Question about Canon Vixia Hfr300 32x51x Advanced Optical Zoom 3. Inch Touchscreen
Initialize only using the camcorder - Canon Vixia Hfr300 32x51x Advanced Optical Zoom 3. Inch Touchscreen
Do you have to initialize your camcorder before you start?
You do have to initialize the DVD-R before recording into it and you have to finalize it when it is full (or whenever you wish to) in order to view it on DVD players.
Thanks for using Fixya!
Jun 01, 2011 | Canon DC210 DVD Camcorder
How do you delete videos from your sony handycam DCR-DVD405
This Sony camcorder uses mini-DVDs to record and there are certain restrictions when DVD is used, it is not like videotape. For a DVD-R disc, you cannot delete video once it is recorded because this type of disc is a record once only. Depending on which other disc type you use and how it was initialized, you MAY be able to delete video. For a DVD+RW disc, or a DVD-RW disc initialized in VIDEO mode, you can delete the last scene IF you have not removed the disc and not recorded any new video. For a DVD-RW disc initialized in VR mode, you can delete anytime. And here is how:
Turn on camcorder and press PLAY. Select the video or still image tab that contains the data you want to delete. Touch EDIT. Touch DELETE. Select what you want deleted. The selected scene is marked with a checkmark. Press and hold the image on the LCD screen to confirm. Touch RETURN to go back to previous screen. Touch OK - YES. You cannot recover data once deleted. There is also a DELETE ALL to delete all video or images.
Mar 22, 2011 | Sony Handycam DCR-DVD405 Camcorder
Can you initialize a DVD-RW after you have recorded on it?
hi its geoff
yes you can. i dose say that no more recording can be done after the disc is finalized (thats true, you first have to unfinalize the cd to write more files on it.but you can initialize the disk at any time but you lose the recorded content(it frormats the disk) then you can use the disk over and over again. remember finalizing and unfinalizing requires you to plug the mains charger into the camcorder it assumes theres not enough power in the battery to do the job and will need the mains every time.but initializing only requires sufficient battery power .
Aug 10, 2010 | Canon DC210 DVD Camcorder
Canon FS200 won't fully initialize 32 GB SDHC card
I heard about that quite a lot of time,in deed. But, I personally haven't load 16 or 32 GB memory card in Canon FS200. At the very begining, I was thinking of using 16 GB SDHC card instead of built in 8 GB memory. The shop assistance don't advice me to buy more than that 8GB because he also know that problem. So then, I am still using with 8GB untill now.
Jul 05, 2009 | Canon FS100 Flash Media Camcorder
Failure to initialize and use memory card SD/SDHC / canon fs100 camcorder
I had the same problem but fixed it by initializing the SDHC Card. It explains it in the manual. If you go to the menu and then down to the card it gives the option to initialize it. I did that for all my cards and now they work fine. Hope that helps...
May 28, 2009 | Canon FS100 Flash Media Camcorder
Did not initialize Canon DC220
try fully charging it and finalizing the disk then try it on your computer
only if your useing a -RW DVD
Apr 22, 2009 | Canon DC210 DVD Camcorder
Cannot initialize disc Canon Dvd camcorder dc210 (dvd-rw)
plz try to clean the DVD rom lens with a lens cleaner..
Feb 07, 2009 | Canon DC210 DVD Camcorder
Initializing DVD-RW Discs
This camcorder only takes DVD-R and DVD-RW, it will not work with the +R discs. I've used Maxell and Fujifilm discs and they both worked fine. You have to make sure the camcorder is plugged in the wall when initializing or else it won't initialize.
May 22, 2008 | Canon DC100 DVD Camcorder
Disc prepare for next use
I think camcorder can initialize/ format dvd. Check its menu items.
May 06, 2008 | Sony Handycam DCR-DVD201 DVD Camcorder
Puttiny videos on my computer
Let me tell you that you can only store stills taken from your camera that too in still mode initiated on your GR-D370. To transfer video to your computer you require a firewire cable, a DV port on your PC.
Apr 23, 2007 | JVC GR-D370 Mini DV Digital Camcorder
Canon Vixia Hfr300 32x51x Advanced Optical Zoom 3. Inch Touchscreen Logo
103 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
