Question about Exerpeutic 1111 900xl Extended Capacity Recumbent Bike With
Exerpeutic recumbent bike computer panel doesn't work
My computer panel on my new recumbent bike lights up but will not give me a reading. it stays set at zero. I tried resetting the panel and the same thing happens . Help ,,,please
How to assemble a weslo pursuit ct 4.2 bike video
Weslo Pursuit CT 4.2 Recumbent Cycle: Relaxing Exercise ...
www.kmart.com > ... > Recumbent Cycles
KmartSep 30, 2012 - Arts & Crafts · Video Games · Learning & Development · Stuffed Animals & Plush · Musical ... Weslo Pursuit CT 4.2 Recumbent Cycle 1 ... With a Weslo recumbent bike you can approach exercise with ease. .... Like all in box items it takes awhile to assemble, but works great, and great value for the money.
Weslo Exercise Bike - YouTube
? 2:55
https://www.youtube.com/watch?v=2ZLzpsk4BdE
Dec 22, 2014 - Uploaded by ReviewTube
Weslo Pursuit CT 2.0 R Exercise Bike http://amzn.to/1vgiQjF ...bike assembly,weslo exercise bike amazon ...
Weslo Pursuit CT 42 Recumbent Exercise Bike ... - YouTube
? 1:41
https://www.youtube.com/watch?v=tYdlVsnDNQo
Aug 20, 2015 - Uploaded by Geraldine T. Lane
SEE MORE Best Sellers in Exercise Bikes http://amzn.to/1frY7Yr The 3 Week Diet is an ... Weslo Pursuit CT 42 ...
Weslo Exercise Bike Product Support ' ManualsOnline.
Jan 17, 2016 | Weslo PURSUIT CT 4.2 Recumbent Cycle
How can I fix program screen on my Stairmaster 3800RC Recumbent Exercise Bike?
If you have not used your machine in about a year, most likely the battery is dead. You can find most of the parts you may need here:
Stairmaster 3800 RC Momentum Recumbent Bike Parts SPORTSMITH net
May 15, 2014 | Stairmaster 3800RC Recumbent Exercise Bike
What are the benefits of recumbent exercise bike?
Recumbent exercise bikes offer a few benefits. First of all, they have lower back support, which is important for people with low back problems. Another benefit is that put less pressure on the knees compared to other exercise bikes. Moreover, if you have limited space available, these chairs are a great choice since they are very compact.
Feb 07, 2013 | Exercise & Fitness
What's better a recumbent or an upright exercise bike?
Recumbent bike works best for elderly people with back and hip problems because of the relaxed position and the angle that put's less pressure on those areas. Upright exercise bike works on more areas than the recumbent bikes including the lower abdominal muscles.
Aug 09, 2012 | Exercise & Fitness
I also have a lifefitness recumbent 9500RHR. The display panel wont light up on pedalling. There was no 9V battery in it!! When I take off the cover is the rechargeable battery the blue round thing on the...
That component is a capacitor and not a battery, The battery is locate on the back portion of the bike frame, tilt the bike to its side you'll notice a plate remove the 4 screws flip the plate over. On that plate is the battery it has 2 leads red ( + ) and black ( - ) leave them on until you purchase the new battery. After receiving the Battery their is 2 screw that attach the battery to the plate and replace with new battery reverse procedure to install.
You may purchase this item from National Gym Supply Part # LC001.5 cost $19.80 tax and s/h Call them @ 1-800-496-7278
Jun 12, 2010 | Life Fitness 9500RHRT Recumbent Bike
PTS Turbo 1000 Recumbent Exercise bike
Hey im55830,
I was the production foreman for Pro Tec way back when, so hopefully I can help you a little.
As for the tire, depending on the actual production date and model, most of them were manufactured in house, so unless someone happens to have a supply stashed somewhere there is no direct replacement.
It is possible, and some of the first ones built did, use a normal tubed bicycle tire. We switched from those because under heavy use they did wear faster than we liked. So that is one option. I understand there maybe a website that carries solid tires that will work. Another option is to attempt to make a tire. The material should be available at a home repair store, if you took the tire in and tried to match the tubing. This is a last resort in my opinion but it is feasible.
Honestly I think I would try a normal tire or solid first. You should be able to remove the wheel and take it to a bicycle shop. It will need a liner to protect the inner tube. If you need I can walk you through removing and reinstalling the wheel.
As for the computer. For the life of me I can't remember the brand we used. I am guessing you have the handlebar mounted one with a small square head, as opposed to the fully computerised 2000 model.
Replacing it may be a bit of a problem. The computer set up was a stock bicycle computer. However we made a jumper wire to accomidate the length of the frame that plugged into the sensor lead and the computer mount.
As a stock item the sensor was connected to the mount so it involved cutting the wires, soldering connectors onto both the cut end of the mount and sensor. Then making another wire with connectors to run from under the seat along the frame and to where the sensor is mounted near the wheel. In theory any new bicycle computer could be used to replace the old one.
If you aren't up for that task, there's the possibility that there is some sort of wireless system available.
To install it you would need to lossen or remove the wheel cover to mount the other half of the sensor unit to the spokes. Depending on when the bike was manufactured this can range for very easy to a bit tricky.
Probably not everything you wanted to hear but I hope it helps
Feb 03, 2010 | Cycling
Hello. We have an Excel 395 Recumbent Magnetic Bike that is making grinding noises when used. Is there any easy solution to fix it myself. Or, should I just throw it away? Thanks, Greg T.
Sorry just saw your request, you'll have take the side panels off and look for read power on the frame this is a indication that the bearings on either flywheel or pulley assembly are destroyed depending on what you paid for you may want to get rid of it if you haven't already.
Jan 07, 2010 | Stairmaster 3800RC Recumbent Exercise Bike
The oomputer display on my recumbent bike does not
check the cable running from the computer to the main drive wheel. Check the alighment of the magnets
Oct 07, 2009 | Exercise & Fitness
Vital Fitness RB-251 Recumbent Bike Manual
Can I purchase a computer for my RB330P recumbent bike? If so where and how much?
Aug 23, 2008 | Sport & Outdoor - Others
Exerpeutic 1111 900xl Extended Capacity Recumbent Bike With Logo
80 people viewed this question
Top Exerpeutic Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exerpeutic Exercise and Fitnes Expert? Answer questions, earn points and help others
