Question about Sharp SD-NX10 CD Shelf System
Sharp sd nx10_out signal trouble
I´ve got a major problem with my 1-bit sharp sd-nx10. I get sound only from one speaker. All the connections are as should be, still I have no audiosignal from the left speaker. I´ve tested the speaker and I´m sure now that is nothing wrong on it. I believe that something is wrong with the subwoofer`s connection system with the left speaker. Please help me I relly love this great 1-bit?
  • 97 Answers
Try all of the spaekers on the channel you know works. If all are fine, swap the speaker lines to test them. Is the input a DVD player on RCA cables? A bad signal cable from a component can be a source for problem. Connect the speakers directly to the amp(if possible) bypassing the sub box. If all works without the box, suspect bad crossover or in the self-powered boxes a bad amp.
Posted on Jun 25, 2007
My sharp aquos has speakers on side of TV. the speakers are worn out and emit a low humming sound that disturbs the audio ? how can i solve the problem
A hum in a speaker is usually a bad connection on an audio jack, this allows interference to enter the audio signal stream Check all the connections and cables. Swap cables if you have the ability. If that does not reveal the source of the problem, you may have a component on the power supply that filters line noise that is going bad.
Oct 18, 2017 | Sharp Televison & Video
Sound
Your TV has both analog and digital sound output jacks. You will need to connect to an audio amplifier/speaker system that can use either of these types of audio signals. Consult your TV user manual for more info.
Mar 22, 2014 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Low sound output from Front Speakers
The out put transisters are probally fried for the front channels,
Nov 27, 2012 | Sony STR-DE695 Digital Audio/Video Control...
I keep getting a Card Access Error message on my Sharp VE-CG40U, what could be causing this?
Actually, you didn't. You put in a new 4GB SDHC card. The camcorder works with SD cards, not with SDHC cards. You need to use SD cards, 2GB and smaller.
May 03, 2012 | Sharp VE-CG40U Digital Camera
What is a meaning of Error 00 for camera samsung nx10?
Error 00 error message. Disconnect the lens and carefully reconnect it when you see the "error 00" message with your Samsung camera. The problem likely occurred because the lens wasn't connected properly initially.
hope helps.
May 20, 2011 | Samsung NX10 Digital Camera
My tuner will not work! I've had this unit for 4 years & it's always worked perfectly. Then yesterday, the tuner stopped working. "Tuning" flashes on-screen intermittently & no...
1. Verify the source of the signal - Look for any antennas that may have been hooked up, and verify connection has not been moved or removed.
2. Test with a different output by plugging in some headphones, and recheck the volume through the headphones.
3. Check that the A/B switch for the speakers has not been moved, and that they are switched to the correct speakers.
4. Try AM and FM for any signals both with speakers and then headphones.
Bruce
May 05, 2011 | Audio Players & Recorders
No sound from speakers. Everything else OK.
If headphones work then so does the amplifier. When did this problem start? From what I can find it almost sounds like it thinks you have headphones plugged in, which would disable the speakers.
Apr 24, 2009 | Audio Players & Recorders
No sound no nothing !
make sure :
1- the the speakers are connected to the sub woofer correctly
2- the sound driver is installed on your computer ( you can check that from Device Manager )
3- that you connected the sub woofer jack to the correct jack of your computer
4- the volume parameter is set to highest in your computer
if nothing works out then i suggest connecting the speakers to another device ( like ipod or mp3 player )
if either this won't work then the speakers are obviously corrupted :)
Dec 25, 2007 | Creative Labs I-Trigue 3600 Computer...
Receiver won't put out sound to LCD Sharp aquos
I have the same problem with my Sharp Lcd and Onkyo 804. I believe one problem is that the TV can not accept dolby digital or dts digital audio signals through HDMI. It will play sound if it receives a PCM signal through HDMI. You can try switching the type of signal on the cable box settings and on the dvd player. I switched to PCM and got sound through the TV and the receiver. The problem is that PCM is usually only a 2 channel signal and Dolby 5.1 will sound better through the surround sound theater system. I have not found an absolute solution to this yet, but I am willing to not get sound through the lousy TV speakers in order to get top notch sound through the Onkyo.
Nov 12, 2007 | Onkyo TX-SR803 Receiver
Sharp SD-NX10 CD Shelf System Logo
688 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve Allison
Steve Allison
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
