this kind of problem is normally do of bad cable box or sat
Apr 05, 2008 | Vizio L32 32 in. LCD HDTV
Tuning in takes ages whilst warms up
IF your TV is not one of the real old ones, you have a problem with the automatic tuning system. Some component in this circuit most likely a capacitor or coil is changing its electrical properties due to temperature which in turn causes the set to be off frequency until it warms up. A capacitor (condenser) can do this quite often. Stargazer
Jan 10, 2007 | Bush 2871NTX 28" TV
Televison & Video Logo
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
