Question about HP PSC 1610 All-In-One InkJet Printer
Hp 1610 and 1018
I have an HP 1610 all in one, and an HP 1018 laser printer. When I try to print a document as a booklet, all of my fonts print much smaller. On my old laserjet 1100 everything prints fine. Any one have this issue?
I incresed the MS word font from arial 10pt to an arial 16pt. I had top reformat the doc, but it did the job. Thanks for you suggestions.
Posted on Jun 25, 2007
  • 97 Answers
The font you are prinitng with in Word or what you are using is the problem. The old Laser Jet you were using had a lower resolution and would not print in a smaller font. Check your software for the font size.
  • 432 Answers
Are you printing from MS Word? What software package are you using? Each printer is different and some require software settings.
Posted on Jun 23, 2007
SOURCE:
49.4C02 service error on laser jet 2300n HP ?
Check these things:
1) printer driver
2) Size of document to be printed...is it non-standard?
3) Complicated fonts/colors design.
4) Flush the printer queue/spooler.
Aug 06, 2014 | HP LaserJet Office Equipment & Supplies
MY LASER PRINTER KEEPS PRINTING WING DINGS
You need to go into the document or driver and select a new font.
Normally, this is a driver issue because the driver will control what fonts are selected on the hardware.
Sometimes, however, the printer's default font has been changed. This will cause the same problem. Check the printer properties and make sure you have the correct font selected.
Oct 20, 2010 | HP DeskJet 5550 InkJet Printer
HP Color laser jet 4700n 49.3048 service error
The problem is usually caused by printing a PDF file with fonts/page size/ page formating errors which will cause the printer to display the 49.3048 error. The only way to use the printer is to POR or recycle the power and delete the print job from the server or spooling device and cancel it on the printer before the offending command is issued to the printer again. You can try updating the firmware to the latest version 46.140.5 from the HP website. MIke L.
Oct 12, 2009 | HP Color LaserJet CP4005dn Network Printer
How do i change font size on HP 6110 xi printer
The manual doesn't list scaleable font size as a feature. You will probably have to set your font size in the document you are making.
Mar 05, 2009 | HP OfficeJet 6110 All-In-One InkJet...
HP 5610 All-in-One printer
If you are trying to print from word then try increasing the font size, In Word in the top you should see the tabs, Zoom, Font and Font Size try increasing the Font size upto your desire before typing anything and then print
Good Luck
Jul 12, 2008 | HP Officejet 5610 All-In-One InkJet...
HP laserjet p2015 printing problem
How old id the printer. What OS do you use. What driver version do you have and does the printer have any accessories fitted?
Jul 07, 2008 | HP LaserJet P2015 Printer
HP Photosmart 3210
Try reinstalling your display drivers. you'll be surprised how dependent printers are on display drivers. Try changing the font as well.
Do you get any error messages once you click the print button? is it sending to the correct printer?
Jun 15, 2008 | HP Photosmart 3210 Printer
Printing spine labels for books on hp laserjet 1020
convert the doc to a PDF so that the sizes and fonts save. That should fix your issue.
Jun 05, 2008 | HP LaserJet 1020 Printer
Brother Hl-2040 laser printer
Fonts and sizes are typically controlled by the application you are using. Are you sure you are increasing the font size? I've had some users confused by the zoom feature which is more like a magnifying lens. It just makes thing larger for viewing purposes and does not affect the print size. To change the actual font size of a document already created you would first highlight the text in the document. In Word (other applications are similar) you would then select Format from the main menu bar, then select Font. In the next box that appears you would click on the Font tab, and then in the Size field select a larger font size. After that click on OK and you should see your font size change. Let us know if that was your problem or not.
Aug 02, 2007 | Brother HL-2040 Laser Printer
HP PSC 1610 All-In-One InkJet Printer Logo
119 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
