Question about Activision Skylanders GIANTS Starter Kit PS3
Ps3 skylanders giants no sound
There is no volume even after going into settings and audio. Specific to this disc as other discs have volume in ps3
    Prodigy:
    An expert who has answered 500 questions.
  • Activision Expert
  • 537 Answers
Get disc replaced.
Posted on Nov 06, 2013
Why my wii skylanders giants won't read cd
This will depend on a few things.
1. If sky landers is the only game that will not work then it is likely that it is scratched or damaged in a way that makes it difficult to read. You can buy special cleaner for your cd to help with this if the damage is moderate to minimal. Or use a home remedy like tubing a banana on the side to be read and wiping it all off with a microfiber cloth and giving it a quick rinse (never submerge) and drying. The banana fills in some of the scratches.
2. If you wii has a hard time reading any disc then you should buy a cleaning disc meant to go inside the wii and clean the reader. One designed for computers and CD players should work just fine.
May 13, 2014 | Activision Skylanders GIANTS Starter Kit...
Will not read disc
The disc is probably scratched, if it is I would recommend buying the game again. If not then see if any oher discs are not working if others are messing up as well then it may be an issue with the wii.
Apr 19, 2014 | Activision Skylanders GIANTS Starter Kit...
PORTAL WILL NOT RECOGNIZE CHARACTER
Skylanders SWAP Force
  1. With the toy on the Portal, select Pause.
  2. Select Skylander.
  3. Select Manage.
  4. Select Reset.. If you are resetting a swappable toy, you must reset both the Top and the Bottomseparately.
Skylanders Giants
  1. Keep the broken Skylanders toy on the Portal of Power and open the Pause Menu.
  2. Return to the Main Menu.
  3. Open Settings.
  4. Select General.
  5. Select Reset Broken Toys.
  6. Select Yes when you are asked to reset the Skylanders toy.
  7. Repeat Steps 5 and 6.
  8. Keep the reset Skylanders toy on the Portal of Power and start a game in Story Mode.
Sep 02, 2013 | Activision Skylanders: Giants Portal...
We can't get to the next level of Skylanders giants.
What do you mean by "no longer being read" ?
If it that error "Disc is unreadable" that is the problem, you have to check your disc, because it might have scratches, dust or some gore that shouldn't be there.
If that is the problem, you should remove whatever is on the backside with warm water and gently rubbing it of with your fingers (not nails!). If you have scratches, and nothing else, then you must either get a new copy of the game or you can try something that might sound very weird, but CAN work.
- Remember that if you try to fix the game by yourself, it's at your own risk! -
If you want to try fixing those scratches you must get some toothpaste, yes toothpaste.
Then you take some of the tootpaste on your finger (remember to not hit the disc with your nails!) and gently rub it over the disc, apply more toothpaste if you can't get it over the whole disc.
When you have done that, you'll get all the toothpaste of the disc, using nothing but warm water.
When that is done, you'll just let it dry, place it on a towel or something like that (with the BACK side up).
And when it is dry, you just put it in your xbox and play the game! It usually work, I've done it with 3-4 games, and all of them worked atleast for 2-3 more weeks. :)
Jan 07, 2013 | Activision Xbox 360 Skylanders Giants...
My wii console can't read my wii U skylander giants disc
I can only pray this is a joke question. Wii ISN'T wii U. That's whyit wont work. It's like putting a wii disc into a ps3.
Dec 01, 2012 | Activision Skylanders Giants Starter Pack...
No audio even i already installed the audio driver
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
hope this helps
Feb 02, 2011 | Asrock P4VT8+ P4 PT800 Prescott Ready...
Can't get 5.1 audio from bose surround system using PS3 blueray
Yes but first thing, the blu-ray disc you are playing must be 5.1 to get true 5.1. If it is an older movie/TV show, then it might be only 2 channel audio. If this is the case, then your Bose system needs to create simulated 5.1 surround sound, which is not true 5.1. However, if your blu-ray disc is a true 5.1, then your PS3 needs to be set to output 5.1. I am not familiar with the PS3 so I am not sure where to located that setting. Also, try other blu-ray discs.
Apr 25, 2009 | Sony Playstation 3 (PS3) Console
PS3 no longer plays Bluray discs in surround sound
check your blueray settings updates can reset them sometimes.
Apr 23, 2009 | Sony Playstation 3 (PS3) Console
Audio crackles at normal volume with game discs
they said there would be a problem for LG tv's try going to your settings audio settings and change stuff around
Jun 24, 2008 | Sony Playstation 3 (PS3) Console
Activision Skylanders GIANTS Starter Kit PS3 Logo
300 people viewed this question
Top Activision Video Game Consoles & Games Experts
Zhenya Ogorodnikov
James Wishart
ray gallant
Are you an Activision Video Game Console and Game Expert? Answer questions, earn points and help others
