Question about Hisense Televison & Video
Need to know what size screws go on a 55" hisense tv base stand
55" flat panel. Base was removed for transporting. Truck flipped, TV actually survived and works greats; however the package that had the screws was lost in the wreck.
ldaala
  • 65 Answers
SOURCE: need screw size for 26" niko tv stand. to mount the tv to the stand
man i looked and couldnt find a size but here is a number to a company who might can tell u, its called peerless mounts 1-800-473-3753 good luck
Posted on May 26, 2009
  • 187 Answers
SOURCE: the screws broke off when trying to remove the tv stand from my LG 42lg30. Is there any other way to remove the base stand? thanks
If you broke one of the base stand screw you will need to do as follow:
Remove the remaining screws of the stand and try to remove the stand, if you cant you will need to remove the back cover of the TV and then you will be able to remove the stand, remove the broken screw and put it all back.
It is pretty easy but if you feel you cant do it let me know and I can give you a detailed step by step guide.
Posted on May 27, 2009
SOURCE: removing the base of flat panel tv
You don't have to mess around with the screws on the bottom of the base.
There are 4 screws on the back of the Toshiba that are in line with the wall mounting screw holes.
Remove the 4 screws and the base falls off.
Posted on Oct 26, 2009
SOURCE: Removing the stand from a flat panel TV
None of these TVs have any problem removing the stand.
Stands for 32'' and larger TVs plug into the TV's body and are attached by 4 to 8 bolts that go through the cover, then through the plugged-in part of the stand and attach to the internal frame.
In most cases the bolts are 4 - one for each ray of the fork that goes into the TV.
Since bolts for the frame are metal bolts and bolts for the plastic back cover are usually wood-type screws (sharp on the top, wider thread) you can visually tell the one for the stand from the rest.
Look right above the stand for four, six or eight symettrically placed heads that are different from the ones you see on the corners.
Once you unscrew those the stand should feel more flexible and you can simply pull it back.
In order to do all that you have to have the TV laying on its face or back.
Watch out if it's heavy - you may need to support it towards the end of the operation. It's unlikely for it to get damaged if it falls down, but you still don't want to try your chances.
Giving it a little lift also helps unscrew the last bolts...otherwise all the force of the TV is pressing against it...and that makes it harder to unscrew.
Posted on Nov 07, 2009
SOURCE: need to know what size screws go in to the tv base
I ended up having to take my entire tv into Home Depot. This is what the package says on the screws that worked:
"Machine Screw Pan-Slotted 4mm- & X 20mm Stainless Steel BR-B/ 12-B/322"
I know this is an old post but since I couldn't find any answers when I was looking I wanted to help someone else out.
Posted on Apr 01, 2010
Hi there i need a replacement stand /base for a hisense 32" tv model number LHD32E130TUK
Please contact the TV manufacturer for this type of part. Fixya sells not parts of any kind.
Oct 14, 2016 | Hisense LHDN32V66AUS 32 in. LCD TV
How do you install the feet on the Model 32K3110W TV
To install the base, put the TV down on a clean flat surface covered with something soft to avoid scratching the TV's screen. Put the two base pieces into the slots on the bottom of the TV; they will only fit one way. Next secure the base with two screws for each leg. With the 32" TV, you need ST4x12 screws. This is shown in the Quick Setup Guide and is available from the Hisense product support page: http://hisense.com.au/single_support/32in-led-series-3-32k3110w/#product-manuals . See page 1 for the parts list and page 2 for a sketch of putting on the base.
I hope this helps.
Apr 29, 2016 | Televison & Video
I have wall mount and now I need remove the pedestal stand from the TV. But I have lost the manual and can some body explain the steps to remove the stand? Thank you
Without knowing the model of your TV, it may be tough, but typically it's 1 or 3 types:
- the whole base is a single piece that slots into the bottom of the TV, with a clip release.
- the base removes from the stand, and the stand removes from a slot in the TV. This may be fastened with clips or screws.
- the base is screwed into the TV, and you'll have to remove these to remove the stand.
If that doesn't help, please provide more details, like the make and model of your TV.
Dec 18, 2014 | Televison & Video
Need a base for lcd19W57aca for table stand
Contact the authorized dealer. They can help you to choose one. Electro help
Jul 22, 2014 | Hisense Televison & Video
How does one remove the Toshiba TV stand. There does not appear to be any levers etc to release it. We want to mount our TV on the wall so the stand needs removing.
ya we put four screws in the base of the stand you have to lay t.v. on a flat surface protect the screen from getting damaged by putting a blanket over it when u flip it over or lay it flat on the bed you will see the 4 screws that hold the base to the t.v., but if it's a model that's having trouble just leave the base on as you will probably be returning it the store where you bought it lol
Aug 24, 2009 | Toshiba 40RV525U 40 in. LCD TV
The screws broke off when trying to remove the tv stand from my LG 42lg30. Is there any other way to remove the base stand? thanks
May 26, 2009 | LG 42LG30 42 in. LCD HDTV
Removal of flat screen pedestal so I can wall mount tv
Had the same issue. I turn the unit upside down and while holding panel down just pulled staight up on the base. The circular base popped off without any damage. I just needed to remove for shipping.so I didn't have to remove the cylindrical post. Once the base is removed you can see a screw that probably attaches that cylinder to the unit. Carefully removing it should work. Good Luck....j
Nov 23, 2008 | Televison & Video
Removing the base of flat panel tv
Nov 23, 2008 | Toshiba Televison & Video
Remove base of Insignia ns-ltdvd26-09
to remove base from insignia tv
1)remove plastic cover from bottom rear of tv
2)remove 8 philips head screws on rear of tv above base
3)pick up tv and base will come off
once you remove it you realize how easy it is
Jun 29, 2008 | Insignia LCDTV26 26 in. Television
Televison & Video Logo
120 people viewed this question
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Electro Med Services...
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
