Question about Garden
Tines wont turn on my snowblower
The shaft going into the gear housing that spins the tines moves, but the tines dont spin
aborcass
  • 2651 Answers
SOURCE: Amana NAV2330 Wont Agitate or Spin
i would assume that perhaps you did not wind hte belt correctly arround the legs of the pump and therefore are not putting the correct tension on hte pulley(remember to hook spring back up to tension idler?)
Posted on Dec 08, 2008
step7dad
SOURCE: GE Washer Model WJSR2080V3WW Agitates, Pumps, but will not Spin
I solved the mystery of the non spinning washing machine by GE. I pulled the agitator off and to my horror was a broken " hub". This the part in the middle of the basket under the agitator. The transmission shaft comes up through the center of it. Any way, it was severely broken and wedged in so it would not spin. Not sure if this is the only problem but I am going to buy a new machine. I can not get it unbolted to replace the hub and don't want to **** around with it. THANKS.
Posted on Jan 26, 2009
jumptrout51
  • 3361 Answers
SOURCE: whirlpool ultimate care 2 washer dont spin or aggitate
Replace the direct drive coupling on the motor.
Posted on Mar 11, 2009
SOURCE: Tine shaft removal for mantis 2 cycle tiller
Hi! I had the same problem last month. Contacted Mantis customer support. Below is the info they gave me Removing Worm Gear Place transmission in a vise with housing cover facing up and drive shaft to the left. Clamp brass worm gear so it cannot move and turn the tine shaft counter clockwise to remove; the shaft is threaded into gear, not pressed. The tine shaft is one solid piece and has right-hand threads. As it comes out of the housing, the bearings, seals & retainers will fall out with the tine shaft. Removing the Worm Shaft Take out the retaining clip at the lower end of the transmission; remove the drive shaft from the top end of the transmission. Place a rod that is longer than the drive shaft into the top of the transmission. Tap gently, and the worm shaft will fall into the cavity of the transmission housing. Hope this helps.
Posted on Jun 06, 2009
  • 112 Answers
SOURCE: Tines do not rotate with any power
what kind of cultivator??? sounds like oil on the cutch or broken clutch need more info.
Posted on Jul 15, 2009
Snowblower wheels will not move freely when drive is disengaged & and wheels will not turn when drive control engaged.
Check the drive shaft bushings if they are worn the gears are probably binding and this creates the problem you are having.
Feb 02, 2014 | Mtd Garden
Rear auger turns front auger not turning
From your information above, it sounds like a broken gear or tooth on the auger gearbox. (this could happen if you hit an object and your shear pin did not break, instead breaking your gear) Hope this helps.
Jan 25, 2014 | Simplicity I924E 2-Stage Snowblower...
When in gear right wheel drives left wheel is locked and will not move same when not engaged
Many snowblowers use pins (or bolts - see image below) that pass thru the shoulder of the rim of the tires thru a hole drilled thru the drive shaft. Removing both of the pins allows the tires to spin freely on the drive shaft and makes it much easier to push, pull and turn the snowblower. If they are not installed again, the machine will not "drive" and make clearing snow difficult to do. Installing only one will make the machine want to go in circles. Make sure you have these pins installed thru BOTH rim shoulders and drive shafts - locked in place. Other machines lock the tires in other ways - since it sounds like one side is working correctly - you should compare the two tires / rims and make them both look like the one that works properly. Good luck!
Jan 06, 2014 | Ariens 926054 Snow Blower 2 Stage 32 In
The motor runs but the tines no longer turn
Does the drive shaft turn and the tines just spin around it ? if not then on the drive shaft there is a gear box and you need to open that up (without the machine plugged in) and check to see why the gears aren't meshing properly.
Oct 12, 2013 | Snow Joe Tiller Joe - TJ601E - 9 AMP...
Drive shaft spinning and it will not go into gear.
If you put your cycle in gear and the drive shaft spins, but the motorcycle does not move, you probably have stripped worm gears in the final drive housing. Take off the large fill cap on the side of the final drive housing and inspect the large gear visually. It is probably cheaper to buy a final drive assembly and replace the whole unit than to pay the labor and parts to rebuild it. ($700 for the 1100, $850 for the 650)
Jul 12, 2011 | 2003 Yamaha V Star Classic
I purchased a Craftsman 205cc dual rear tine tiller (17" width) in 2009. I used it very little to break ground for a small garden (32'x12') after purchase then to till it a couple of times a...
It appears that the gear case on your model is not capable of being serviced. The cost is over 300 dollars. There is a shear pin or similar connection in the case where the shaft connects to the pulleys. It has broken off and the shaft has no torque now.
Mar 05, 2017 | Craftsman 205 cc 13" Dual Rotating Rear...
I have an Ariens 926LE snowblower. The blower spins but the auger spins slowly. It barely throws snow. Some times the auger stops spinning. Shear pins are fine.
Hi, The blower spins at full speed? If it does the belt, pulley, and shaft are good. Look at the shaft from the fan to the gear box while it's running and that shaft should be turning at the speed of the fan.
If the blower spins at full speed and the auger doesn't the most likely problem is the worm gear transmission from the blower shaft to the auger shaft.
A good way to visually inspect this is: With the machine turned off and the spark plug wire unhooked go to the front and try to rotate the auger by hand. If the gear box is good you will only be able to move the auger less than an inch. If the box is bad you will be able to move the auger a lot farther. While you are there recheck your shear pins.
You can also remove the blower drive belt and have someone turn the pulley by hand while you watch the auger. Put resistance on the auger with your gloved hand. If the box is good the auger will move smoothly in you hand. If it is bad, it will ****, move roughly, or stop.
While the other person is turning the pulley and you have some resistance on the auger look closely at the shaft running from the gearbox back to the blower. On some models there is a connecting sleeve and the roll pin that connects the sleeve to the shaft and gearbox will break.
If the gearbox is bad, it will have to be replaced as a complete unit.
Was this helpful? If you have any other questions, please ask.
Jan 10, 2011 | Garden
Tiller tines will not turn. Engine runs fine...
Well hopefully it's not the transmission, as sometimes these tend to go. Another common but cheaper repair are the two bearings where the tines connect to the unit.
MORE THAN LIKELY.. The bearing is located above the worm gear housing, the part connected to the tines beneath the guard. This removal can be somewhat frustrating but if you remove it and remove the engine flange you'll be able to manually spin the drive shaft and see if it's the worm gear housing/lower bearings or if it's the more likely bearing on the clutch drum or the clutch itself.
Apr 06, 2010 | Honda 25cc 4-cycle Mini Tiller
Put the tiller in a vise clamping on the bottom of worm gear housing. Remove worm gear housing cover. Clamp the worm gear at the top with a vise grip (I think Kuya Jon is correct in that you could skip this step because the transmission won't move when unscrewing, but I did it anyway just in case). Put a pipe wrench on the left tine shaft and unscrew it like it was a normal bolt. It's in there tight and it will take some force. When I unscrewed mine, the left bearing seal retainer, left bearing seal, and left bearing all came out with it. I just needed to replace the seals. I went to the right side, and with a screw driver carefully pried out the retainer. Then it's easy to just pull out the right seal with your finger. Put a new right seal in and insert the right retainer. Make sure the retainer is facing the correct way. I used a block of wood to tap mine in once I had it positioned because I was afraid to hit the retainer with a hammer. Now I put the tine shaft back in while holding the worm gear with the vise grip. Screw the shaft as far as it will go by hand and then go the rest of the way with a pipe wrench. Now came the tricky part. The right bearing did not slide right in. There was some resistance. I had to use a 1/2" threaded pvc pipe (not sure it needs to be threaded but that's what worked for me) longer than the tine shaft that was sticking out. I slip the pipe over the shaft against the bearing and tapped with a hammer. This drove the bearing in all the way. It needs to go in far enough to leave room for the seal and retainer. The plastic pvc allowed for this. Now put the right seal in. If the outer edge of the seal is only flush with the housing you did not tap the bearing in far enough. I made this mistake on my first try and tried to force the retainer in. Take it from me. It won't work. You will end up ordering another retainer to replace the one you mangled. Once in properly I slid the retainer over the shaft and then put a washer over that to tap against. The block of wood doesn't work on this side because the shaft is in the way. I used my pvc pipe again to tap against the washer and, wala, it worked like a charm. I hope this helps someone. All the other posts really helped me. Thanks!
May 01, 2009 | Mantis 2-Cycle Tiller
Washing machine will not spin or agitate.
Replace the timer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 10, 2009 | Washing Machines
Garden Logo
57 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
