Question about Dishwashers
Soap residue left on dishes and hardened residue, water left in bottom of machine after cycle finished
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 14 Answers
Start by filling the soap dispenser with white vinegar and run on the highest/hottest setting. Most likely this will not work but you can be hopeful.
Next, remove the mounting screws above the front of the dishwasher and pull out of counter. Disconnect the drain line from bottom of dishwasher (usually a flat-head or squeeze clamp) and also from the bottom of the sink. Take it outside and blow the hose out with either an air hose or the garden hose and check for debris. Re-install and check for operation. Also check the drain for debris.
If this fails, then your best bet is to purchase a new dishwasher because the sump pump has gone bad.
Posted on Dec 30, 2012
5 Suggested Answers
  • 105 Answers
SOURCE: soapy water standing in bottom not rinsing soap off dishes
It sounds as if it is not draining. Try to trace the drain line under the sink. Usually it goes into a disposall. The port where it connects to the disposall may be clogged. Another thought. If you had the disposall replaced recently they may not have taken the knock out plug out which would give the drain water no where to go.
Posted on Apr 09, 2009
skrbin
  • 121 Answers
SOURCE: Water left in bottom of machine when cycle finished.
you must check filter,it is full of dirt.
it must be on front side,down left or right corner,
Posted on May 22, 2009
heatman101
  • 43501 Answers
SOURCE: have white residue left on dishes after cleaning
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker
Posted on Nov 12, 2010
heatman101
  • 43501 Answers
SOURCE: My dishwasher is leaving residue or soap scum on my dishes...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
0=0
Posted on Mar 03, 2011
My GE profile dishwasher is leaving soap residue on the dishes after a wash cycle. Cloudy and a sort of fim on the dishes. Seems to be getting worse. I use the same dish detergent-Cascade and regulary use...
The problem is most likely that there is still water residue at the bottom of your machine. If the machine is not fully drained it picks up some of the residue and sprays that onto the dishes during the final rinse, leaving an unhealthy and unsightly film on everything.
Remove the bottom strainers and make sure that there is nothing obstructing the outlet pipe and the pump. If possible back flush through the outlet pipe and try draining the machine again before using it again.
Mar 04, 2011 | GE Dishwashers
It appears that the machine turns on, and operates, after the cycle is complete I open the door and the soap is still in the dish, and the glasses have water and some soap residue on the dishes
sounds like the water jets are clogged or the water is not completely draining from the unit do to clogged sump ports in the bottom of dishwasher or water pump
Jan 27, 2011 | Dishwashers
heatman101
0=0
May 02, 2010 | Kenmore 24 in. 15689 Built-in Dishwasher
Dishes on upper tray are left with soap residue
Soap residue would indicate drain not holding,allowing water to seep away prior to end of cycle Check the drain valve for obstruction. (2) check and clean the filter in the fill valve as it could be partially blocked not allowing enough water to enter the machine
Apr 24, 2010 | KitchenAid 24 in. KUDP01IL - Multiple...
All my dishes come out with some sort of a residue that won't even wash off with water and soap. The dishes seem to have the same type of residue that the coil in the bottom of the machine has built up.
scrub the film off with a Mr Clean Magic Eraser
make sure your water is at least 140 degrees
use ONLY Finish Tablets... formerly called Electrosol... from now on.
Oct 21, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Dishes left dirty - possible blockage
You can probably either unscrew a knob and remove the wash arms or they'll snap off and on. Take off the wash arms and make sure there aren't big chunks of food collected under there. If there's a plastic washer in the wash arm assembly, and it's looking worn, you'd be surprised how much quieter and better your machine will run by replacing it.
Sep 20, 2009 | Dishwashers
Soap is leaving residue on dishes
Hard water, add finishing rinse, rinso, jet dry etc, plus clean the inside once in awhile too!
Aug 25, 2009 | Dishwashers
Grit like residue after cycle finishes.
I had the same problem and it was fixed by switching dishwasher soap. We always used the same liquid soap for years and when this problem came out of the blue (about 8 months ago) I switched to Cascade action pacs with Dawn. It did the trick! No more residue since then. We now are having a problem with the dishwasher not draining (our unit is 8 years old), but the grit issue has been handled!
Aug 09, 2008 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus Soap does not dissolve
What is happening, is that your dishes are washing dry. Start the dishwasher and slowly turn the timer till it starts to fill. Let it go and see how they are after
Jun 20, 2008 | GE Nautilus 24" Built-in Dishwasher
Dishwashers Logo
56 people viewed this question
Top Dishwashers Experts
Owen Barnes
