Question about Woods InWall 7 Day Digital Programmable Timer (59018)
Trying to install a Woods 59018 with older copper wiring - My house only has one black wire (not the two black wires it calls for).
Trying to install a 59018 with older copper wiring. My house has a solid copper (neutral) that I've attached to the Woods' green. My house has a black copper wire painted white that I've attached to the Woods' white wire. Here's the problem. I only have one black house copper wire. The Woods unit calls for two black wires. I tried to attach it to the red and black Woods wires. The Woods unit powers up. I can hit the on/off button and it turns red and you can feel it switching. However, my lights (two canister CFLs) don't power on or off. Do I need to scrap the project or is there a simple solution (beyond calling in an electrician)? Thanks!
  • Socal Ken Dec 30, 2012
    So I played around with the suggestions below. I took the Woods' green and white wires, wound them together and attached them to the house bare copper. Then I took the Woods red wire and attached it to the house white wire. The Black Woods wire and attached it to the House Black. Success! But the question is, Is this safe?
  • Woods Master
  • 5,089 Answers
1) It is safe, but not code.
The timer uses such a tiny amount of power that the installation is safe, and the line is still protected by circuit breaker.
http://waterheatertimer.org/How-to-wire-timers.html
http://waterheatertimer.org/Troubleshoot-household-electricity.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
2) In the main breaker box, the neutral wires and ground wires are bonded together and both connect to ground wire leading out to pole and down into the ground.
3) By code a ground wire cannot be used as a neutral, even though both are connected together in the main box.
This is so electrician can work on ground wires while ASSUMING they do not complete a circuit.
NO ELECTRICIAN should assume that, since the purpose of ground wires is to ground stray current.
Posted on Dec 30, 2012
Testimonial: "Thanks for helping out a rookie Gene! Your guidance, combined with what I'll call the "FixYa Intelligent Archive," was awesome."
    Thanks Gene! We were worried we had a fire hazard brewing. Definitely feel better about it now.
  • 351 Answers
SOURCE: Help with Woods 59018/59028 7 day digital timer
The usual connection for this type timer is the house black power to the timer black, the house white power to the timer white and the , the light black wire to the red timer wire.
If you only have two wires, one black and one white, at the switch location, then you cannot use this style timer , as it needs a neutral. You should return this timer and get one that does not require a neutral connection.
Please Vote !!
Posted on Jun 01, 2010
SOURCE: Can't get my Woods Model 59018 digital timer to work
I have same problem and called the manufacturer. They told me they are supposed to help and that these need to be installed by an electrician.
Glad I bought mine at a Menard's which is targeted to the general market.
I don't want to support a company that says things like that to their customers so I am bringing mine back.
Posted on Oct 13, 2009
SOURCE: I'm trying to install this
Sure George.
These in-wall timers have extra wire to operate the electronics located inside timer.
You said your old switch has 3 wires.
The new timer can only replace on-off switch that has 2 brass screws and a green screw.
If old switch has 2 brass screws and a dark screw, that is a 3-way switch.
Typically a 3-way switch is found at both ends of hallway.
The Woods 95008 countdown timer is not made to replace 3-way:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59000
Here's what to do:
1) Switch has 2 wires (plus bare ground wire). Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
2) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires. This wire will power timer electronics.
3) If electric box does not have white wires described above, then connect timer-white to bare ground, along with timer-green wire.
4) Turn on electricity, and push override button located below the OFF button. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
Add a comment if your need more assistance.
Posted on Dec 22, 2010
Testimonial: "Geno, Thank you so very much. I finally got around to install one of the two fan switches and your advice was awesome. "
SOURCE: I am replacing a light
1) Woods 59000 series in-wall countdown timer has extra wire to run electronic clock circuit inside timer, just like plugging in ordinary alarm clock.
2) Open following link for wiring instructions, and to download online manual:
3) Instructions:
How to wire 59000 and 59017 in-wall timers
1) Timer-green-wire connects to bare ground wire.
2) Switch has 2 wires. Take switch wires and connect to timer-black-wire and timer-red-wire. Choose either one for now.
3) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires.
4) If electric box does not have white wires described above, then connect timer-white to bare ground along with green wire.
5) Turn on electricity, and push ON-OFF button. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Feb 21, 2011
SOURCE: I just installed a Wood 59018 timer, and when i
Timer is wired wrong and timer white and timer red wires are probably connected together.
Timer white wire has to be connected to white neutral wires that are twisted together and shoved to back of box. This will power the clock mechanism inside timer.
If box does not have white neutrals, then connect timer white wire to bare ground wire along with timer green wire.
Timer black wire connects to Hot wire.
Timer red wire connects to Load wire.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59028
Posted on Jul 10, 2011
I have a junction box with a 3 way switch that operates hall lights, and a 2 way switch that operates outdoor lights. I want to replace the 2 way with the Woods timer (59018). I tried following...
Remove timer, and reconnect both switches as they were before starting.
Notice if there is a wire that connects to both switches... this will be the Hot wire.
Then notice that the 2-way switch has two wires.
One wire will be Hot > and this wire connects to timer Black wire.
And the other wire goes to Load (light) > and this wire connects to timer red wire.
The timer green wire connects to bare ground wires.
This leaves the timer White wire > you can connect timer White wire with the other ground wires.... > or look in the back of switch box to notice a group of white wires covered with wire nut > connect timer White wire to these other white wires.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59018
Gene
h
Oct 28, 2013 | Coleman Cable Woods 59018 InWall 7Day...
I just installed a Woods Digital In-wall Timer Model #59018. When I switch the power and manually turn the power on, the lights rapidly flash on and off. This is a three-way outlet and I have red, black...
3-way outlet or 3-way switch?
Woods 59018 only replaces single-pole switch, and does not work for 3-way application. Often connecting timer wrong will cause lights to blink. No harm done to lights, timer or wiring.
There are several timers that work with 3-way. In each case the timer replaces 1 switch and other 3-way switch must be rewired.
http://waterheatertimer.org/ST01C-program.html#3-way
Gene
Aug 03, 2013 | Hardware & Accessories
Just installed a in-wall digital timer model 59018 and when we try to program it when we hit the clock button the unit shuts off so we are unable to set the time (or anything)
Woods 59018 single-pole 7-day 7-program timer, color white:
I test timers and 3-5% arrive defective, and they never work. Some stop working within 1 year, and some last quite a while.
Timers are affected by line interference and polarity issues. So wiring in home has to be correct before timer will operate as expected.
Timer has to be installed correctly with each wire correctly connected.
Press manual override button and see if lights turn on-off. This will indicate if your timer is wired correctly. If lights do not turn on-off with manual override, the open link above for wiring instructions.
To begin programming, reset timer by pushing in the round reset button with toothpick or paper clip.
12:00 am Mon should display.
If the above items are all correct, then defective timer is suspect.
If you try multiple timers, and each timer has same problem, then line interference or bad wiring is suspect, or you are buying from somebody who has a bad batch of timers.
Try wiring same timer at neighbor's house and see if it works there.
Jul 04, 2011 | Woods InWall 7 Day Digital Programmable...
I have the Woods 59018 In-Wall 7-Day Digital Timer, and am having trouble installing it. I am replacing an IntermaticModel EJ251 timer that only connects using two black wires in the junction box (as...
Open following link to identify timer, read wiring instructions, and download on-line manual:
How to wire timer
4) If electric box does not have white wires described above, then connect timer-white to bare ground.
5) Turn on electricity, and push timer door which is also the ON-OFF button. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Mar 06, 2011 | Coleman Cable Woods 59018 InWall 7Day...
Timer was connected with all wires correctly. On/Off button is lighting up red, but does not turn light on or off. Directions said try switching switch from off to timer, but unable to locate switch. ...
Woods timers:
Scroll down page to make sure your timer is shown.
You posted under Woods 59018-59028
GE 15086 timer has OFF-Timer switch
http://waterheatertimer.org/images/GE-15086-programmable.jpg
http://waterheatertimer.org/Programmable.html#Aube
Add a comment to identify timer, and I can help more
Double-check wiring:
2) Switch has 2 wires. Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
Nov 22, 2010 | Woods InWall 7 Day Digital Programmable...
I have a 59028 timer, and when I turn the lights on they flash - versus staying on.
59028 is a Woods in-wall timer.
See Woods timers and manuals:
Manual for 59208 timer:
http://waterheatertimer.org/pdf/Woods-59018-59028.pdf
The lights are blinking so the red and white wires are connected together.
Here's what to do Switch has 2 wires.
1) Green wire connects to bare copper
2) Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
Nov 20, 2010 | Hardware & Accessories
Woods In-wall Timer Heavy Duty, Model #59018 -- I just installed my timer and was able program and set the time, but when I push the manual override button to turn the light on, the light flashes and turns...
Quick answer:
1) Programming steps say 'press clock key to return to current time and day'
2) Use mode button and change between AUTO & RND >> try manual override in each mode
3) Does timer turn lights on-and-off with program, or do they blink too?
4) Swap Black and Red wires
5) Try timer on light in different room, on different circuit breaker
6) Timer might be defective
Longer answer:
Woods 59018 manual does not show troubleshooting steps except 'check wiring; switch Red and Black leads; and/or reset programming'
Seems unlikely you could program timer unless timer is wired correctly ... unless there is a short of some kind.
To review wiring.
Green goes to bare ground wire.
White goes to Neutral white wire (neutral is usually 2 or 3 white wires twisted together and shoved to back of box)
Black must connect to Hot from circuit breaker
Red must connect to Load (light, fan, motor etc)
How to test wiring
Disconnect timer and set aside.
Mark each wire
Separate wires in box so they don't touch
Use ordinary tester (you can tape tester leads to wood sticks)
Turn on power
You should have two black wires that were originally connected to switch
Test black wires to bare ground > when tester lights up, that is the Hot wire.
The other black wire goes to Load
Now you want to find the neutral.
Test the Hot black wire to white wires in box.
When tester lights up, that is neutral.
If everything checks out, I guess timer is defective.
Sep 29, 2010 | Woods InWall 7 Day Digital Programmable...
How do i program my woods 59028 timer?
Manual explains programming steps clearly. The steps are fairly long because there are several options. You can program 7 on events and 7 off events per week. Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
http://waterheatertimer.org/Woods-59028-59018.pdf
To save manual to your computer > click link above and let page fully open > go to File at top of browser > click save-as.
To print manual > open page > go to File > click print
Programming cannot take place until timer is wired correctly and power turned on. This is because clock motor inside timer runs on 120V circuit:
Timer has 4 wires
Black wire from timer connects to black hot wire from breaker box
Red wire connects to black wire going to load (lights, fan etc)
White wire from timer connects to white neutral from breaker box ((if no neutral is available, then connect white wire to bare ground wire)
Green wire connects to bare copper wire
To see sample of wiring when white connects to bare copper
http://waterheatertimer.org/images/EI210-wiring-full.jpg
Sep 18, 2010 | Woods 59028 Programmable Timer Switch...
Please Vote !!
Jun 01, 2010 | Woods 59028 Programmable Timer Switch...
Oct 03, 2009 | Woods Hardware & Accessories
Woods InWall 7 Day Digital Programmable Timer (59018) Logo
225 people viewed this question
Top Woods Hardware & Accessories Experts
Gene Haynes
Colin Stickland
Colin Stickland
Are you a Woods Hardware and Accessory Expert? Answer questions, earn points and help others
