Question about Kenmore 63672 Convection/Microwave Oven
Broken door latch on Model 63679 Kenmore Elite Microwave.
Ordered new latch spring assembly but cannot see how to take door assembly apart to replace. Please help with directions on how to do.
  • Anonymous Feb 09, 2009
    broken spring latch on microwave but don't know how to remove door to fix it
  • Mary Hagan
    Mary Hagan Jul 22, 2014
    Does the Kenmore Elite Microwave Door Latch work for Emerson
  • Kenmore Master
  • 9,086 Answers
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can find helpful exploded views by entering your full Kenmore model number at the Sears parts site.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Please be aware that you may have a broken spring mounting tab on the inner door panel.
In such cases, the best way to fix that is to drill a hole in the remaining material, insert the spring, then add a dab of epoxy where they spring attaches to the panel.
Posted on Jan 18, 2009
How do you replace the handle
follow this steps and fix it. see the pictures attached. God bless you2f4dab72-f574-4367-8631-e2d40f813792.gif
Open Lever
If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Spring
If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch
If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook
If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring
If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button
If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator
If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Jun 18, 2013 | KitchenAid KHMS147 Microwave Oven
I have a amana road range microwave and the door won't close . AMV3204VAB-0
proceed according . God bless you
Open Lever
Door Spring
Door Latch
Door Hook
Button Spring
Button
Handle Actuator
Apr 02, 2013 | Microwave Ovens
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
How to fix a door latch of Samsung SMH9207ST microwave?
The small tab on the latch broke so the spring was loose. Took my drill and drilled a small hole in the main body, ran a small wire tie thru it and hooked the spring to the wire tie. Works great and more durable than the orginal dinky hook.
Dec 10, 2011 | Microwave Ovens
I have a frigidaire model fmv156dbf and the door latch will no longer operate. when i opened up the door i saw that the spring that is supposed to operate the latch was no longer attached. where the spring...
We have the service manual and have uploaded it to our site here to help you.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
You can order parts here if needed.
May 26, 2010 | Frigidaire Microwave Microwave Oven
How to install latch and spring in microwave door
You need to know where the 'catches' are inside the choke cover on the door to remove it carefully without breaking anything or marring the cover. You might get inside and find that the post for mounting the return spring has broken and that is part of the outer door panel.
Sep 11, 2009 | Sharp R-1610 Microwave Oven
The latch on kenmore micro #721-62622200 is broken at bottom
In order to have the correct operation of the door latch mechanism and latch switches.
  1. Ensure correct adjustment of the Door and the Latch switches.
  2. Wipe off any dirt or grease around the door key where it touches the latch switched and door hooks with a soft cloth. Maintaining the smooth movement of the latch mechanism and switches etc�
  3. After replacement of the latch mechanism and/or Latch switches. Make sure to confirm a smooth operation of these parts are in order.
to view the exact diagram of how to do this manually just click the link http://www.applianceaid.com/micro8.html
Mar 07, 2009 | Kenmore 62622 Microwave Oven
Kenmore Mod. 721.80524500 microwave door will not lock.
If you gently push up on the door latch heads (hook-like devices sticking out of the door) there should be spring tension. If they just flop right up, the spring is off inside.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Mar 06, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
Microwave broken door latch
The door latch head (hook) is pretty easy to replace or repair if that's the issue.
If you gently push up on the door latches (hook-like devices on the door) there should be spring tension. If they just flop right up, the spring is off.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
We have critical safety & disassembly info at our site, linked here.
Sep 24, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Door latch is broken
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
BUT - please note that we have critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Oct 20, 2007 | GE Advantium SCA2001BSS Microwave Oven
Kenmore 63672 Convection/Microwave Oven Logo
1,112 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
